ROMS can't be calculated,help me!
langlangxie
#1 Unread post by langlangxie »
Kindhearted persons:
I already have some files,such as .ini,.grd,.clm,.frc and so on.Now I want to calculate my ROMS(It is just upwelling example),but it can't be calculated.I don't know How to modify the file(such upwelling.h and ocean_upwelling.in).
Thanks for everyone help!
Re: ROMS can't be calculated,help me!
Could you please be more specific about what you are trying to do and what is going wrong? You don't need all those files for the upwelling case. Have you looked through the documentation on the wiki? There is also a manual.
langlangxie
#3 Unread post by langlangxie »
kate wrote:Could you please be more specific about what you are trying to do and what is going wrong? You don't need all those files for the upwelling case. Have you looked through the documentation on the wiki? There is also a manual.
Thanks!
I am now doing a model of the South China Sea in this case on the basis of upwelling.I have used agrifroms to make ​​.ini,.frc, .grd and other documents , and then go into my own calculation Projects.
Thank for your help!
langlangxie
#4 Unread post by langlangxie »
Thanks!
when it is runing ,rapidly stopping.Then ,the problem is :
BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= EXIT CODE: 256
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
Thanks again!
#5 Unread post by kate »
Hmm, I don't know that one. Here's what I wrote about ROMS blowing up.
langlangxie
#6 Unread post by langlangxie »
kate wrote:Hmm, I don't know that one. Here's what I wrote about ROMS blowing up.
Thanks your help!
