stdout
redhat007
stdout
#1 Unread post by redhat007 »
i am using 13 files as roms forces (sms, shflux,swrad,Tair, Qair,Pair,wind,rain, cloud, sensible,latent,lwrad, river). But in stdout file there are some parts which show just five of them . Some thing like this:
GET_NGFLD   - river runoff mass transport,               t =    31 00:00:00
                   (Rec=0002, Index=1, File: rivers_force_08.nc)
                   (Tmin=          0.0000 Tmax=        335.0000)
                   (Min =  8.10000000E+00 Max =  1.80850150E+02)
    GET_NGFLD   - river runoff potential temperature,        t =    31 00:00:00
                   (Min =  0.00000000E+00 Max =  5.70000000E+00)
    GET_NGFLD   - river runoff salinity,                     t =    31 00:00:00
    GET_2DFLD   - surface u-momentum stress,                 t =     0 04:30:00
                   (Rec=0002, Index=2, File: CS_sms2_era_08.nc)
                   (Tmin=          0.0625 Tmax=        365.9375)
                   (Min = -8.81097026E-05 Max =  1.11008348E-04)
    GET_2DFLD   - surface v-momentum stress,                 t =     0 04:30:00
                   (Min = -9.29573630E-05 Max =  1.26521028E-04)
    GET_2DFLD   - surface net heat flux,                     t =     0 04:30:00
                   (Rec=0002, Index=2, File: CS_shflux2_era_08.nc)
                   (Min = -6.13341848E-05 Max =  6.77839475E-06)
    GET_2DFLD   - surface net freswater flux, (E-P),         t =     0 04:30:00
                   (Rec=0002, Index=2, File: CS_swflux2_era_08.nc)
                   (Min = -2.98790427E-07 Max =  5.04688906E-08)
does it mean that other force files have not been applied by roms :?: ?
my header file is:
#define ROMS_MODEL
#define SPLINES /*activate parabolic splines reconstruction */
#undef WET_DRY
#define OUT_DOUBLE /*writing double precision output fields*/
/* advection, dissipation, pressure grad, etc. */
#define DJ_GRADPS /*splines density Jacobian (Shchepetkin, 2000) */
#define UV_ADV /*turn on advection terms*/
#define UV_COR /*turn on Coriolis term*/
#undef UV_SADVECTION
/*tracer advection*/
#define TS_U3HADVECTION /*3rd-order upstream horiz. advection*/
#define TS_C4VADVECTION
!#define TS_MPDATA
#define UV_QDRAG /*quardatic bottom friction*/
#define UV_VIS2 /*harmonic horizantal mixixng*/
#define MIX_S_UV /*4th-order centered vertical advection */
#define TS_DIF2 /*tracer harmonic horizontal mixing */
#define MIX_S_TS
/* Boundary Conditions */
#define EASTERN_WALL
#define WESTERN_WALL
#define NORTHERN_WALL
#define SOUTHERN_WALL
/* output stuff */
#define AVERAGES /*writing out time-averaged data */
#define DIAGNOSTICS_UV /*writing out momentum diagnostics */
#define DIAGNOSTICS_TS /*writing out tracer diagnostics */
/* roms quirks */
#undef ANA_GRID
#undef ANA_INITIAL
#undef ANA_SMFLUX
# undef ANA_STFLUX
# undef ANA_SSFLUX
# define ANA_BTFLUX
# define ANA_BSFLUX
/*river*/
#define UV_PSOURCE
#define TS_PSOURCE
#undef Q_PSOURCE
/* vertical mixing */
#define GLS_MIXING /*Generic Length-Scale mixing */
#if defined GLS_MIXING
# undef CANUTO_A
#else
# define ANA_VMIX
#ifdef PERFECT_RESTART
# undef AVERAGES
# undef DIAGNOSTICS_BIO
# undef DIAGNOSTICS_TS
# undef DIAGNOSTICS_UV
# define OUT_DOUBLE
Best
redhat
Re: stdout
Yes, that's right. You didn't #define BULK_FLUXES so it doesn't need Tair and friends and therefore doesn't read them. If you provide the wind stress and heat/salt flux, you don't need to compute them from atmospheric fields.
redhat007
Re: stdout
#3 Unread post by redhat007 »
Dear kate
thanks.
Are
Tair and friends
: Pair, Qair , rain and cloud and
atmospheric fields
: latent, sensible, solar and thermal radiation?
With regard that Bulk flux equations are empirical and each sea needs its own formulation, Which one it better: using #define Bulk flux or providing wind stress, fresh water flux and heat flux fields directly?
Cheers
redhat
Re: stdout
Yes, that's the list of atmospheric fields, though I'm reading albedo and not clouds. It depends. Because the heat fluxes are sensitive to SST, I believe one should compute them based on your local SST or at the very least include the dQdSST term when reading in fluxes.
That said, I have colleagues who don't like the default bulk_flux routine and prefer the algorithm used in CESM. We therefore have an alternate CCSM_FLUXES option which happens to include the surface ocean currents in its calculation.
redhat007
Re: stdout
#5 Unread post by redhat007 »
Many thanks.
you mean that dQdsst (surface net heat flux sensitivity to sst ) should be used instead of shflux or both of them should be used.
Also would you please if you know any good way to calculate dQdsst, tell it to me.
Thanks again
cheers
redhat
Re: stdout
#6 Unread post by kate »
The ROMS flag QCORRECTION enables this code:
          stflx(i,j,itemp)=stflx(i,j,itemp)+                            &
     &                     dqdt(i,j)*(t(i,j,N(ng),nrhs,itemp)-sst(i,j))
You need the three fields stflx(itemp), dqdt (dQdSST) and sst (the SST used when computing stflx(itemp)).
Re: stdout
#7 Unread post by wilkin »
See the paper:
B. Barnier, L. Siefridt, P. Marchesiello, Thermal forcing for a global ocean circulation model using a three-year climatology of ECMWF analyses, J. Marine Sys., 2005, 6, 363-380
for one approach toward setting appropriate values for dQdSST.
You could adapt that method to code the algorithm in Functionals/ana_dqdsst.h for typical values of SST, Tair, rho_atmosphere, wind speed and humidity in your region of interest, or write time and space evolving dqdsst to a forcing netcdf file from your other forcing data. It's up to you how to do it.
Among the IRD Matlab Roms_tools http://www.romsagrif.org/index.php/download there is a file get_dqdsst.m that does the calculation in Matlab.
redhat007
Re: stdout
#8 Unread post by redhat007 »
Dear
thanks for good information
i am really eager to know if surface net heat flux, surface fresh water flux and wind stress (as well as river , if there is) are enough forces in Roms model?
Cheers
redhat
Re: stdout
#9 Unread post by kate »
If you turn on SOLAR_SOURCE, ROMS will also want incoming shortwave radiation for solar heating below the surface.
redhat007
Re: stdout
#10 Unread post by redhat007 »
Dear
i make decision to use #define BULK_FLUXES .
Same setting with same initial file which used for model with out #define BULK_FLUXES ( run with out problem) have been used but with Pair, Tair,Qair,rain,cloud,sward and lwrad and river as a force files. But new model BLOW UP just after 9 min. also when i use #define LONGWAVE and #define SHORTWAVE instead of lwrad and swrad, respectively, this blow up happened again.
In restart file current speed is less that 2m/s and tracers are in correct limit. But just zeta is out of range (about 1.2 m in some region).
Would you please tell me what s problem?
 Node #  0 (pid=   17197) is active.
 Model Input Parameters:  ROMS/TOMS version 3.4
                          Monday - June 16, 2014 -  1:15:35 PM
 Node #  1 (pid=   17198) is active.
 Operating system : Linux
 CPU/hardware     : i686
 Compiler system  : gfortran
 Compiler command : /usr/lib/mpich2/bin/mpif90
 Compiler flags   : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
 Input Script  : ocean_rip_current.in
 SVN Root URL  :
 SVN Revision  : 791M
 Local Root    : /home/COAWST
 Header Dir    : /home/COAWST/project/p5_07022
 Header file   : rip_current.h
 Analytical Dir: /home/COAWST/project/Roms_only/p5_07022
 Resolution, Grid 01: 0194x0344x032,  Parallel Nodes:   2,  Tiling: 001x002
      15360  ntimes          Number of timesteps for 3-D equations.
     90.000  dt              Timestep size (s) for 3-D equations.
         30  ndtfast         Number of timesteps for 2-D equations between
          1  ERstr           Starting ensemble/perturbation run number.
          1  ERend           Ending ensemble/perturbation run number.
          0  nrrec           Number of restart records to read from disk.
          T  LcycleRST       Switch to recycle time-records in restart file.
        960  nRST            Number of timesteps between the writing of data
                               into restart fields.
          1  ninfo           Number of timesteps between print of information
                               to standard output.
          T  ldefout         Switch to create a new output NetCDF file(s).
        480  nHIS            Number of timesteps between the writing fields
                               into history file.
          1  ntsAVG          Starting timestep for the accumulation of output
                               time-averaged data.
       9600  nAVG            Number of timesteps between the writing of
          1  ntsDIA          Starting timestep for the accumulation of output
      28800  nDIA            Number of timesteps between the writing of
 1.0000E+02  nl_tnu2(01)     NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for tracer 01: temp
 1.0000E+02  nl_tnu2(02)     NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for tracer 02: salt
 1.0000E+01  nl_visc2        NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for momentum.
 5.0000E-06  Akt_bak(01)     Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akt_bak(02)     Background vertical mixing coefficient (m2/s)
                               for tracer 02: salt
 1.0000E-05  Akv_bak         Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akk_bak         Background vertical mixing coefficient (m2/s)
                               for turbulent energy.
 5.0000E-06  Akp_bak         Background vertical mixing coefficient (m2/s)
      3.000  gls_p           GLS stability exponent.
      1.500  gls_m           GLS turbulent kinetic energy exponent.
     -1.000  gls_n           GLS turbulent length scale exponent.
 7.6000E-06  gls_Kmin        GLS minimum value of turbulent kinetic energy.
 1.0000E-12  gls_Pmin        GLS minimum value of dissipation.
 5.4770E-01  gls_cmu0        GLS stability coefficient.
 1.4400E+00  gls_c1          GLS shear production coefficient.
 1.9200E+00  gls_c2          GLS dissipation coefficient.
-4.0000E-01  gls_c3m         GLS stable buoyancy production coefficient.
 1.0000E+00  gls_c3p         GLS unstable buoyancy production coefficient.
 1.0000E+00  gls_sigk        GLS constant Schmidt number for TKE.
 1.3000E+00  gls_sigp        GLS constant Schmidt number for PSI.
   1400.000  charnok_alpha   Charnok factor for Zos calculation.
      0.500  zos_hsig_alpha  Factor for Zos calculation using Hsig(Awave).
      0.020  sz_alpha        Factor for Wave dissipation surface tke flux .
    100.000  crgban_cw       Factor for Craig/Banner surface tke flux.
 2.0000E-04  rdrg            Linear bottom drag coefficient (m/s).
 3.3000E-03  rdrg2           Quadratic bottom drag coefficient.
 2.0000E-02  Zob             Bottom roughness (m).
 2.0000E-02  Zos             Surface roughness (m).
 2.0000E+00  blk_ZQ          Height (m) of surface air humidity measurement.
 2.0000E+00  blk_ZT          Height (m) of surface air temperature measurement.
 1.0000E+01  blk_ZW          Height (m) of surface winds measurement.
          1  lmd_Jwt         Jerlov water type.
          2  Vtransform      S-coordinate transformation equation.
          4  Vstretching     S-coordinate stretching function.
 8.0000E+00  theta_s         S-coordinate surface control parameter.
 4.0000E-01  theta_b         S-coordinate bottom  control parameter.
      6.000  Tcline          S-coordinate surface/bottom layer width (m) used
   1025.000  rho0            Mean density (kg/m3) for Boussinesq approximation.
     53.000  dstart          Time-stamp assigned to model initialization (days).
20070101.00  time_ref        Reference time for units attribute (yyyymmdd.dd)
 0.0000E+00  Tnudg(01)       Nudging/relaxation time scale (days)
 0.0000E+00  Tnudg(02)       Nudging/relaxation time scale (days)
                               for tracer 02: salt
 0.0000E+00  Znudg           Nudging/relaxation time scale (days)
 0.0000E+00  M2nudg          Nudging/relaxation time scale (days)
 0.0000E+00  M3nudg          Nudging/relaxation time scale (days)
                               for 3D momentum.
 0.0000E+00  obcfac          Factor between passive and active
     10.000  T0              Background potential temperature (C) constant.
     35.000  S0              Background salinity (PSU) constant.
      1.000  gamma2          Slipperiness variable: free-slip (1.0) or
          T  LtracerSrc(01)  Processing point sources/Sink on tracer 01: temp
          T  LtracerSrc(02)  Processing point sources/Sink on tracer 02: salt
          T  Hout(idFsur)    Write out free-surface.
          T  Hout(idUbar)    Write out 2D U-momentum component.
          T  Hout(idVbar)    Write out 2D V-momentum component.
          T  Hout(idUvel)    Write out 3D U-momentum component.
          T  Hout(idVvel)    Write out 3D V-momentum component.
          T  Hout(idWvel)    Write out W-momentum component.
          T  Hout(idOvel)    Write out omega vertical velocity.
          T  Hout(idTvar)    Write out tracer 01: temp
          T  Hout(idTvar)    Write out tracer 02: salt
          T  Hout(idUsms)    Write out surface U-momentum stress.
          T  Hout(idVsms)    Write out surface V-momentum stress.
          T  Hout(idUbms)    Write out bottom U-momentum stress.
          T  Hout(idVbms)    Write out bottom V-momentum stress.
          T  Hout(idVvis)    Write out vertical viscosity coefficient.
          T  Hout(idMtke)    Write out turbulent kinetic energy.
          T  Hout(idMtls)    Write out turbulent generic length-scale.
             Output Restart File:  ocean_rip_current_rst.nc
             Output History File:  ocean_rip_current_his.nc
            Output Averages File:  ocean_rip_current_avg.nc
         Output Diagnostics File:  ocean_rip_current_dia.nc
                 Input Grid File:  /home/grid/grid_3.nc
    Input Nonlinear Initial File:  /home/clim-init/initial_feb_23.nc
           Input Forcing File 01:  /home/cloud2_era_07.nc
           Input Forcing File 02:  /home/Pair2_era_07.nc
           Input Forcing File 03:  /home/Qair2_era_07.nc
           Input Forcing File 04:  /home/Tair2_era_07.nc
           Input Forcing File 05:  /home/uwnd2_era_07.nc
           Input Forcing File 06:  /home/vwnd2_era_07.nc
           Input Forcing File 07:  /home/rain2_era_07.nc
           Input Forcing File 08:  /home/lwrad2_era_07.nc
           Input Forcing File 09:  /home/swrad2_era_07.nc
           Input Forcing File 10:  /home/rivers_force_07.nc
 Tile partition information for Grid 01:  0194x0344x0032  tiling: 001x002
        0        1      194        1      172  1067776
        1        1      194      173      344  1067776
   (interior points only)
        0     0.50   194.50     0.50   172.50  RHO-points
        1     0.50   194.50   172.50   344.50  RHO-points
        0     1.00   194.00     0.50   172.50    U-points
        1     1.00   194.00   172.50   344.50    U-points
        0     0.50   194.50     1.00   172.50    V-points
        1     0.50   194.50   172.50   344.00    V-points
               HaloSizeI(1) =     410
               HaloSizeJ(1) =     368
                TileSide(1) =     199
                TileSize(1) =   35422
 RIPCURRENT          Rip Current from Haas and Warner
 AVERAGES            Writing out time-averaged fields.
 BULK_FLUXES         Surface bulk fluxes parametererization.
 COOL_SKIN           Surface cool skin correction.
 DIAGNOSTICS_TS      Computing and writing tracer diagnostic terms.
 DIAGNOSTICS_UV      Computing and writing momentum diagnostic terms.
 EASTERN_WALL        Wall boundary at Eastern edge.
 EMINUSP             Compute Salt Flux using E-P.
 GLS_MIXING          Generic Length-Scale turbulence closure.
 MIX_S_TS            Mixing of tracers along constant S-surfaces.
 NORTHERN_WALL       Wall boundary at Northern edge.
 OUT_DOUBLE          Double precision output fields in NetCDF files.
 PERFECT_RESTART     Processing perfect restart variables.
 K_GSCHEME           Third-order upstream advection of TKE fields.
 SOLAR_SOURCE        Solar Radiation Source Term.
 SOUTHERN_WALL       Wall boundary at Southern edge.
 TS_U3HADVECTION     Third-order upstream horizontal advection of tracers.
 TS_DIF2             Harmonic mixing of tracers.
 TS_PSOURCE          Tracers point sources and sinks.
 UV_PSOURCE          Mass point sources and sinks.
 WESTERN_WALL        Wall boundary at Western edge.
 Vertical S-coordinate System:
 level   S-coord     Cs-curve   Z   at hmin       at hc    half way     at hmax
    32   0.0000000   0.0000000        0.000       0.000       0.000       0.000
    31  -0.0312500  -0.0000256       -0.101      -0.094      -0.198      -0.211
    30  -0.0625000  -0.0001040       -0.202      -0.188      -0.421      -0.474
    29  -0.0937500  -0.0002400       -0.304      -0.282      -0.672      -0.792
    28  -0.1250000  -0.0004423       -0.406      -0.376      -0.956      -1.175
    27  -0.1562500  -0.0007236       -0.508      -0.471      -1.278      -1.635
    26  -0.1875000  -0.0011014       -0.610      -0.566      -1.647      -2.188
    25  -0.2187500  -0.0015996       -0.713      -0.661      -2.074      -2.858
    24  -0.2500000  -0.0022492       -0.816      -0.757      -2.575      -3.675
    23  -0.2812500  -0.0030910       -0.920      -0.853      -3.170      -4.679
    22  -0.3125000  -0.0041778       -1.025      -0.950      -3.884      -5.921
    21  -0.3437500  -0.0055774       -1.132      -1.048      -4.749      -7.467
    20  -0.3750000  -0.0073773       -1.239      -1.147      -5.810      -9.402
    19  -0.4062500  -0.0096898       -1.349      -1.248      -7.119     -11.834
    18  -0.4375000  -0.0126588       -1.461      -1.350      -8.748     -14.904
    17  -0.4687500  -0.0164685       -1.576      -1.456     -10.786     -18.791
    16  -0.5000000  -0.0213546       -1.696      -1.564     -13.346     -23.723
    15  -0.5312500  -0.0276179       -1.820      -1.677     -16.577     -29.993
    14  -0.5625000  -0.0356419       -1.952      -1.794     -20.663     -37.973
    13  -0.5937500  -0.0459141       -2.091      -1.919     -25.843     -48.136
    12  -0.6250000  -0.0590529       -2.242      -2.052     -32.416     -61.084
    11  -0.6562500  -0.0758390       -2.406      -2.196     -40.763     -77.575
    10  -0.6875000  -0.0972542       -2.588      -2.354     -51.360     -98.561
     9  -0.7187500  -0.1245249       -2.791      -2.530     -64.804    -125.235
     8  -0.7500000  -0.1591703       -3.023      -2.728     -81.834    -159.072
     7  -0.7812500  -0.2030516       -3.289      -2.953    -103.354    -201.879
     6  -0.8125000  -0.2584153       -3.599      -3.213    -130.457    -255.839
     5  -0.8437500  -0.3279186       -3.962      -3.515    -164.434    -323.533
     4  -0.8750000  -0.4146160       -4.390      -3.869    -206.771    -407.927
     3  -0.9062500  -0.5218760       -4.895      -4.284    -259.106    -512.293
     2  -0.9375000  -0.6531834       -5.491      -4.772    -323.132    -640.016
     1  -0.9687500  -0.8117684       -6.190      -5.342    -400.420    -794.233
     0  -1.0000000  -1.0000000       -7.000      -6.000    -492.123    -977.246
 Time Splitting Weights: ndtfast =  30    nfast =  42
  7-0.0011849025289723 0.0336508794757796-0.0107112868023601 0.2343461315221331
  8-0.0005032751608632 0.0336903762267453-0.0112145619632232 0.2680365077488784
  9 0.0003887272597151 0.0337071520654408-0.0108258347035082 0.3017436598143192
 10 0.0014892209965583 0.0336941944901169-0.0093366137069499 0.3354378543044362
 12 0.0043042707117221 0.0335513677379153-0.0022367614257357 0.4026337758325831
 13 0.0060106451121704 0.0334078920475245 0.0037738836864347 0.4360416678801077
 14 0.0079087469427945 0.0332075372104522 0.0116826306292292 0.4692492050905598
 15 0.0099910761708919 0.0329439123123590 0.0216737068001212 0.5021931174029188
 16 0.0122483446563884 0.0326108764399960 0.0339220514565096 0.5348039938429148
 17 0.0146692120341107 0.0322025982847830 0.0485912634906203 0.5670065921276978
 18 0.0172400033810439 0.0317136245503127 0.0658312668716642 0.5987202166780105
 19 0.0199444086685725 0.0311389577709445 0.0857756755402366 0.6298591744489550
 20 0.0227631639997064 0.0304741441486588 0.1085388395399430 0.6603333185976138
 21 0.0256737146312910 0.0297153720153352 0.1342125541712340 0.6900486906129490
 22 0.0286498597812016 0.0288595815276255 0.1628624139524357 0.7189082721405746
 23 0.0316613792205219 0.0279045862015855 0.1945237931729576 0.7468128583421600
 24 0.0346736416507075 0.0268492068942347 0.2291974348236651 0.7736620652363948
 25 0.0376471948657328 0.0256934188392112 0.2668446296893979 0.7993554840756060
 26 0.0405373376992232 0.0244385123436867 0.3073819673886211 0.8237939964192927
 27 0.0432936737565710 0.0230872677537126 0.3506756411451921 0.8468812641730054
 28 0.0458596469320356 0.0216441452951603 0.3965352880772277 0.8685254094681656
 29 0.0481720587108284 0.0201154903974257 0.4447073467880561 0.8886408998655914
 30 0.0501605672561820 0.0185097551070648 0.4948679140442381 0.9071506549726561
 31 0.0517471682814030 0.0168377361985254 0.5466150823256412 0.9239883911711815
 32 0.0528456577069106 0.0151128305891453 0.5994607400325518 0.9391012217603267
 33 0.0533610761022577 0.0133513086655816 0.6528218161348095 0.9524525304259084
 34 0.0531891349131379 0.0115726061288397 0.7060109510479474 0.9640251365547481
 35 0.0522156244733761 0.0097996349650684 0.7582265755213234 0.9738247715198165
 36 0.0503158038019030 0.0080591141492892 0.8085423793232265 0.9818838856691057
 37 0.0473537721847154 0.0063819206892258 0.8558961515079418 0.9882658063583315
 38 0.0431818225418188 0.0048034616164019 0.8990779740497606 0.9930692679747335
 39 0.0376397765791564 0.0033640675316746 0.9367177506289170 0.9964333355064081
 40 0.0305543017255207 0.0021094083123694 0.9672720523544377 0.9985427438187775
 41 0.0217382098544505 0.0010909315881854 0.9890102622088881 0.9996336754069629
 42 0.0109897377911118 0.0003663245930371 0.9999999999999999 1.0000000000000000
 ndtfast, nfast =   30  42   nfast/ndtfast = 1.40000
 Power filter parameters, Fgamma, gamma =  0.28400   0.18933
 Minimum X-grid spacing, DXmin =  3.33514538E+00 km
 Maximum X-grid spacing, DXmax =  3.98831267E+00 km
 Minimum Y-grid spacing, DYmin =  3.33800882E+00 km
 Maximum Y-grid spacing, DYmax =  3.98739982E+00 km
 Minimum Z-grid spacing, DZmin =  1.01057987E-01 m
 Maximum Z-grid spacing, DZmax =  1.83012378E+02 m
 Minimum barotropic Courant Number =  8.90418085E-03
 Maximum barotropic Courant Number =  1.08159505E-01
 Maximum Coriolis   Courant Number =  9.58513554E-03
 NLM: GET_STATE - Read state initial conditions,             t =    52 24:00:00
                   (File: initial_feb_23.nc, Rec=0001, Index=1)
                - free-surface
                - u-momentum component
                - v-momentum component
                - potential temperature
                   (Min = -4.20086944E+00 Max =  1.28952207E+01)
                - salinity
                   (Min = -4.95809949E-01 Max =  1.88765502E+01)
    GET_NGFLD   - river runoff  XI-positions at RHO-points
                   (Min =  1.80000000E+01 Max =  1.11000000E+02)
    GET_NGFLD   - river runoff ETA-positions at RHO-points
                   (Min =  8.50000000E+01 Max =  3.31000000E+02)
    GET_NGFLD   - river runoff direction
                   (Min =  0.00000000E+00 Max =  1.00000000E+00)
    GET_NGFLD   - river runoff mass transport vertical profile
                   (Min =  0.00000000E+00 Max =  7.63425333E-02)
    GET_NGFLD   - river runoff mass transport,               t =    45 15:45:00
                   (Rec=0002, Index=2, File: rivers_force_07.nc)
                   (Tmin=         15.2188 Tmax=        350.0313)
    GET_NGFLD   - river runoff potential temperature,        t =    45 15:45:00
    GET_NGFLD   - river runoff salinity,                     t =    45 15:45:00
    GET_2DFLD   - surface u-wind component,                  t =    52 24:00:00
                   (Rec=0424, Index=1, File:uwnd2_era_07.nc)
                   (Tmin=          0.1250 Tmax=        365.0000)
                   (Min = -7.74161853E+00 Max =  1.07270185E+01)
    GET_2DFLD   - surface v-wind component,                  t =    52 24:00:00
                   (Rec=0424, Index=1, File: vwnd2_era_07.nc)
                   (Min = -7.15289563E+00 Max =  2.31153406E+00)
    GET_2DFLD   - cloud fraction,                            t =    52 24:00:00
                   (Rec=0424, Index=1, File: cloud2_era_07.nc)
                   (Min =  2.01395231E-06 Max =  9.99995078E-01)
    GET_2DFLD   - solar shortwave radiation flux,            t =    52 22:30:00
                   (Rec=0424, Index=1, File: swrad2_era_07.nc)
                   (Tmin=          0.0625 Tmax=        364.9375)
    GET_2DFLD   - net longwave radiation flux,               t =    52 22:30:00
                   (Rec=0424, Index=1, File: lwrad2_era_07.nc)
                   (Min = -3.36537199E-05 Max = -2.44188518E-06)
    GET_2DFLD   - surface air pressure,                      t =    52 24:00:00
                   (Rec=0424, Index=1, File:Pair2_era_07.nc)
                   (Min =  1.00973711E+01 Max =  1.02177491E+01)
    GET_2DFLD   - surface air temperature,                   t =    52 24:00:00
                   (Rec=0424, Index=1, File: Tair2_era_07.nc)
                   (Min = -1.32895356E+01 Max =  1.05571051E+01)
    GET_2DFLD   - surface air relative humidity,             t =    52 24:00:00
                   (Rec=0424, Index=1, File: Qair2_era_07.nc)
                   (Min =  3.92107980E+01 Max =  9.98422398E+01)
    GET_2DFLD   - rain fall rate,                            t =    52 22:30:00
                   (Rec=0424, Index=1, File: rain2_era_07.nc)
                   (Min =  0.00000000E+00 Max =  9.99754352E-05)
 Maximum grid stiffness ratios:  rx0 =   2.334384E-01 (Beckmann and Haidvogel)
                                 rx1 =   2.465125E+00 (Haney)
 Initial basin volumes: TotVolume =  7.6973949537E+13 m3
                        MinVolume =  1.1438083862E+06 m3
                        MaxVolume =  2.6995814696E+09 m3
                          Max/Min =  2.3601693274E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00015360)
    GET_NGFLD   - river runoff mass transport,               t =    76 02:15:00
                   (Rec=0003, Index=1, File: rivers_force_07.nc)
                   (Min =  1.03500000E+01 Max =  1.80990150E+02)
    GET_NGFLD   - river runoff potential temperature,        t =    76 02:15:00
                   (Min =  1.00000000E+00 Max =  8.50000000E+00)
    GET_NGFLD   - river runoff salinity,                     t =    76 02:15:00
    GET_2DFLD   - surface u-wind component,                  t =    53 03:00:00
                   (Rec=0425, Index=2, File: uwnd2_era_07.nc)
                   (Min = -6.57603001E+00 Max =  1.11504230E+01)
    GET_2DFLD   - surface v-wind component,                  t =    53 03:00:00
                   (Rec=0425, Index=2, File: vwnd2_era_07.nc)
                   (Min = -6.86435918E+00 Max =  2.28099857E+00)
    GET_2DFLD   - cloud fraction,                            t =    53 03:00:00
                   (Rec=0425, Index=2, File: cloud2_era_07.nc)
                   (Min =  3.32647248E-04 Max =  1.00000763E+00)
    GET_2DFLD   - solar shortwave radiation flux,            t =    53 01:30:00
                   (Rec=0425, Index=2, File: swrad2_era_07.nc)
    GET_2DFLD   - net longwave radiation flux,               t =    53 01:30:00
                   (Rec=0425, Index=2, File: lwrad2_era_07.nc)
                   (Min = -2.93528307E-05 Max = -3.13833471E-06)
    GET_2DFLD   - surface air pressure,                      t =    53 03:00:00
                   (Rec=0425, Index=2, File: Pair2_era_07.nc)
                   (Min =  1.01237279E+01 Max =  1.02222626E+01)
    GET_2DFLD   - surface air temperature,                   t =    53 03:00:00
                   (Rec=0425, Index=2, File: Tair2_era_07.nc)
                   (Min = -1.45091888E+01 Max =  8.87779870E+00)
    GET_2DFLD   - surface air relative humidity,             t =    53 03:00:00
                   (Rec=0425, Index=2, File:Qair2_era_07.nc)
                   (Min =  3.84657750E+01 Max =  9.98664843E+01)
    GET_2DFLD   - rain fall rate,                            t =    53 01:30:00
                   (Rec=0425, Index=2, File: rain2_era_07.nc)
                   (Min = -3.21245078E-19 Max =  7.43657791E-05)
  GRID  STEP   Day HH:MM:SS  KINETIC_ENRG   POTEN_ENRG    TOTAL_ENRG    NET_VOLUME
   1       0    52 24:00:00  0.000000E+00  2.676897E+03  2.676897E+03  8.067723E+13
      DEF_HIS   - creating history file: ocean_rip_current_his.nc
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000001
      DEF_AVG   - creating average file: ocean_rip_current_avg.nc
   1       1    53 00:01:30  1.391354E-04  2.676849E+03  2.676850E+03  8.067724E+13
   1       2    53 00:03:00  4.958762E-04  2.676660E+03  2.676661E+03  8.067725E+13
   1       3    53 00:04:30  9.625364E-04  2.676449E+03  2.676450E+03  8.067726E+13
   1       4    53 00:06:00  1.442661E-03  2.676260E+03  2.676262E+03  8.067728E+13
   1       5    53 00:07:30  1.916653E-03  2.676073E+03  2.676075E+03  8.067729E+13
   1       6    53 00:09:00  2.346807E-03  2.675890E+03  2.675893E+03  8.067730E+13
 ROMS/TOMS - Blows up ................ exit_flag:   1
      WRT_RST   - wrote re-start fields (Index=1,1) into time record = 0000001
 Elapsed CPU time (seconds):
 Node   #  0 CPU:      37.938
 Node   #  1 CPU:     119.167
 Total:               157.105
  Initialization ...................................        39.047  (24.8541 %)
  OI data assimilation .............................         0.001  ( 0.0006 %)
  Reading of input data ............................        34.456  (21.9317 %)
  Processing of input data .........................         0.020  ( 0.0127 %)
  Processing of output time averaged data ..........         2.631  ( 1.6744 %)
  Computation of vertical boundary conditions ......         0.005  ( 0.0032 %)
  Computation of global information integrals ......         0.180  ( 0.1146 %)
  Writing of output data ...........................        18.403  (11.7139 %)
  Model 2D kernel ..................................        19.281  (12.2727 %)
  2D/3D coupling, vertical metrics .................         0.145  ( 0.0923 %)
  Omega vertical velocity ..........................         0.197  ( 0.1254 %)
  Equation of state for seawater ...................         1.461  ( 0.9298 %)
  Atmosphere-Ocean bulk flux parameterization ......         0.838  ( 0.5333 %)
  GLS vertical mixing parameterization .............         8.301  ( 5.2836 %)
  3D equations right-side terms ....................         1.446  ( 0.9203 %)
  3D equations predictor step ......................         3.944  ( 2.5107 %)
  Pressure gradient ................................         0.991  ( 0.6307 %)
  Harmonic mixing of tracers, S-surfaces ...........         0.462  ( 0.2940 %)
  Harmonic stress tensor, S-surfaces ...............         0.875  ( 0.5569 %)
  Corrector time-step for 3D momentum ..............         4.547  ( 2.8944 %)
  Corrector time-step for tracers ..................         2.432  ( 1.5478 %)
                                              Total:       139.662   88.8970
 Nonlinear model message Passage profile:
  Message Passage: 2D halo exchanges ...............         1.127  ( 0.7172 %)
  Message Passage: 3D halo exchanges ...............         1.183  ( 0.7529 %)
  Message Passage: 4D halo exchanges ...............         0.422  ( 0.2686 %)
  Message Passage: data broadcast ..................        79.158  (50.3854 %)
  Message Passage: data reduction ..................         2.710  ( 1.7247 %)
  Message Passage: data gathering ..................        17.503  (11.1412 %)
  Message Passage: data scattering..................         1.211  ( 0.7707 %)
                                              Total:       103.313   65.7606
 All percentages are with respect to total time =          157.105
 Analytical header files used:
     ROMS/Functionals/ana_btflux.h
Re: stdout
#11 Unread post by wilkin »
Your initial conditions for temp and salt ...
- salinity
are a bit odd. Salinity < 0. This of itself won't immediately cause a blow-up. But it might mean you initial conditions are not what you intended them to be.
You have quite large horizontal mixing coefficients (100 m2/s) for a 3000 m grid, and your mixing is along s-coordinate surfaces (you do not have MIX_GEO_TS) which could drive appreciable diapyncal mixing and convection at the start of your run.
Remember, on blow-up the model state is written to record 3 of the restart file. So look at that to see where the problem is occurring and that may guide you toward a source of the problem.
redhat007
Re: stdout
#12 Unread post by redhat007 »
Dear Wilkin
Thanks for your reply. I set initial values to zero and TNU2== 50 50. changing some options, for example #define MIX_GEO_TS instead of #define MIX_S_TS, and #define ana_STFLUX,or #Undef TS_DIF2 can not solve problem and blow up happened after 13 min. In last step of restart file there are some values for temperature in the surface layer that seems this is problem (about 40 c). I have checked Tair data, there was not strange values (all data about 10c). running model for different time (second run) face with blow up, too.
5.0000E+01  nl_tnu2(01)     NLM Horizontal, harmonic mixing coefficient
 5.0000E+01  nl_tnu2(02)     NLM Horizontal, harmonic mixing coefficient
Final header file contains:
RIPCURRENT
 ANA_BSFLUX
 ANA_BTFLUX
 ASSUMED_SHAPE
 AVERAGES
 BULK_FLUXES
 COOL_SKIN
 DIAGNOSTICS_TS
 DIAGNOSTICS_UV
 DJ_GRADPS
 DOUBLE_PRECISION
 EASTERN_WALL
 EMINUSP
 GLS_MIXING
 KANTHA_CLAYSON
 MASKING
 MIX_S_TS
 MIX_S_UV
 MPI
 NONLINEAR
 NONLIN_EOS
 NORTHERN_WALL
 N2S2_HORAVG
 OUT_DOUBLE
 PERFECT_RESTART
 POWER_LAW
 PROFILE
 K_GSCHEME
 !RST_SINGLE
 SALINITY
 SOLAR_SOURCE
 SOLVE3D
 SOUTHERN_WALL
 SPLINES
 TS_U3HADVECTION
 TS_C4VADVECTION
 TS_DIF2
 TS_PSOURCE
 UV_ADV
 UV_COR
 UV_U3HADVECTION
 UV_C4VADVECTION
 UV_QDRAG
 UV_PSOURCE
 UV_VIS2
 VAR_RHO_2D
 WESTERN_WALL       .
I become really appreciate to receive your command.
Many thanks
redhat
Re: stdout
#13 Unread post by kate »
I would write out the computed heat fluxes and all the terms that go into it, such as latent and sensible heat. Also, check your Pair units. ROMS wants millibars, numbers close to 1000. You can scale it in varinfo.dat, or maybe you are inadvertantly already.
redhat007
Re: stdout
#14 Unread post by redhat007 »
Dear kate
Thanks .as you can see there are some odd values in sensible and latent flux which are written out.
I will be so grateful for receiving any command to solve it
Many thanks
redhat
sensible heat flux
sensible heat flux
latent heat flux
latent heat flux
Re: stdout
#15 Unread post by kate »
Urgent need is how you learn to develop some debugging skills. You can go to the bulk_flux code to see which fields enter into the computation of these fields. You can look at your forcing files to make sure they are sensible, but if ROMS is interpolating them, there shouldn't be these lone points of weirdness. You can start adding print statements to print out the relevant variables at those points. If running in parallel, the safest print statements in do loops are like:
      if (i==54 .and. j==54) then
        print *, 'DEBUG t ', t(i,j,N(ng),:,:)
      end if
Instead, I do most of my debugging in totalview where I can query one field after another. ddt is similar. In the open source world there is gdb and ddd, but they can be tricky to use with fortran data structures.
redhat007
Re: stdout
#16 Unread post by redhat007 »
Dear Kate
1-would you please tell me when Qair (one input force file) is surface RELATIVE humidity (millibar), using #define SPECIFIC_HUMIDITY is wrong?
That is because when i use #undef SPECIFIC_HUMIDITY , model does not face with blow up.
2-also if it is possible please tell me where i should add following code:
      end if
Many thanks
redhat
Re: stdout
#17 Unread post by kate »
If you have relative humidity, you don't want to set SPECIFIC_HUMIDITY.
The print statement should go after:
      DO j=Jstr-1,JendR
        DO i=Istr-1,IendR
and before the END DO.
redhat007
Re: stdout
#18 Unread post by redhat007 »
Dear Wilkin
i have read Barnier's article and set_dqdsst.m, too. Author spoke about ECMWF data but some of needed input parameters (rho_atm, qsea, sat) are not in that database. it just has sst and wind speed components. also COADS05 dataset has not requested data in my research region (caspian sea)
Therefore i become appreciate if you (or some one else) know how i can provide them to compute dqdsst, help me to compute dqdsst.
many thanks
redhat
Re: stdout
#19 Unread post by wilkin »
Reread my post of 13 May 2014 08:30 on this thread for pointers to ROMS Agrif Matlab code that shows one approach to computing dqdsst.
The atmosphere and ocean quantities required are most definitely available amongst the ECMWF ERA Interim data at http://apps.ecmwf.int/datasets/data/interim_full_daily/ ... but you will have to do a bit of reading to understand which variables to use and appropriate units conversions to make.
redhat007
Re: stdout
#20 Unread post by redhat007 »
Dear Wilkin
first of all thanks for your attention. I have used 3 hourly data from ECMWF_Interim and set them as:
sst=ncread('CS_sst_era.nc','sst'); % sea surface temperature (Kelvin)
sst = sst - 273.15;                   % Kelvin to Celsius
sat=ncread('CS_Tair_era.nc','Tair');   %sea surface atmospheric temperature (Celsius) at 2m
rho_atm =1.29;  %atmospheric density (kilogram meter-3)
u=ncread('CS_wind_era.nc','Uwind');
v=ncread('CS_wind_era.nc','Vwind');
U        =(u.^2+v.^2).^.5;
qsea=qsat(sat);computes specific humidity at saturation(kg/kg) at air temperature which will be in 2 meter level
dqdsst =get_dqdsst(sst,sat,rho_atm,U,qsea);
i become so appreciate if there is any problem tell it to me (is there problem to use 2 m temperature data as a sat? because i can find just this parameter as a air temperature there aslo i cant find data for atmospheric density therefore set it as a fix value)
many many thanks for your patient
cheers
redhat
by following approach mean value of dqdsst computed equal to -21.0172
redhat007
Re: stdout
#21 Unread post by redhat007 »
Dear
i have checked all posts about dqdsst, no one explained how compute it. Also in Barnier mentioned to surface air temperature. And as you know surface air temperature is ECMWF-Interim (Tair) is actually in 2 m level. Now i would you please tell me that:
1-is 2 m air temperature (Tair) same sea surface air temperature? And therefore sea level specific humidity (which compute base on sea surface air temperature ) same 2 m specific humidity? or not, there is different between surface air temp and 2m air temp?
2- Is function P/R.T (p: surface air pressure, R=287.05 and T=Tair) appropriate way to compute atmospheric density?
Cheers
redhat
