Model blown up after 24 Year and 9 months simulation
novice
#1 Unread post by novice »
Hi Forum,
I was trying to extend the climatological run to 40 Years whcih was successfully completed for 20 years using ROMS configured for the Indian ocean. Model is initialized using the restart file of 20 year run. Model is blowing after 24 year and 9 months.
The model configuration and simulation steps are as shown below.
I am still in the early stages of understanding the model. I would be grateful if somebody can point out what might have gone wrong.
Thursday - May 8, 2014 - 6:54:16 PM
Trial run for Indian Ocean
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script :
SVN Root URL : https:://myroms.org/svn/src
SVN Revision : 669M
Local Root : /home/osf123/src0
Header Dir : /home/osf123/src0/test/test_io8
Header file : test_io8.h
Analytical Dir: /home/osf123/src0/test/test_io8
Resolution, Grid 01: 0359x0251x020, Parallel Nodes: 24, Tiling: 006x004
4147200 ntimes Number of timesteps for 3-D equations.
-1 nrrec Number of restart records to read from disk.
864 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
8640 nHIS Number of timesteps between the writing fields
into history file.
103680 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
8640 nAVG Number of timesteps between the writing of
103680 ndefAVG Number of timesteps between creation of new
time-averaged file.
5.0000E+00 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
5.0000E+00 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
1.0000E-04 rdrg Linear bottom drag coefficient (m/s).
1.0000E-03 rdrg2 Quadratic bottom drag coefficient.
1 lmd_Jwt Jerlov water type.
6.0000E+00 theta_s S-coordinate surface control parameter.
10.000 Tcline S-coordinate surface/bottom layer width (m) used
1027.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
3.6000E+02 Tnudg(01) Nudging/relaxation time scale (days)
3.6000E+02 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.6000E+02 Znudg Nudging/relaxation time scale (days)
3.6000E+02 M2nudg Nudging/relaxation time scale (days)
3.6000E+02 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.2000E+02 obcfac Factor between passive and active
-0.278 T0 Background potential temperature (C) constant.
34.649 S0 Background salinity (PSU) constant.
T LtracerCLM(01) Processing climatology on tracer 01: temp
T LtracerCLM(02) Processing climatology on tracer 02: salt
Prefix for History Files: ocean_his
Prefix for Averages Files: ocean_avg
Input Grid File: roms_grd.nc
Input Nonlinear Initial File: ocean_rst.nc
Input Forcing File 01: roms_frc.nc
Input Climatology File: roms_clm.nc
Input Boundary File: roms_bry.nc
Tile partition information for Grid 01: 0359x0251x0020 tiling: 006x004
tile Istr Iend Jstr Jend Npts
0 1 60 1 63 75600
1 61 120 1 63 75600
2 121 180 1 63 75600
3 181 240 1 63 75600
4 241 300 1 63 75600
5 301 359 1 63 74340
6 1 60 64 126 75600
7 61 120 64 126 75600
8 121 180 64 126 75600
9 181 240 64 126 75600
10 241 300 64 126 75600
11 301 359 64 126 74340
12 1 60 127 189 75600
13 61 120 127 189 75600
14 121 180 127 189 75600
15 181 240 127 189 75600
16 241 300 127 189 75600
17 301 359 127 189 74340
18 1 60 190 251 74400
19 61 120 190 251 74400
20 121 180 190 251 74400
21 181 240 190 251 74400
22 241 300 190 251 74400
23 301 359 190 251 73160
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 60.50 0.50 63.50 RHO-points
1 60.50 120.50 0.50 63.50 RHO-points
2 120.50 180.50 0.50 63.50 RHO-points
3 180.50 240.50 0.50 63.50 RHO-points
4 240.50 300.50 0.50 63.50 RHO-points
5 300.50 359.50 0.50 63.50 RHO-points
6 0.50 60.50 63.50 126.50 RHO-points
7 60.50 120.50 63.50 126.50 RHO-points
8 120.50 180.50 63.50 126.50 RHO-points
9 180.50 240.50 63.50 126.50 RHO-points
10 240.50 300.50 63.50 126.50 RHO-points
11 300.50 359.50 63.50 126.50 RHO-points
12 0.50 60.50 126.50 189.50 RHO-points
13 60.50 120.50 126.50 189.50 RHO-points
14 120.50 180.50 126.50 189.50 RHO-points
15 180.50 240.50 126.50 189.50 RHO-points
16 240.50 300.50 126.50 189.50 RHO-points
17 300.50 359.50 126.50 189.50 RHO-points
18 0.50 60.50 189.50 251.50 RHO-points
19 60.50 120.50 189.50 251.50 RHO-points
20 120.50 180.50 189.50 251.50 RHO-points
21 180.50 240.50 189.50 251.50 RHO-points
22 240.50 300.50 189.50 251.50 RHO-points
23 300.50 359.50 189.50 251.50 RHO-points
0 1.00 60.50 0.50 63.50 U-points
1 60.50 120.50 0.50 63.50 U-points
2 120.50 180.50 0.50 63.50 U-points
3 180.50 240.50 0.50 63.50 U-points
4 240.50 300.50 0.50 63.50 U-points
5 300.50 359.00 0.50 63.50 U-points
6 1.00 60.50 63.50 126.50 U-points
7 60.50 120.50 63.50 126.50 U-points
8 120.50 180.50 63.50 126.50 U-points
9 180.50 240.50 63.50 126.50 U-points
10 240.50 300.50 63.50 126.50 U-points
11 300.50 359.00 63.50 126.50 U-points
12 1.00 60.50 126.50 189.50 U-points
13 60.50 120.50 126.50 189.50 U-points
14 120.50 180.50 126.50 189.50 U-points
15 180.50 240.50 126.50 189.50 U-points
16 240.50 300.50 126.50 189.50 U-points
17 300.50 359.00 126.50 189.50 U-points
18 1.00 60.50 189.50 251.50 U-points
19 60.50 120.50 189.50 251.50 U-points
20 120.50 180.50 189.50 251.50 U-points
21 180.50 240.50 189.50 251.50 U-points
22 240.50 300.50 189.50 251.50 U-points
23 300.50 359.00 189.50 251.50 U-points
0 0.50 60.50 1.00 63.50 V-points
1 60.50 120.50 1.00 63.50 V-points
2 120.50 180.50 1.00 63.50 V-points
3 180.50 240.50 1.00 63.50 V-points
4 240.50 300.50 1.00 63.50 V-points
5 300.50 359.50 1.00 63.50 V-points
6 0.50 60.50 63.50 126.50 V-points
7 60.50 120.50 63.50 126.50 V-points
8 120.50 180.50 63.50 126.50 V-points
9 180.50 240.50 63.50 126.50 V-points
10 240.50 300.50 63.50 126.50 V-points
11 300.50 359.50 63.50 126.50 V-points
12 0.50 60.50 126.50 189.50 V-points
13 60.50 120.50 126.50 189.50 V-points
14 120.50 180.50 126.50 189.50 V-points
15 180.50 240.50 126.50 189.50 V-points
16 240.50 300.50 126.50 189.50 V-points
17 300.50 359.50 126.50 189.50 V-points
18 0.50 60.50 189.50 251.00 V-points
19 60.50 120.50 189.50 251.00 V-points
20 120.50 180.50 189.50 251.00 V-points
21 180.50 240.50 189.50 251.00 V-points
22 240.50 300.50 189.50 251.00 V-points
23 300.50 359.50 189.50 251.00 V-points
HaloSizeI(1) = 144
HaloSizeJ(1) = 150
TileSide(1) = 69
TileSize(1) = 4554
zeta 1 Closed Chapman Imp Chapman Imp Closed
ubar 1 Closed Flather Flather Closed
vbar 1 Closed Flather Flather Closed
u 1 Closed Rad + Nud Rad + Nud Closed
v 1 Closed Rad + Nud Rad + Nud Closed
temp 1 Closed Rad + Nud Rad + Nud Closed
salt 1 Closed Rad + Nud Rad + Nud Closed
TEST_IO7 Trial run for Indian Ocean
DEBUGGING Internal debugging switch activated.
DIURNAL_SRFLUX Modulate shortwave radiation by the local diurnal cycle.
LMD_BKPP KPP bottom boundary layer mixing.
LMD_CONVEC LMD convective mixing due to shear instability.
LMD_MIXING Large/McWilliams/Doney interior mixing.
LMD_NONLOCAL LMD convective nonlocal transport.
LMD_RIMIX LMD diffusivity due to shear instability.
LMD_SKPP KPP surface boundary layer mixing.
M3CLIMATOLOGY Processing 3D momentum climatology data.
M3CLM_NUDGING Nudging toward 3D momentum climatology.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NO_LBC_ATT Not checking NetCDF global attribute NLM_LBC during restart.
QCORRECTION Surface net heat flux correction.
SALINITY Using salinity.
SCORRECTION Surface salinity flux correction.
TCLIMATOLOGY Processing tracer climatology data.
TCLM_NUDGING Nudging toward tracer climatology.
TS_SVADVECTION Parabolic splines vertical advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_LDRAG Linear bottom stress.
ZCLIMATOLOGY Processing sea surface height climatology data.
Process Information:
Node # 0 (pid= 11154) is active.
Node # 2 (pid= 11156) is active.
Node # 3 (pid= 11157) is active.
Node # 5 (pid= 11159) is active.
Node # 6 (pid= 11160) is active.
Node # 8 (pid= 11162) is active.
Node # 10 (pid= 11164) is active.
Node # 11 (pid= 11165) is active.
Node # 12 (pid= 11166) is active.
Node # 16 (pid= 11170) is active.
Node # 18 (pid= 11172) is active.
Node # 19 (pid= 11173) is active.
Node # 21 (pid= 11175) is active.
Node # 22 (pid= 11176) is active.
Node # 23 (pid= 11177) is active.
Node # 1 (pid= 11155) is active.
Node # 4 (pid= 11158) is active.
Node # 7 (pid= 11161) is active.
Node # 9 (pid= 11163) is active.
Node # 13 (pid= 11167) is active.
Node # 14 (pid= 11168) is active.
Node # 15 (pid= 11169) is active.
Node # 17 (pid= 11171) is active.
Node # 20 (pid= 11174) is active.
20 0.0000000 0.0000000 0.000 0.000 0.000 0.000
19 -0.0500000 -0.0015097 -0.598 -0.500 -4.316 -8.033
18 -0.1000000 -0.0031562 -1.205 -1.000 -8.977 -16.750
17 -0.1500000 -0.0050890 -1.831 -1.500 -14.362 -26.894
16 -0.2000000 -0.0074832 -2.486 -2.000 -20.914 -39.341
15 -0.2500000 -0.0105560 -3.186 -2.500 -29.180 -55.174
14 -0.3000000 -0.0145859 -3.948 -3.000 -39.866 -75.784
13 -0.3500000 -0.0199385 -4.796 -3.500 -53.895 -102.993
12 -0.4000000 -0.0270990 -5.761 -4.000 -72.493 -139.224
11 -0.4500000 -0.0367168 -6.887 -4.500 -97.302 -187.717
10 -0.5000000 -0.0496640 -8.228 -5.000 -130.526 -252.823
9 -0.5500000 -0.0671145 -9.862 -5.500 -175.132 -340.401
8 -0.6000000 -0.0906508 -11.892 -6.000 -235.120 -458.347
7 -0.6500000 -0.1224070 -14.456 -6.500 -315.884 -617.311
6 -0.7000000 -0.1652627 -17.742 -7.000 -424.702 -831.661
5 -0.7500000 -0.2231040 -22.002 -7.500 -571.395 -1120.789
4 -0.8000000 -0.3011757 -27.576 -8.000 -769.221 -1510.867
3 -0.8500000 -0.4065570 -34.926 -8.500 -1036.073 -2037.220
2 -0.9000000 -0.5488038 -44.672 -9.000 -1396.102 -2747.531
1 -0.9500000 -0.7408145 -57.653 -9.500 -1881.909 -3706.164
0 -1.0000000 -1.0000000 -75.000 -10.000 -2537.500 -5000.000
12 0.0043042707117221 0.0335513677379153-0.0022367614257356 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864348 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001213 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565097 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906204 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716643 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402368 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399432 0.6603333185976138
21 0.0256737146312911 0.0297153720153352 0.1342125541712342 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524359 0.7189082721405746
23 0.0316613792205220 0.0279045862015855 0.1945237931729578 0.7468128583421600
24 0.0346736416507075 0.0268492068942347 0.2291974348236653 0.7736620652363948
25 0.0376471948657328 0.0256934188392112 0.2668446296893981 0.7993554840756060
26 0.0405373376992232 0.0244385123436867 0.3073819673886213 0.8237939964192927
27 0.0432936737565710 0.0230872677537126 0.3506756411451924 0.8468812641730054
28 0.0458596469320356 0.0216441452951603 0.3965352880772280 0.8685254094681656
29 0.0481720587108284 0.0201154903974257 0.4447073467880565 0.8886408998655914
30 0.0501605672561820 0.0185097551070648 0.4948679140442384 0.9071506549726561
31 0.0517471682814030 0.0168377361985254 0.5466150823256415 0.9239883911711815
32 0.0528456577069106 0.0151128305891453 0.5994607400325521 0.9391012217603267
33 0.0533610761022577 0.0133513086655816 0.6528218161348098 0.9524525304259084
34 0.0531891349131379 0.0115726061288397 0.7060109510479478 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213239 0.9738247715198165
36 0.0503158038019030 0.0080591141492892 0.8085423793232269 0.9818838856691057
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
38 0.0431818225418188 0.0048034616164019 0.8990779740497611 0.9930692679747334
39 0.0376397765791564 0.0033640675316746 0.9367177506289175 0.9964333355064080
40 0.0305543017255206 0.0021094083123694 0.9672720523544381 0.9985427438187774
41 0.0217382098544504 0.0010909315881854 0.9890102622088885 0.9996336754069628
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 2.40495901E+01 km
Maximum X-grid spacing, DXmax = 2.77832099E+01 km
Minimum Y-grid spacing, DYmin = 2.40871264E+01 km
Maximum Y-grid spacing, DYmax = 2.77830873E+01 km
Minimum Z-grid spacing, DZmin = 5.98128547E-01 m
Maximum Z-grid spacing, DZmax = 1.29383575E+03 m
Minimum barotropic Courant Number = 1.38069792E-02
Maximum barotropic Courant Number = 1.30102503E-01
Maximum Coriolis Courant Number = 2.18475176E-02
NLM: GET_STATE - Warning - NetCDF global attribute: NLM_LBC
for lateral boundary conditions not checked
in restart file: ocean_rst.nc
NLM: GET_STATE - Read state initial conditions, t = 7200 00:00:00
(Grid 01, File: ocean_rst.nc, Rec=0002, Index=1)
- free-surface
(Min = -4.78214204E-01 Max = 3.89312325E-01)
(Min = -9.16194885E-01 Max = 1.23920726E+00)
(Min = -1.23307813E+00 Max = 1.46448011E+00)
- u-momentum component
(Min = -1.89390162E+00 Max = 2.08851137E+00)
- v-momentum component
(Min = -1.48630389E+00 Max = 1.75882535E+00)
- potential temperature
(Min = -1.71560703E+00 Max = 3.07218421E+01)
- salinity
(Min = 3.05956257E+01 Max = 4.12501141E+01)
- vertical viscosity coefficient
(Min = 0.00000000E+00 Max = 3.78931408E-01)
- temperature vertical diffusion coefficient
(Min = 0.00000000E+00 Max = 5.02493971E-01)
- salinity vertical diffusion coefficient
GET_2DFLD - surface u-momentum stress, t = 345 00:00:00
(Rec=0000012, Index=1, File: roms_frc.nc)
(Min = -1.68642882E-04 Max = 4.38884107E-05)
GET_2DFLD - surface v-momentum stress, t = 345 00:00:00
(Min = -2.30629585E-04 Max = 1.16616426E-04)
GET_2DFLD - solar shortwave radiation flux, t = 345 00:00:00
(Min = 2.41802272E-05 Max = 8.42049060E-05)
GET_2DFLD - surface net heat flux, t = 345 00:00:00
(Min = -6.70591379E-05 Max = 4.01735706E-05)
GET_2DFLD - sea surface temperature climatology, t = 345 00:00:00
(Min = 1.78758011E+01 Max = 2.96960344E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 345 00:00:00
(Min = -1.56755779E-05 Max = -4.63628970E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 345 00:00:00
(Min = -2.34185175E-07 Max = 1.15583962E-07)
GET_2DFLD - sea surface salinity climatology, t = 345 00:00:00
(Min = 2.06685009E+01 Max = 4.11551018E+01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 345 00:00:00
(Rec=0000012, Index=2, File: roms_bry.nc)
(Min = -1.91496681E+00 Max = 9.00861315E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 345 00:00:00
(Min = 0.00000000E+00 Max = 8.75090950E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 345 00:00:00
(Min = -3.57115043E-02 Max = 1.96736410E-03)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 345 00:00:00
(Min = -3.76078500E-02 Max = 4.73588457E-02)
GET_NGFLD - temperature eastern boundary condition, t = 345 00:00:00
(Min = 1.63492812E+00 Max = 2.98321407E+01)
GET_NGFLD - salinity eastern boundary condition, t = 345 00:00:00
(Min = 3.27957689E+01 Max = 3.54240978E+01)
GET_NGFLD - temperature southern boundary condition, t = 345 00:00:00
(Min = 8.28655706E-01 Max = 2.44628128E+01)
GET_NGFLD - salinity southern boundary condition, t = 345 00:00:00
(Min = 3.43723796E+01 Max = 3.59319211E+01)
GET_2DFLD - sea surface height climatology, t = 345 00:00:00
(Rec=0000012, Index=1, File: roms_clm.nc)
(Min = -1.78705581E+00 Max = 7.96083745E-01)
GET_3DFLD - potential temperature climatology, t = 345 00:00:00
(Min = 4.91792269E-01 Max = 3.02931215E+01)
GET_3DFLD - salinity climatology, t = 345 00:00:00
(Min = 2.44741127E+01 Max = 4.12579176E+01)
GET_3DFLD - u-momentum component climatology, t = 345 00:00:00
(Min = -4.08915209E+00 Max = 2.00958789E+00)
GET_3DFLD - v-momentum component climatology, t = 345 00:00:00
(Min = -1.98343534E+00 Max = 5.78551037E+00)
Maximum grid stiffness ratios: rx0 = 8.471468E-02 (Beckmann and Haidvogel)
rx1 = 5.761194E-01 (Haney)
Initial basin volumes: TotVolume = 1.3099140165E+17 m3
MinVolume = 3.4783556314E+08 m3
MaxVolume = 9.9871602556E+11 m3
Max/Min = 2.8712303496E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 02073601 - 04147200)
GET_2DFLD - surface u-momentum stress, t = 15 00:00:00
(Rec=0000001, Index=2, File: roms_frc.nc)
(Min = -1.40968591E-04 Max = 7.20559182E-05)
GET_2DFLD - surface v-momentum stress, t = 15 00:00:00
(Min = -2.30095718E-04 Max = 1.35504341E-04)
GET_2DFLD - solar shortwave radiation flux, t = 15 00:00:00
(Min = 2.57186559E-05 Max = 8.00079621E-05)
GET_2DFLD - surface net heat flux, t = 15 00:00:00
(Min = -7.05270723E-05 Max = 3.53025562E-05)
GET_2DFLD - sea surface temperature climatology, t = 15 00:00:00
(Min = 1.44625673E+01 Max = 2.94178028E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 15 00:00:00
(Min = -1.41245812E-05 Max = -5.16924856E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 15 00:00:00
(Min = -2.60033824E-07 Max = 1.14237990E-07)
GET_2DFLD - sea surface salinity climatology, t = 15 00:00:00
(Min = 2.58551006E+01 Max = 4.05689011E+01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 15 00:00:00
(Rec=0000001, Index=1, File: roms_bry.nc)
(Min = -1.91938411E+00 Max = 9.54460196E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 15 00:00:00
(Min = 0.00000000E+00 Max = 7.26320741E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 15 00:00:00
(Min = -4.20254106E-02 Max = 2.38842545E-03)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 15 00:00:00
(Min = -6.75467620E-02 Max = 4.11074862E-02)
GET_NGFLD - temperature eastern boundary condition, t = 15 00:00:00
(Min = 1.63492812E+00 Max = 2.97560361E+01)
GET_NGFLD - salinity eastern boundary condition, t = 15 00:00:00
(Min = 3.31857120E+01 Max = 3.53559989E+01)
GET_NGFLD - temperature southern boundary condition, t = 15 00:00:00
(Min = 8.28655706E-01 Max = 2.62440748E+01)
GET_NGFLD - salinity southern boundary condition, t = 15 00:00:00
(Min = 3.43755679E+01 Max = 3.60665365E+01)
GET_2DFLD - sea surface height climatology, t = 15 00:00:00
(Rec=0000001, Index=2, File: roms_clm.nc)
(Min = -1.79889318E+00 Max = 7.39762271E-01)
GET_3DFLD - potential temperature climatology, t = 15 00:00:00
(Min = 4.91792269E-01 Max = 3.01460773E+01)
GET_3DFLD - salinity climatology, t = 15 00:00:00
(Min = 2.56801249E+01 Max = 4.17132341E+01)
GET_3DFLD - u-momentum component climatology, t = 15 00:00:00
(Min = -4.40144392E+00 Max = 2.00821265E+00)
GET_3DFLD - v-momentum component climatology, t = 15 00:00:00
(Min = -2.35466529E+00 Max = 5.98387303E+00)
2073600 7200 00:00:00 6.657179E-03 1.983058E+04 1.983058E+04 1.331376E+17
(049,120,04) 1.487874E-02 1.754144E-02 0.000000E+00 2.130434E+00
2073601 7200 00:05:00 6.657337E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 1.544012E-03 2.542339E-04 4.158805E-02 2.130946E+00
2073602 7200 00:10:00 6.657279E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 1.618072E-03 2.566145E-04 4.147935E-02 2.131449E+00
2073603 7200 00:15:00 6.657222E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 1.692210E-03 2.589891E-04 4.162542E-02 2.131945E+00
2073604 7200 00:20:00 6.657166E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 1.766415E-03 2.613564E-04 4.175495E-02 2.132434E+00
2073605 7200 00:25:00 6.657114E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 1.840656E-03 2.637183E-04 4.186976E-02 2.132917E+00
2073606 7200 00:30:00 6.657065E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 1.914910E-03 2.660793E-04 4.196979E-02 2.133393E+00
2073607 7200 00:35:00 6.657019E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 1.989153E-03 2.684440E-04 4.205425E-02 2.133864E+00
2073608 7200 00:40:00 6.656976E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 2.063360E-03 2.708149E-04 4.212316E-02 2.134328E+00
2073609 7200 00:45:00 6.656937E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 2.137506E-03 2.731947E-04 4.217677E-02 2.134786E+00
2073610 7200 00:50:00 6.656904E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 2.211564E-03 2.755860E-04 4.221527E-02 2.135238E+00
2073611 7200 00:55:00 6.656876E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 2.285509E-03 2.779929E-04 4.223837E-02 2.135684E+00
2073612 7200 01:00:00 6.656851E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 2.359314E-03 2.804155E-04 4.224591E-02 2.136123E+00
2073613 7200 01:05:00 6.656829E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 2.432957E-03 2.828551E-04 4.223845E-02 2.136556E+00
2073614 7200 01:10:00 6.656758E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 2.506407E-03 2.853158E-04 4.221587E-02 2.136984E+00
2073615 7200 01:15:00 6.656725E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 2.579637E-03 2.877978E-04 4.217745E-02 2.137405E+00
2073616 7200 01:20:00 6.656705E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 2.652623E-03 2.903018E-04 4.212442E-02 2.137821E+00
2073617 7200 01:25:00 6.656688E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 2.725338E-03 2.928300E-04 4.205607E-02 2.138230E+00
2073618 7200 01:30:00 6.656674E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 2.797755E-03 2.953816E-04 4.197241E-02 2.138634E+00
2073619 7200 01:35:00 6.656662E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 2.869846E-03 2.979570E-04 4.187418E-02 2.139032E+00
2073620 7200 01:40:00 6.656655E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 2.941586E-03 3.005571E-04 4.176084E-02 2.139424E+00
2073621 7200 01:45:00 6.656650E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 3.012946E-03 3.031809E-04 4.163239E-02 2.139810E+00
2073622 7200 01:50:00 6.656650E-03 1.983058E+04 1.983059E+04 1.331376E+17
(009,001,14) 3.083901E-03 3.058273E-04 4.148938E-02 2.140191E+00
2073623 7200 01:55:00 6.656652E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.454610E-03 9.443363E-04 3.745806E-02 2.140567E+00
2073624 7200 02:00:00 6.656659E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.465403E-03 9.625368E-04 3.750811E-02 2.140937E+00
2073625 7200 02:05:00 6.656670E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.476181E-03 9.806490E-04 3.755793E-02 2.141301E+00
2073626 7200 02:10:00 6.656685E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.486943E-03 9.986723E-04 3.760737E-02 2.141660E+00
2073627 7200 02:15:00 6.656704E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.497692E-03 1.016606E-03 3.765631E-02 2.142014E+00
2073628 7200 02:20:00 6.656728E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.508429E-03 1.034448E-03 3.770481E-02 2.142363E+00
2073629 7200 02:25:00 6.656758E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.519152E-03 1.052200E-03 3.775291E-02 2.142706E+00
2073630 7200 02:30:00 6.656793E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.529863E-03 1.069860E-03 3.780064E-02 2.143044E+00
2073631 7200 02:35:00 6.656827E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.540561E-03 1.087428E-03 3.784809E-02 2.143376E+00
2073632 7200 02:40:00 6.656861E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.551247E-03 1.104905E-03 3.789529E-02 2.143704E+00
2073633 7200 02:45:00 6.656897E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.561923E-03 1.122290E-03 3.794210E-02 2.144026E+00
2073634 7200 02:50:00 6.656938E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.572591E-03 1.139579E-03 3.798869E-02 2.144343E+00
2073635 7200 02:55:00 6.656981E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.583240E-03 1.156768E-03 3.803383E-02 2.144655E+00
2073636 7200 03:00:00 6.657021E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.593875E-03 1.173854E-03 3.807848E-02 2.144962E+00
2073637 7200 03:05:00 6.657054E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.604492E-03 1.190836E-03 3.812320E-02 2.145264E+00
2073638 7200 03:10:00 6.657111E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.615094E-03 1.207711E-03 3.816828E-02 2.145562E+00
2073639 7200 03:15:00 6.657174E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.625680E-03 1.224479E-03 3.821247E-02 2.145854E+00
2073640 7200 03:20:00 6.657223E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.636247E-03 1.241138E-03 3.825649E-02 2.146142E+00
2073641 7200 03:25:00 6.657263E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.646797E-03 1.257690E-03 3.830077E-02 2.146425E+00
2073642 7200 03:30:00 6.657300E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.657330E-03 1.274154E-03 3.834460E-02 2.146704E+00
2073643 7200 03:35:00 6.657335E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.667849E-03 1.290477E-03 3.838836E-02 2.146978E+00
2073644 7200 03:40:00 6.657369E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.678353E-03 1.306576E-03 3.843208E-02 2.147247E+00
2073645 7200 03:45:00 6.657400E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.688844E-03 1.322424E-03 3.847555E-02 2.147512E+00
2073646 7200 03:50:00 6.657432E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.699320E-03 1.338035E-03 3.851908E-02 2.147773E+00
2073647 7200 03:55:00 6.657460E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.709784E-03 1.353432E-03 3.856306E-02 2.148029E+00
2073648 7200 04:00:00 6.657485E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.720237E-03 1.368645E-03 3.860717E-02 2.148281E+00
2073649 7200 04:05:00 6.657507E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.730682E-03 1.383701E-03 3.865123E-02 2.148529E+00
2073650 7200 04:10:00 6.657526E-03 1.983058E+04 1.983059E+04 1.331376E+17
(046,116,12) 6.741119E-03 1.398627E-03 3.869549E-02 2.148773E+00
2073651 7200 04:15:00 6.657540E-03 1.983058E+04 1.983059E+04 1.331377E+17
(046,116,12) 6.751549E-03 1.413444E-03 3.873993E-02 2.149012E+00
2073652 7200 04:20:00 6.657552E-03 1.983058E+04 1.983059E+04 1.331377E+17
(046,116,12) 6.761978E-03 1.428169E-03 3.878440E-02 2.149247E+00
2073653 7200 04:25:00 6.657559E-03 1.983058E+04 1.983059E+04 1.331377E+17
(046,116,12) 6.772402E-03 1.442818E-03 3.882907E-02 2.149479E+00
2073654 7200 04:30:00 6.657562E-03 1.983058E+04 1.983059E+04 1.331377E+17
(046,116,12) 6.782817E-03 1.457400E-03 3.887415E-02 2.149706E+00
2073655 7200 04:35:00 6.657560E-03 1.983058E+04 1.983059E+04 1.331377E+17
(046,116,12) 6.793223E-03 1.471921E-03 3.891959E-02 2.149929E+00
(202,001,11) 2.888617E-02 4.862884E-02 6.204487E-01 7.496339E+00
2470299 8577 10:15:00 6.040943E-03 1.983051E+04 1.983051E+04 1.331373E+17
(202,001,11) 3.339220E-02 4.967671E-02 6.291463E-01 7.633953E+00
2470300 8577 10:20:00 6.040105E-03 1.983051E+04 1.983051E+04 1.331373E+17
(202,001,11) 3.818249E-02 4.974186E-02 6.454950E-01 7.626223E+00
2470301 8577 10:25:00 6.040885E-03 1.983051E+04 1.983051E+04 1.331373E+17
(202,001,12) 2.547472E-02 5.091943E-02 6.699138E-01 7.960792E+00
2470302 8577 10:30:00 6.041576E-03 1.983051E+04 1.983051E+04 1.331373E+17
(202,001,12) 3.024301E-02 5.375964E-02 6.975454E-01 8.206067E+00
2470303 8577 10:35:00 6.039601E-03 1.983051E+04 1.983051E+04 1.331373E+17
(202,001,12) 3.546282E-02 5.482124E-02 7.282653E-01 8.190405E+00
2470304 8577 10:40:00 6.035539E-03 1.983051E+04 1.983051E+04 1.331373E+17
(202,001,12) 4.073659E-02 5.453751E-02 7.395298E-01 8.156431E+00
2470305 8577 10:45:00 6.038530E-03 1.983051E+04 1.983051E+04 1.331373E+17
(202,001,13) 2.588235E-02 5.491358E-02 7.449321E-01 8.788720E+00
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000003
Elapsed CPU time (seconds):
Node # 0 CPU: 26692.904
number of time records written in HISTORY file = 00000009
number of time records written in RESTART file = 00000118
number of time records written in AVERAGE file = 00000009
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_fsobc.h
Node # 1 CPU: 26851.662
Node # 2 CPU: 26852.670
Node # 3 CPU: 26853.010
Node # 4 CPU: 26853.786
Node # 5 CPU: 26851.866
Node # 6 CPU: 26853.354
Node # 7 CPU: 26851.810
Node # 8 CPU: 26852.258
Node # 9 CPU: 26851.990
Node # 10 CPU: 26852.490
Node # 11 CPU: 26851.142
Node # 12 CPU: 26850.174
Node # 13 CPU: 26852.934
Node # 14 CPU: 26852.166
Node # 15 CPU: 26851.758
Node # 16 CPU: 26852.878
Node # 17 CPU: 26850.930
Node # 18 CPU: 26853.522
Node # 19 CPU: 26852.998
Node # 20 CPU: 26850.710
Node # 21 CPU: 26852.818
Node # 22 CPU: 26851.922
Node # 23 CPU: 26852.970
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_srflux.h
ROMS/TOMS: DONE... Saturday - May 10, 2014 - 2:03:00 AM
Re: Model blown up after 24 Year and 9 months simulation
It is time for a new section of the wiki on model runtime issues: https://www.myroms.org/wiki/index.php/F ... t_Run_Time
Please tell me what I forgot to include.
