This is my first time compiling the Upwelling test case. I cannot figure out how to correct the locale variable warnings and I cannot find the netcdf.mod file. The compiler looks for it in /usr/local/include, the contents of which I have printed below, but it is not there nor is it in the netcdf file that was created in ~/src directory when I installed it.
Can anyone help me correct these issues?
Thanks!
-Connor
Macasaurus-Rex:include Connor$ cd ~/ROMS/Projects/Upwelling
Macasaurus-Rex:Upwelling Connor$ ./build.bash
rm -f -r core *.ipo /Users/Connor/ROMS/Projects/Upwelling/Build /Users/Connor/make_macros.mk
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LC_ALL = "en_US.UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
makefile:238: INCLUDING FILE /Users/Connor/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
svnversion: warning: cannot set LC_CTYPE locale
svnversion: warning: environment variable LC_ALL is en_US.UTF-8
svnversion: warning: please check that your locale name is correct
cp -f /usr/local/include/netcdf.mod /Users/Connor/ROMS/Projects/Upwelling/Build
cp: /usr/local/include/netcdf.mod: No such file or directory
make: *** No rule to make target `/Users/Connor/ROMS/Projects/Upwelling/Build/MakeDepend', needed by `all'. Stop.
Macasaurus-Rex:Upwelling Connor$ cd ~
Macasaurus-Rex:~ Connor$ cd ../../usr/local/include
Macasaurus-Rex:include Connor$ ls
ecpg_config.h ecpgtype.h libpq pg_config.h pgtypes_date.h pgtypes_timestamp.h sqlca.h
ecpg_informix.h gnumake.h libpq-events.h pg_config_ext.h pgtypes_error.h postgres_ext.h sqlda-compat.h
ecpgerrno.h informix libpq-fe.h pg_config_manual.h pgtypes_interval.h server sqlda-native.h
ecpglib.h internal node pg_config_os.h pgtypes_numeric.h sql3types.h sqlda.h
Macasaurus-Rex:include Connor$ cd ~/src/netcdf-3.6.3
Macasaurus-Rex:netcdf-3.6.3 Connor$ ls
COPYRIGHT Makefile.in a.out.dSYM config.guess config.status cxx examples libsrc man nc_test4 nctest
INSTALL README acinclude.m4 config.h config.sub cxx4 f90 libsrc4 man4 ncdap.m4 nf_test
Makefile RELEASE_NOTES aclocal.m4 config.h.in configure depcomp fortran libtool missing ncdump stamp-h1
Makefile.am VERSION compile config.log configure.ac dods.m4 install-sh ltmain.sh nc_test ncgen win32
