Computing problem!
langlangxie
Computing problem!
#1 Unread post by langlangxie »
Hi,I have a problem in computing ROMS.
This is :
WRT_AVG - error while writing variable: zeta
into averages NetCDF file for time record: 1
Elapsed CPU time (seconds):
Node # 0 CPU: 1009.411
Node # 4 CPU: 1009.387 ROMS/TOMS - Output NetCDF summary for Grid 01:
Node # 5 CPU: 1009.386 Node # 10 CPU: 1009.406 Node # 3 CPU: 1009.394 Node # 1 CPU: 1009.411 Node # 8 CPU: 1009.410 Node # 12 CPU: 1009.410 Node # 9 CPU: 1009.402 Node # 2 CPU: 1009.394 Node # 11 CPU: 1009.405 Node # 14 CPU: 1009.402 Node # 7 CPU: 1009.387 Node # 6 CPU: 1009.387 Node # 13 CPU: 1009.409 Node # 15 CPU: 1009.400
number of time records written in AVERAGE file = 00000001
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/TOMS - Output error ............ exit_flag: 3
REASON: NetCDF: Numeric conversion not representable
Can you help me ?
Re: Computing problem!
Have you set NINFO to 1? If you do, you will get a diagnostics report each timestep. If the model is blowing up, you would then see it there first. If NINFO is large, you can get a NaN and ROMS will keep running. I believe you have NaN or some such number in your zeta field, which is why it won't write to the NetCDF file.
langlangxie
#3 Unread post by langlangxie »
kate wrote:Have you set NINFO to 1? If you do, you will get a diagnostics report each timestep. If the model is blowing up, you would then see it there first. If NINFO is large, you can get a NaN and ROMS will keep running. I believe you have NaN or some such number in your zeta field, which is why it won't write to the NetCDF file.
hi,kate.
My NINFO is 51840,and I want to understand how to make the NINFO,can you give some your understanding.
Thank you very much!
NINFO is set in your ocean_xx.in file. Try setting it to 1. If you can get things to run stably, then you can set it to a large value again if you like. I always leave it at 1 and put up with the extra output.
langlangxie
#5 Unread post by langlangxie »
kate wrote:NINFO is set in your ocean_xx.in file. Try setting it to 1. If you can get things to run stably, then you can set it to a large value again if you like. I always leave it at 1 and put up with the extra output.
Thanks a lot. Thanks a million!
langlangxie
#6 Unread post by langlangxie »
Hi kate
Can you tell me how to find zeta? Is there zeta in clim.nc or ini.nc? Then how can i get the value of zeta?
Thank you!
#7 Unread post by kate »
Zeta is the free surface elevation and it evolves during a model run. It would be in your ini file and also in the restart file, plus whatever other outputs you've asked for. I suggest ncview to look at the netcdf input and output files.
langlangxie
#8 Unread post by langlangxie »
kate wrote:Zeta is the free surface elevation and it evolves during a model run. It would be in your ini file and also in the restart file, plus whatever other outputs you've asked for. I suggest ncview to look at the netcdf input and output files.
Thanks for your help! Firstly ,I got a error is "WRT_AVG - error while writing variable: zeta into averages NetCDF file for time record: 1",this time my NINFO=51840. Then I make the NINFO to 5,the error is " WRT_AVG - error while writing variable: zeta into averages NetCDF file for time record: 5",why is the error happening.What is the best value of NINFO?
And I ncview my netcdf input and output files,there is zeta and ssh.I think my zeta is realy.
#9 Unread post by kate »
The best value for NINFO is 1 (as above). That way, ROMS will check for NaN and other such values every time-step. Your model is going bad and you need to figure out where and why.
langlangxie
#10 Unread post by langlangxie »
kate wrote:The best value for NINFO is 1 (as above). That way, ROMS will check for NaN and other such values every time-step. Your model is going bad and you need to figure out where and why.
Thanks!
I am finding my errors in my ROMS.can you give me some directions of going bad?
Today,I get a result ,and I get 20 avg files,likes "creating average file, Grid 01: /public/userspace/langlangxie/south/clim_avg_M_d8_0020.nc",why it is 20?
#11 Unread post by kate »
Are you changing NAVG as well as NINFO? You should read up on these parameters - they are described briefly at the bottom of the ocean.in file.
As for ROMS blowing up, there are a few tips on the wiki.
langlangxie
#12 Unread post by langlangxie »
kate wrote:Are you changing NAVG as well as NINFO? You should read up on these parameters - they are described briefly at the bottom of the ocean.in file.
Dear kate
Firstly,thanks again!
My NAVG is not equal to NINFO.NAVG=4320,and NINFO=51840.
When I make as follows: NTIMES == 51840 !1 years
DT == 60.0d0
NDTFAST == 600
I get a error: LBC_GETATT - error while reading global attribute: NLM_LBC
in restart file: scs_ini.nc
call from: get_state.F
Probably global attribute was not found ...
restart file needs to be generated by ROMS version 3.6 or higher
Alternatively, you may use NO_LBC_ATT at your own risk!
When DT=600,ROMS can running stable,but I make DT=60,there is error above.
Can you help me solve my problem!
Thanks!
#13 Unread post by kate »
I told you to try NINFO=1.
With dt=60 and that many steps, you are asking it to run for 36 days, saving an averages file every 3 days. You shouldn't get 20 averages files, just 12. Right?
I've never heard of anyone using ndtfast as large as 600.
You must have told it that your initial file is a restart file. What is your NRREC?
langlangxie
#14 Unread post by langlangxie »
kate wrote:I told you to try NINFO=1.
I make NINFO=1,it can running stable.And I get 12 averages.
Thanks!
