Seagrid installation - mexrect.F error - out of memory
ngarg
#1 Unread post by ngarg »
I am installing the seagrid package from the svn link on ROMS website instead of the one on USGS. When I use the script make_seagrid_mex, I get the following error:
Error using mexrect
Out of memory. Type HELP MEMORY for your options.
Error in test_mexrect (line 37)
z = mexrect ( z, np, n(1), n(2), n(3), n(4) );
Error in make_seagrid_mex (line 16)
test_mexrect;
With my little understanding, I believe it has something to do with mexrect routine in the fortran file. I am working on Matlab R13 linux 64 bit version. I managed to compile and test both mexsepeli and mexinside routines. I tried to change the size of Z, N and T array in the mexrect.F file but it does not solve it for me.
I was wondering if someone can help me solve this error.
Also, just for the information, when i use the Seagrid package from USGS website and compile mex files, it compiles them, but when i again pass mexrect command, i get segmentation fault.
ngarg
Re: Seagrid installation - mexrect.F error - out of memory
#2 Unread post by ngarg »
After heaps of google search about mex files in Matlab 64 bit, I managed to get the mexrect file compiled and I was able to use the text_mexrect file on my linux 64 bit machine.
I modified the original mexrect.F in following way:
subroutine mexFunction ( nlhs, plhs, nrhs, prhs )
implicit none
#if defined (__alpha__) || defined (__x86_64__)
integer*8 plhs(*), prhs(*)
#else
integer plhs(*), prhs(*)
integer*8 mxCreateDoubleMatrix, mxGetM, mxGetN, mxGetPi
integer*8 mxGetPr
#include "fintrf.h"
implicit none
mwPointer plhs(*), prhs(*)
#else
mwPointer mxCreateDoubleMatrix, mxGetM, mxGetN, mxGetPi
mwPointer mxGetPr
Now, I am not sure why but it lets the compiler for Matlab 2013 compile the fortran file. I think its due to change in the Matlab Api or something.
