Hi!
Can someone tell me how to set or create the 'time' string within the netcdf file?
Now i try to use COAWSTv3.1, and i can find there is a new file 'check_multifile.F' (COAWST/ROMS/Utility) that do the file checking. But i dont know how to create such netcdf files (One example is that i want to create two forcing files, one for tide, another for wind stresses. In the previous version, i set 'sms_time' within the second file and it works, but in the new version it shows error message: 'unable to find time variable in input NetCDF file'.....'variable name does not contains the 'time' string').
I hope that someone could help me. Thanks!
How to set 'time' in the input NETCDF files (COAWSTv3.1)
Re: How to set 'time' in the input NETCDF files (COAWSTv3.1)
The current ROMS (now in COAWST) gets its time by one of two ways:
- 1. The "time" attribute on the variable. Here's an example with a non-default time, needing a "time" attribute:
2. Having a time variable that agrees with that listed in the varinfo.dat file. Here's an example without a "time" attribute:
double ocean_time(ocean_time) ; ocean_time:long_name = "time" ; ocean_time:units = "days since 1900-01-01 00:00:00" ; ocean_time:field = " " ; double vbar_south(ocean_time, xi_v) ; vbar_south:_FillValue = 1.26765060022823e+30 ; vbar_south:long_name = "2D v-momentum south boundary condition" ; vbar_south:units = "meter second-1" ; vbar_south:field = "vbar_south, scalar, series" ; vbar_south:time = "ocean_time" ;
which then depends on this in the varinfo.dat:Code: Select all
double wind_time(wind_time) ; wind_time:units = "days since 1900-01-01 00:00:00" ; wind_time:calendar = "LEAP" ; float Vwind(wind_time, lat, lon) ; Vwind:_FillValue = 1.e+15f ; Vwind:missing_value = 1.e+15f ; Vwind:long_name = "Northward wind at 2 m above the displacement height" ; Vwind:units = "m/s" ; Vwind:coordinates = "lon lat" ;
'Uwind' ! Input 'surface u-wind component' 'meter second-1' ! [m/s] 'u-wind, scalar, series' 'wind_time' 'idUair' 'r2dvar' 1.0d0
Thanks very much!
I just figure out my problem. The problem comes from the code that i used to create the NetCDF file for wind stress.
The original matlab code was written as:
v1 = netcdf.defVar(nc,'sms_time','double',[time_steps one]);
% Here 'time_steps' is a self-defined parameter.
Because the new 'check_multifile.F' 'Search for the time variable: any 1D array variable with the string 'time' in the variable name'. So, the code above is not reasonable any more. It should be modified as:
v1 = netcdf.defVar(nc,'sms_time','double',time_steps);
I made the modification, and now it works. Hope i make myself clear. Thanks!
