We have been working on optimizing ROMS benchmark application performance.
This was primarily targeting the Intel Xeon and Intel Xeon Phi architectures but there are some optimizations that should benefit all architectures.
Here is one.
Application and Workload used
Application: benchmark built from ROMS 3.7 svn version 709
Workload: https://www.myroms.org/svn/src/tags/rom ... chmark3.in.
From the profile of benchmark application on this workload, the function that took the longest time is lmd_skpp_tile. Though most of the loops in ROMS iterate fastest down a column which is cache efficient, there is one loop in lmd_skpp_tile where the innermost loop iterates over k (depth). This is the loop to compute the critical function (FC) for bulk Richardson number (BRN).
This loop needs to iterate over k (N(ng),1,-1) since it needs to find for each (i,j), the minimum depth at which the BRN achieves critical value. This can be made more cache efficient by using a vector, depth (depth(Istr,Iend)), instead of the scalar depth and interchanging the i and k loops.
Here is the original code:
! Compute turbulent velocity scales for momentum (wm) and tracers (ws).
! Then, compute critical function (FC) for bulk Richardson number.
DO i=Istr,Iend
FC(i,N(ng))=0.0_r8
DO k=N(ng),1,-1
depth=z_w(i,j,N(ng))-z_w(i,j,k-1)
IF (Bflux(i,j,k-1).lt.0.0_r8) THEN
sigma=MIN(sl_dpth(i,j),depth)
ELSE
sigma=depth
DO k = 1, N(ng)
DO i = Istr, Iend
depth_vec(i, k) = z_w(i, j, N(ng))-z_w(i, j, k-1)
DO k = N(ng),1,-1
DO i = Istr, Iend
sigma = depth_vec(i, k)
IF ((Bflux(i, j, k-1) .LT. 0.0_r8) .AND. &
& (sl_dpth(i, j) .LT. depth_vec(i, k))) THEN
sigma = sl_dpth(i, j)
Please write to one of us (emails given below), and we can share more details about the changes.
-indraneil.m.gokhale@intel.com
-gopal.bhaskaran@tcs.com
