time-step size
time-step size
In refinement grids, is it possible that the donor and receiver grids be not an integer factor (RefineScale) of the time-step size( while are in grid-size) ? For example is it possible that for RefineScale=5, time steps be 50 and 40 sec in coarse and fine grids, respectively, not 50 and 10 sec?
Re: time-step size
Even if this was possible, using a different time step (other than once scaled by the ratio of the parent:nested grid size) would cause the nested grids to have different CFL numbers, diffusion numbers (K*dt/dx^2, K*dt/dy^2) than the parent grid and hence alter the numerical properties of the solutions in the nested grids because the truncation errors of the numerical schemes employed to solve the equations are dependent on these dimensionless numbers. So the error properties of the parent and nested grids would be less consistent (with each other) and this may lead to stability and/or accuracy issues. Just my thoughts.
