bug in main3d
turuncu
bug in main3d
#1 Unread post by turuncu »
I think, i found a bug in main3d. When i run the model (revision 737) in coupling mode (coupled with atmospheric model) the model is not run correctly. For example, if i set coupling interval as 1-hour the model runs 30 step (in my case dt = 120 s) for first 1-hour but after that it runs until end time and it does not stop in next 1-hour. I check the code and add following statement to it just before reading required data
      IF (tile == 0) then
              PRINT*, Time_Step, step_counter(ng), Rsteps, RunInterval
It writes following information to the stdout.
First iteration (1-hour) - F 30 30 3480.00000000000
Second iteration (1-hour) - T 60 30 3480.00000000000
I think that following statement is wrong,
IF (step_counter(ng).eq.Rsteps) Time_Step=.FALSE.
and should be like that
IF (MOD(step_counter(ng),Rsteps).eq.0) Time_Step=.FALSE.
Anyway, i modified code and run it. In this case, the ROMS model hanging after second iteration. So i just wonder that is this a bug? Do you have any idea about it?
PS: If you use the model in standalone mode, probably you won't see any problem.
Regards,
--ufuk
turuncu
Re: bug in main3d
#2 Unread post by turuncu »
Hi Again,
To fix hanging problem i also fix "ROMS/Utility/ntimestep.F". I just initialise my_Nsteps as 1.
          ELSE
            my_Nsteps(ig)=1
            my_Nsteps(ig)=MAX(my_Nsteps(ig), WindowSteps(ig)+1)
            step_counter(ng)=step_counter(ng)+WindowSteps(ig)+1
# ifdef ADJOINT
The previous version had a problem because my_Nsteps is not initializing and it has some garbage value comes from memory.
--ufuk
Re: bug in main3d
#3 Unread post by kate »
Thanks for the reports! I assume this is COAWST? I'll be trying the coupled atmosphere option soon.
Re: bug in main3d
#4 Unread post by jcwarner »
this is a roms specific issue. for the model coupling in coawst we simply have
IF (iic(ng).ne.ntstart(ng)) THEN
CALL ocean_coupling (nl)
COAWST looks at the dt of all the models and determines the number of steps each model should take before coupling. For roms it uses iic(ng) as the time step indicator. Do notice that coawst is different model coupling than distributed by rutgers. i dont think the rutgers version would couple to wrf correctly. Suggest users use coawst for any model coupling.
More importantly I think that the my_Nsteps issue is real. It is never initialized at the top of ntimestep.F, but can be used for the case
ELSE
turuncu
Re: bug in main3d
#5 Unread post by turuncu »
No. It is not COWAST. I wrote my own driver
RegESM - https://github.com/uturuncoglu/RegESM
to couple ROMS with ICTP's RegCM regional climate model. I just want to test the latest version of the ROMS with the driver, then i found this error.
--ufuk
