I wonder if somebody using a Windows XP computer could please send me her or his start file, please. I mean, I haven’t been able to fix my problems with the make_grid stage… I believe these problems are related to my ‘start’ file and/or to the mexnc file. I think I have the right mex file though… Every time I try to get through the make_grid stage I always get the same error (please see below if interested)
Thank you very much.
Juan Fernandez
>> make_grid
Making the grid: ../Run/ROMS_FILES/roms_grd.nc
Title: Benguela Test Model
Resolution: 1/3 deg
Create the grid file...
LLm = 23
MMm = 31
Fill the grid file...
Compute the metrics...
??? Error: File: subsref.m Line: 128 Column: 9
"subs" previously appeared to be used as a function, conflicting with its use here as the name of a variable.
A possible cause of this error is that you forgot to initialize the
variable, or you have initialized it implicitly using load or eval.
Error in ==> netcdf.subsref at 52
result = subsref(result, s);
Error in ==> get_metrics at 35
latu=nc{'lat_u'}(:);
Error in ==> make_grid at 95
[pm,pn,dndx,dmde]=get_metrics(grdname);”
