seamount
Cool Findings and Plots
vip545
seamount
#1 Unread post by vip545 »
I run the SEAMOUNT case, but the seamount shape could not be found when the flow field (temperature, u, v) was plot. can someone know how to obtain the seamount shape in the seamount.h or ocean_seamount.in.
thankyou very much!
Re: seamount
How are you plotting it? Your plotting tools need to know about the z coordinate stretching.
The depth is set in ana_grid.h:
#elif defined SEAMOUNT
      DO j=JstrT,JendT
        DO i=IstrT,IendT
          val1=(xr(i,j)-0.5_r8*Xsize)/40000.0_r8
          val2=(yr(i,j)-0.5_r8*Esize)/40000.0_r8
          h(i,j)=depth-4500.0_r8*EXP(-(val1*val1+val2*val2))
vip545
Re: seamount
#3 Unread post by vip545 »
Thankyou for your help! i want to create a flow from west to east with a constant eastward flow velocity of 0.5m/s for this seamount case. so i set a Cla boundary condition on western side and Rad boundary condition on eastern side (LBC(isUvel)== Cla Clo Rad Clo !3D u-momentum). The flow velocity was given through ANA_M3OBC (the velocity was 0.5). the details are as follows,
#if defined SEAMOUNT
IF (LBC(iwest,isUvel,ng)%acquire.and. &
& LBC(iwest,isVvel,ng)%acquire.and. &
& DOMAIN(ng)%Western_Edge(tile)) THEN
DO k=1,N(ng)
DO j=JstrT,JendT
BOUNDARY(ng)%u_west(j,k)=0.5_r8
DO j=JstrP,JendT
BOUNDARY(ng)%v_west(j,k)=0.0_r8
i want to know what i have set is right or wrong to realize the constant eastward flow? the results shows the velocity is very small and the flow is also irregular, i hope someone can help me make the right set. thankyou very much!
Re: seamount
What are your ubar boundary conditions? You need to set up a consistent ubar for ANA_M2OBC.
vip545
Re: seamount
#5 Unread post by vip545 »
kate, thankyou :) i got the expected flow field.
