Hi,can you help me?
I make my boundary all is T,but my roms can't running.the error is
South China Sea model
Operating system : Linux
CPU/hardware : x86_64
Compiler system : pgi
Compiler command : /dcfs2/program/mpi/mvapich2/1.8/pgcc.pgf90/bin/mpif90
Compiler flags : -O3 -Mfree
Input Script :
SVN Revision :
Local Root : /dcfs2/users/langlangxie/Myabc/trunk
Header Dir : /dcfs2/users/langlangxie/Projects/year
Header file : test.h
Analytical Dir: /dcfs2/users/langlangxie/Projects/year
Resolution, Grid 01: 0091x0095x032, Parallel Nodes: 64, Tiling: 008x008
103680 ntimes Number of timesteps for 3-D equations.
600.000 dt Timestep size (s) for 3-D equations.
51840 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
0 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
4320 nAVG Number of timesteps between the writing of
51840 ndefAVG Number of timesteps between creation of new
time-averaged file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
1.0000E+02 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
5.0000E-03 Zob Bottom roughness (m).
1 lmd_Jwt Jerlov water type.
3.0000E-01 theta_b S-coordinate bottom control parameter.
5.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
5.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
5.0000E+00 Znudg Nudging/relaxation time scale (days)
5.0000E+00 M2nudg Nudging/relaxation time scale (days)
5.0000E+00 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.2000E+02 obcfac Factor between passive and active
T VolCons(1) NLM western edge boundary volume conservation.
T VolCons(2) NLM southern edge boundary volume conservation.
T VolCons(3) NLM eastern edge boundary volume conservation.
T VolCons(4) NLM northern edge boundary volume conservation.
T Hout(idu3dE) Write out 3D U-wastward component at RHO-points.
T Hout(idv3dN) Write out 3D V-northward component at RHO-points.
T Aout(idu3dE) Write out averaged 3D U-eastward at RHO-points.
T Aout(idv3dN) Write out averaged 3D V-northward at RHO-points.
T Aout(idTsur) Write out averaged surface net heat flux.
T Aout(idTsur) Write out averaged surface net salt flux.
Output Restart File: /public/userspace/langlangxie/year/year_rst_y20.nc
Prefix for Averages Files: /public/userspace/langlangxie/year/year_avg_y20
Input Grid File: scs_grd.nc
Input Nonlinear Initial File: scs_ini.nc
Input Forcing File 01: scs_frc.nc
Input Boundary File: scs_bry.nc
[node53:mpi_rank_32][error_sighandler] Caught error: Segmentation fault (signal 11)
Tile partition information for Grid 01: 0091x0095x0032 tiling: 008x008
tile Istr Iend Jstr Jend Npts
0 1 10 1 12 3840
1 11 22 1 12 4608
2 23 34 1 12 4608
3 35 46 1 12 4608
4 47 58 1 12 4608
5 59 70 1 12 4608
6 71 82 1 12 4608
7 83 91 1 12 3456
8 1 10 13 24 3840
9 11 22 13 24 4608
10 23 34 13 24 4608
11 35 46 13 24 4608
12 47 58 13 24 4608
13 59 70 13 24 4608
14 71 82 13 24 4608
15 83 91 13 24 3456
16 1 10 25 36 3840
17 11 22 25 36 4608
18 23 34 25 36 4608
19 35 46 25 36 4608
20 47 58 25 36 4608
21 59 70 25 36 4608
22 71 82 25 36 4608
23 83 91 25 36 3456
24 1 10 37 48 3840
25 11 22 37 48 4608
26 23 34 37 48 4608
27 35 46 37 48 4608
28 47 58 37 48 4608
29 59 70 37 48 4608
30 71 82 37 48 4608
31 83 91 37 48 3456
32 1 10 49 60 3840
33 11 22 49 60 4608
34 23 34 49 60 4608
35 35 46 49 60 4608
36 47 58 49 60 4608
37 59 70 49 60 4608
38 71 82 49 60 4608
39 83 91 49 60 3456
40 1 10 61 72 3840
41 11 22 61 72 4608
42 23 34 61 72 4608
43 35 46 61 72 4608
44 47 58 61 72 4608
45 59 70 61 72 4608
46 71 82 61 72 4608
47 83 91 61 72 3456
48 1 10 73 84 3840
49 11 22 73 84 4608
50 23 34 73 84 4608
51 35 46 73 84 4608
52 47 58 73 84 4608
53 59 70 73 84 4608
54 71 82 73 84 4608
55 83 91 73 84 3456
56 1 10 85 95 3520
57 11 22 85 95 4224
58 23 34 85 95 4224
59 35 46 85 95 4224
60 47 58 85 95 4224
61 59 70 85 95 4224
62 71 82 85 95 4224
63 83 91 85 95 3168
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 10.50 0.50 12.50 RHO-points
1 10.50 22.50 0.50 12.50 RHO-points
2 22.50 34.50 0.50 12.50 RHO-points
3 34.50 46.50 0.50 12.50 RHO-points
4 46.50 58.50 0.50 12.50 RHO-points
5 58.50 70.50 0.50 12.50 RHO-points
6 70.50 82.50 0.50 12.50 RHO-points
7 82.50 91.50 0.50 12.50 RHO-points
8 0.50 10.50 12.50 24.50 RHO-points
9 10.50 22.50 12.50 24.50 RHO-points
10 22.50 34.50 12.50 24.50 RHO-points
11 34.50 46.50 12.50 24.50 RHO-points
12 46.50 58.50 12.50 24.50 RHO-points
13 58.50 70.50 12.50 24.50 RHO-points
14 70.50 82.50 12.50 24.50 RHO-points
15 82.50 91.50 12.50 24.50 RHO-points
16 0.50 10.50 24.50 36.50 RHO-points
17 10.50 22.50 24.50 36.50 RHO-points
18 22.50 34.50 24.50 36.50 RHO-points
19 34.50 46.50 24.50 36.50 RHO-points
20 46.50 58.50 24.50 36.50 RHO-points
21 58.50 70.50 24.50 36.50 RHO-points
22 70.50 82.50 24.50 36.50 RHO-points
23 82.50 91.50 24.50 36.50 RHO-points
24 0.50 10.50 36.50 48.50 RHO-points
25 10.50 22.50 36.50 48.50 RHO-points
26 22.50 34.50 36.50 48.50 RHO-points
27 34.50 46.50 36.50 48.50 RHO-points
28 46.50 58.50 36.50 48.50 RHO-points
29 58.50 70.50 36.50 48.50 RHO-points
30 70.50 82.50 36.50 48.50 RHO-points
31 82.50 91.50 36.50 48.50 RHO-points
32 0.50 10.50 48.50 60.50 RHO-points
33 10.50 22.50 48.50 60.50 RHO-points
34 22.50 34.50 48.50 60.50 RHO-points
35 34.50 46.50 48.50 60.50 RHO-points
36 46.50 58.50 48.50 60.50 RHO-points
37 58.50 70.50 48.50 60.50 RHO-points
38 70.50 82.50 48.50 60.50 RHO-points
39 82.50 91.50 48.50 60.50 RHO-points
40 0.50 10.50 60.50 72.50 RHO-points
41 10.50 22.50 60.50 72.50 RHO-points
42 22.50 34.50 60.50 72.50 RHO-points
43 34.50 46.50 60.50 72.50 RHO-points
44 46.50 58.50 60.50 72.50 RHO-points
45 58.50 70.50 60.50 72.50 RHO-points
46 70.50 82.50 60.50 72.50 RHO-points
47 82.50 91.50 60.50 72.50 RHO-points
48 0.50 10.50 72.50 84.50 RHO-points
49 10.50 22.50 72.50 84.50 RHO-points
50 22.50 34.50 72.50 84.50 RHO-points
51 34.50 46.50 72.50 84.50 RHO-points
52 46.50 58.50 72.50 84.50 RHO-points
53 58.50 70.50 72.50 84.50 RHO-points
54 70.50 82.50 72.50 84.50 RHO-points
55 82.50 91.50 72.50 84.50 RHO-points
56 0.50 10.50 84.50 95.50 RHO-points
57 10.50 22.50 84.50 95.50 RHO-points
58 22.50 34.50 84.50 95.50 RHO-points
59 34.50 46.50 84.50 95.50 RHO-points
60 46.50 58.50 84.50 95.50 RHO-points
61 58.50 70.50 84.50 95.50 RHO-points
62 70.50 82.50 84.50 95.50 RHO-points
63 82.50 91.50 84.50 95.50 RHO-points
0 1.00 10.50 0.50 12.50 U-points
1 10.50 22.50 0.50 12.50 U-points
2 22.50 34.50 0.50 12.50 U-points
3 34.50 46.50 0.50 12.50 U-points
4 46.50 58.50 0.50 12.50 U-points
5 58.50 70.50 0.50 12.50 U-points
6 70.50 82.50 0.50 12.50 U-points
7 82.50 91.00 0.50 12.50 U-points
8 1.00 10.50 12.50 24.50 U-points
9 10.50 22.50 12.50 24.50 U-points
10 22.50 34.50 12.50 24.50 U-points
11 34.50 46.50 12.50 24.50 U-points
12 46.50 58.50 12.50 24.50 U-points
13 58.50 70.50 12.50 24.50 U-points
14 70.50 82.50 12.50 24.50 U-points
15 82.50 91.00 12.50 24.50 U-points
16 1.00 10.50 24.50 36.50 U-points
17 10.50 22.50 24.50 36.50 U-points
18 22.50 34.50 24.50 36.50 U-points
19 34.50 46.50 24.50 36.50 U-points
20 46.50 58.50 24.50 36.50 U-points
21 58.50 70.50 24.50 36.50 U-points
22 70.50 82.50 24.50 36.50 U-points
23 82.50 91.00 24.50 36.50 U-points
24 1.00 10.50 36.50 48.50 U-points
25 10.50 22.50 36.50 48.50 U-points
26 22.50 34.50 36.50 48.50 U-points
27 34.50 46.50 36.50 48.50 U-points
28 46.50 58.50 36.50 48.50 U-points
29 58.50 70.50 36.50 48.50 U-points
30 70.50 82.50 36.50 48.50 U-points
31 82.50 91.00 36.50 48.50 U-points
32 1.00 10.50 48.50 60.50 U-points
33 10.50 22.50 48.50 60.50 U-points
34 22.50 34.50 48.50 60.50 U-points
35 34.50 46.50 48.50 60.50 U-points
36 46.50 58.50 48.50 60.50 U-points
37 58.50 70.50 48.50 60.50 U-points
38 70.50 82.50 48.50 60.50 U-points
39 82.50 91.00 48.50 60.50 U-points
40 1.00 10.50 60.50 72.50 U-points
41 10.50 22.50 60.50 72.50 U-points
42 22.50 34.50 60.50 72.50 U-points
43 34.50 46.50 60.50 72.50 U-points
44 46.50 58.50 60.50 72.50 U-points
45 58.50 70.50 60.50 72.50 U-points
46 70.50 82.50 60.50 72.50 U-points
47 82.50 91.00 60.50 72.50 U-points
48 1.00 10.50 72.50 84.50 U-points
49 10.50 22.50 72.50 84.50 U-points
50 22.50 34.50 72.50 84.50 U-points
51 34.50 46.50 72.50 84.50 U-points
52 46.50 58.50 72.50 84.50 U-points
53 58.50 70.50 72.50 84.50 U-points
54 70.50 82.50 72.50 84.50 U-points
55 82.50 91.00 72.50 84.50 U-points
56 1.00 10.50 84.50 95.50 U-points
57 10.50 22.50 84.50 95.50 U-points
58 22.50 34.50 84.50 95.50 U-points
59 34.50 46.50 84.50 95.50 U-points
60 46.50 58.50 84.50 95.50 U-points
61 58.50 70.50 84.50 95.50 U-points
62 70.50 82.50 84.50 95.50 U-points
63 82.50 91.00 84.50 95.50 U-points
0 0.50 10.50 1.00 12.50 V-points
1 10.50 22.50 1.00 12.50 V-points
2 22.50 34.50 1.00 12.50 V-points
3 34.50 46.50 1.00 12.50 V-points
4 46.50 58.50 1.00 12.50 V-points
5 58.50 70.50 1.00 12.50 V-points
6 70.50 82.50 1.00 12.50 V-points
7 82.50 91.50 1.00 12.50 V-points
8 0.50 10.50 12.50 24.50 V-points
9 10.50 22.50 12.50 24.50 V-points
10 22.50 34.50 12.50 24.50 V-points
11 34.50 46.50 12.50 24.50 V-points
12 46.50 58.50 12.50 24.50 V-points
13 58.50 70.50 12.50 24.50 V-points
14 70.50 82.50 12.50 24.50 V-points
15 82.50 91.50 12.50 24.50 V-points
16 0.50 10.50 24.50 36.50 V-points
17 10.50 22.50 24.50 36.50 V-points
18 22.50 34.50 24.50 36.50 V-points
19 34.50 46.50 24.50 36.50 V-points
20 46.50 58.50 24.50 36.50 V-points
21 58.50 70.50 24.50 36.50 V-points
22 70.50 82.50 24.50 36.50 V-points
23 82.50 91.50 24.50 36.50 V-points
24 0.50 10.50 36.50 48.50 V-points
25 10.50 22.50 36.50 48.50 V-points
26 22.50 34.50 36.50 48.50 V-points
27 34.50 46.50 36.50 48.50 V-points
28 46.50 58.50 36.50 48.50 V-points
29 58.50 70.50 36.50 48.50 V-points
30 70.50 82.50 36.50 48.50 V-points
31 82.50 91.50 36.50 48.50 V-points
32 0.50 10.50 48.50 60.50 V-points
33 10.50 22.50 48.50 60.50 V-points
34 22.50 34.50 48.50 60.50 V-points
35 34.50 46.50 48.50 60.50 V-points
36 46.50 58.50 48.50 60.50 V-points
37 58.50 70.50 48.50 60.50 V-points
38 70.50 82.50 48.50 60.50 V-points
39 82.50 91.50 48.50 60.50 V-points
40 0.50 10.50 60.50 72.50 V-points
41 10.50 22.50 60.50 72.50 V-points
42 22.50 34.50 60.50 72.50 V-points
43 34.50 46.50 60.50 72.50 V-points
44 46.50 58.50 60.50 72.50 V-points
45 58.50 70.50 60.50 72.50 V-points
46 70.50 82.50 60.50 72.50 V-points
47 82.50 91.50 60.50 72.50 V-points
48 0.50 10.50 72.50 84.50 V-points
49 10.50 22.50 72.50 84.50 V-points
50 22.50 34.50 72.50 84.50 V-points
51 34.50 46.50 72.50 84.50 V-points
52 46.50 58.50 72.50 84.50 V-points
53 58.50 70.50 72.50 84.50 V-points
54 70.50 82.50 72.50 84.50 V-points
55 82.50 91.50 72.50 84.50 V-points
56 0.50 10.50 84.50 95.00 V-points
57 10.50 22.50 84.50 95.00 V-points
58 22.50 34.50 84.50 95.00 V-points
59 34.50 46.50 84.50 95.00 V-points
60 46.50 58.50 84.50 95.00 V-points
61 58.50 70.50 84.50 95.00 V-points
62 70.50 82.50 84.50 95.00 V-points
63 82.50 91.50 84.50 95.00 V-points
HaloSizeI(1) = 48
HaloSizeJ(1) = 48
TileSide(1) = 18
TileSize(1) = 324
zeta 1 Closed Chapman Imp Chapman Imp Closed
u 1 Closed Rad + Nud Rad + Nud Closed
v 1 Closed Rad + Nud Rad + Nud Closed
TEST South China Sea model
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
[node53:mpi_rank_34][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpi_rank_33][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpispawn_2][readline] Unexpected End-Of-File on file descriptor 5. MPI process died?
[node53:mpispawn_2][mtpmi_processops] Error while reading PMI socket. MPI process died?
[node53:mpi_rank_36][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpi_rank_38][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpi_rank_37][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpi_rank_39][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpi_rank_40][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpi_rank_43][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpi_rank_41][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpi_rank_42][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpi_rank_44][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpi_rank_45][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpi_rank_46][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpi_rank_35][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpi_rank_47][error_sighandler] Caught error: Segmentation fault (signal 11)
[node53:mpispawn_2][child_handler] MPI process (rank: 38, pid: 31092) terminated with signal 11 -> abort job
[node51:mpirun_rsh][process_mpispawn_connection] mpispawn_2 from node node53 aborted: Error while reading a PMI socket (4)
[node51:mpispawn_0][read_size] Unexpected End-Of-File on file descriptor 25. MPI process died?
[node51:mpispawn_0][handle_mt_peer] Error while reading PMI socket. MPI process died?
real 5.08
user 0.06
sys 0.03
+ exit 0
[node52:mpispawn_1][read_size] Unexpected End-Of-File on file descriptor 21. MPI process died?
[node52:mpispawn_1][handle_mt_peer] Error while reading PMI socket. MPI process died?
[node54:mpispawn_3][read_size] Unexpected End-Of-File on file descriptor 21. MPI process died?
[node54:mpispawn_3][handle_mt_peer] Error while reading PMI socket. MPI process died?
what's more .I have a Problem.why my temp in August will become more high,such as 100.can you give some suggestions to modify my roms.
Thank you a lot!
error_sighandler
error_sighandler
- My area
- temp1.jpg (38.03 KiB) Viewed 2619 times
Re: error_sighandler
I wrote about segmentation faults here. ROMS allocates big arrays right after printing the cppdefs.
The run with T=100 must be some other run? Unless that's your initial condition?
Thanks a lot,kate!kate wrote:I wrote about segmentation faults here. ROMS allocates big arrays right after printing the cppdefs.
