is my forcing data right?
shiyf
#1 Unread post by shiyf »
hi,everyone,
I am preparing the forcing data from NCEP dataset which are shflux,swflux,swrad, But i am not sure it is correct,
could you help me,the data are:
swrad get from Downward Solar Radiation Flux at surface minus Upward Solar Radiation Flux
shflux get form -1.0*(net shortwave flux plus net longwaveflux plus Sensible Heat Net Flux plus Latent Heat Net Flux ) which directly download from NCEP
swflux :
% For Evaporation rate: E(m/s)=lhtfl/Llv/rho
% with lhtfl = "mean Daily Latent Heat Net Flux at surface" ;
% Llv = Latent heat of vaporization (approx to 2.5*10^6 J Kg^-1)
% rho = 1025 Kg/m^3
Llv = 2.5*10^6;
rho = 1025; % using a typical value for salty water.
Et=ncep.lhtfl/Llv/rho;
E=Et*100*86400; % to convert to cm/day
Pt=ncep.prate/1000; % to convert to a rate, using 1000 Kg/m^3 as
% density of pure water.
P=Pt*100*86400; % to convert to cm/day
ncep.swflux=E-P;
ncep.desc.swflux ='surface freshwater flux (E-P) cm/day (postive,net evaporation)';
and I want to know that the swrad which got through the above algorithm is the same as net shortwave radiation?
thank you very much!
