BAD TERMINATION (inlet_test)
togye176
#1 Unread post by togye176 »
Dear Members,
I am testing inlet_test case on my workstation.
The compile seems to be done successfully. However, whenever I try to run the case, it is terminated as follows
Please someone help me solve this problem
Coupled Input File name = coupling_inlet_test.in
Model Coupling Parallel Threads:
Ocean Model MPI nodes: 000 - 000
Waves Model MPI nodes: 001 - 001
Ocean Export: bath:SSH:Ubar:Vbar:ZO
Waves Export: Wdir:Wamp:Wlen:Wptop:Wpbot:Wubot
Wednesday - April 16, 2014 - 12:22:52 AM
SWAN is preparing computation ...
Inlet Test Case
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /usr/local/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -I/opt/intelsoft/mct/include -free -free -free
Input Script :
SVN Root URL : https:://myroms.org/svn/src
SVN Revision : 익스포트됨
Local Root : /root/work/ROM/ROM
Header Dir : /root/work/ROM/inlet_test
Header file : inlet_test.h
Analytical Dir: /root/work/ROM/inlet_test
Resolution, Grid 01: 0075x0070x008, Parallel Nodes: 1, Tiling: 001x001
34560 ntimes Number of timesteps for 3-D equations.
5.000 dt Timestep size (s) for 3-D equations.
720 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
720 nHIS Number of timesteps between the writing fields
into history file.
1.0000E-03 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
5.0000E-06 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
for turbulent energy.
1.5000E-02 Zob Bottom roughness (m).
5.0000E-01 Zos Surface roughness (m).
1.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E+00 theta_b S-coordinate bottom control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
T Hout(idBath) Write out time-dependent bathymetry.
T Hout(idUbrs) Write out bottom U-current stress.
T Hout(idVbrs) Write out bottom V-current stress.
T Hout(idUbws) Write out wind-induced, bottom U-wave stress.
T Hout(idVbws) Write out wind-induced, bottom V-wave stress.
T Hout(idUbcs) Write out max wind + current, bottom U-wave stress.
T Hout(idVbcs) Write out max wind + current, bottom V-wave stress.
T Hout(idW2xx) Write out 2D radiation stress, Sxx.
T Hout(idW2xy) Write out 2D radiation stress, Sxy.
T Hout(idW2yy) Write out 2D radiation stress, Syy.
T Hout(idWamp) Write out wave height.
T Hout(idWlen) Write out wavelength.
T Hout(idWdir) Write out wave direction.
T Hout(idBott) Write out bottom property 01: grain_diameter
T Hout(idBott) Write out bottom property 02: grain_density
T Hout(idBott) Write out bottom property 03: settling_vel
T Hout(idBott) Write out bottom property 04: erosion_stress
T Hout(idBott) Write out bottom property 05: ripple_length
T Hout(idBott) Write out bottom property 06: ripple_height
T Hout(idBott) Write out bottom property 07: bed_wave_amp
T Hout(idBott) Write out bottom property 08: Zo_def
T Hout(idBott) Write out bottom property 09: Zo_app
Physical parameters File:
Input Grid File: Data/inlet_test_grid.nc
Tile partition information for Grid 01: 0075x0070x0008 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 75 1 70 42000
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 75.50 0.50 70.50 RHO-points
0 1.00 75.00 0.50 70.50 U-points
0 0.50 75.50 1.00 70.00 V-points
HaloSizeI(1) = 255
HaloSizeJ(1) = 243
TileSide(1) = 79
TileSize(1) = 5925
Sediment Parameters, Grid: 01
Size Sd50 Csed Srho Wsed Erate poros
Class (mm) (kg/m3) (kg/m3) (mm/s) (kg/m2/s) (nondim)
1 1.0000E-01 0.0000E+00 2.6500E+03 1.0000E+01 5.0000E-03 0.0000E+00
tau_ce tau_cd nl_tnu2 nl_tnu4 Akt_bak Tnudg
(N/m2) (N/m2) (m2/s) (m4/s) (m2/s) (day)
1 1.0000E-01 1.0000E-02 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+01
New bed layer formed when deposition exceeds 0.1000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.0000E+00 (m).
Rate coefficient for bed load transport = 0.1500E+00
F LtracerSponge(03Turning OFF sponge on tracer 03: mud_01
F LtracerSrc(03) Turning OFF point sources/Sink on tracer 03: mud_01
F LtracerCLM(03) Turning OFF processing of climatology tracer 03: mud_01
F LnudgeTCLM(03) Turning OFF nudging of climatology tracer 03: mud_01
T Hout(idTvar) Write out sediment01: mud_01
T Hout(idfrac) Write out bed fraction, sediment 01: mudfrac_01
T Hout(idfrac) Write out mass, sediment 01: mudmass_01
T Hout(idSbed) Write out BED property 01: bed_thickness
T Hout(idSbed) Write out BED property 02: bed_age
T Hout(idSbed) Write out BED property 03: bed_porosity
zeta 1 Gradient Closed Gradient Gradient
ubar 1 Gradient Closed Gradient Reduced
vbar 1 Gradient Closed Gradient Reduced
u 1 Gradient Closed Gradient Gradient
v 1 Gradient Closed Gradient Gradient
temp 1 Gradient Closed Gradient Gradient
salt 1 Gradient Closed Gradient Gradient
mud_01 1 Gradient Closed Gradient Gradient
tke 1 Gradient Closed Gradient Gradient
INLET_TEST Inlet Test Case
ANA_BPFLUX Analytical bottom passive tracers fluxes.
ANA_SEDIMENT Analytical sediment initial conditions.
ANA_SPFLUX Analytical surface passive tracer fluxes.
FSOBC_REDUCED Using free-surface data in reduced physics conditions
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
NEARSHORE_MELLOR05 Nearshore Radiation Stress Terms (Mellor 2005).
NONLINEAR Nonlinear Model.
SEDIMENT Cohesive and noncohesive sediments.
SED_MORPH Allow bottom model elevation to evolve.
SUSPLOAD Activate suspended sediment transport.
SSW_BBL Styles and Glenn Bottom Boundary Layer - modified.
SSW_CALC_ZNOT Internal computation of bottom roughness.
SWAN_COUPLING Two-way SWAN/ROMS coupling.
UV_ADV Advection of momentum.
WAVES_OCEAN Two-way wave-ocean models coupling.
Process Information:
Node # 0 (pid= 4963) is active.
8 0.0000000 0.0000000 0.000 0.000 0.000 0.000
7 -0.1250000 -0.1122656 -0.449 0.000 -1.096 -1.742
6 -0.2500000 -0.2350037 -0.940 0.000 -2.294 -3.647
5 -0.3750000 -0.3654529 -1.462 0.000 -3.567 -5.672
4 -0.5000000 -0.5000000 -2.000 0.000 -4.880 -7.760
3 -0.6250000 -0.6345471 -2.538 0.000 -6.193 -9.848
2 -0.7500000 -0.7649963 -3.060 0.000 -7.466 -11.873
1 -0.8750000 -0.8877344 -3.551 0.000 -8.664 -13.778
0 -1.0000000 -1.0000000 -4.000 0.000 -9.760 -15.520
Time Splitting Weights for Grid 01: ndtfast = 20 nfast = 29
3-0.0011514592651645 0.0501156998674241-0.0034654566136460 0.1501639558342179
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649002
5 0.0009829200513762 0.0501919516143856-0.0028561122363360 0.2505291802792858
6 0.0029141799764308 0.0501428056118168 0.0000580677400948 0.3006719858911026
7 0.0054132615310267 0.0499970966129952 0.0054713292711215 0.3506690825040978
8 0.0084687837865132 0.0497264335364439 0.0139401130576347 0.4003955160405417
9 0.0120633394191050 0.0493029943471183 0.0260034524767397 0.4496985103876600
10 0.0161716623600090 0.0486998273761630 0.0421751148367486 0.4983983377638230
11 0.0207585511322367 0.0478912442581626 0.0629336659689853 0.5462895820219856
12 0.0257765478740990 0.0468533167015507 0.0887102138430843 0.5931428987235363
13 0.0311633730493853 0.0455644893078458 0.1198735868924696 0.6387073880313821
14 0.0368391158442262 0.0440063206553765 0.1567127027366958 0.6827137086867585
15 0.0427031802506397 0.0421643648631652 0.1994158829873354 0.7248780735499237
16 0.0486309868367616 0.0400292058506332 0.2480468698240970 0.7649072794005569
17 0.0544704302037591 0.0375976565087951 0.3025173000278562 0.8025049359093520
18 0.0600380921294285 0.0348741349986072 0.3625553921572847 0.8373790709079592
19 0.0651152103984763 0.0318722303921358 0.4276706025557610 0.8692513013000949
20 0.0694434033194839 0.0286164698722119 0.4971140058752449 0.8978677711723068
21 0.0727201499285569 0.0251442997062377 0.5698341558038018 0.9230120708785445
22 0.0745940258796570 0.0215082922098099 0.6444281816834588 0.9445203630883544
23 0.0746596950216180 0.0177785909158270 0.7190878767050768 0.9622989540041814
24 0.0724526566618460 0.0140456061647461 0.7915405333669228 0.9763445601689276
25 0.0674437485167025 0.0104229733316538 0.8589842818836253 0.9867675335005814
26 0.0590334053485720 0.0070507859058187 0.9180176872321973 0.9938183194064002
27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447904
28 0.0292219798521905 0.0017718319739095 0.9937853403740005 0.9996892670186999
29 0.0062146596259994 0.0003107329813000 0.9999999999999999 0.9999999999999999
Minimum X-grid spacing, DXmin = 2.00000000E-01 km
Maximum X-grid spacing, DXmax = 2.00000000E-01 km
Minimum Y-grid spacing, DYmin = 2.00000000E-01 km
Maximum Y-grid spacing, DYmax = 2.00000000E-01 km
Minimum Z-grid spacing, DZmin = 4.49062569E-01 m
Maximum Z-grid spacing, DZmax = 2.08817024E+00 m
Minimum barotropic Courant Number = 1.10736173E-02
Maximum barotropic Courant Number = 2.18124964E-02
Maximum Coriolis Courant Number = 7.29000000E-04
Maximum grid stiffness ratios: rx0 = 3.846154E-02 (Beckmann and Haidvogel)
rx1 = 6.467265E-01 (Haney)
Initial basin volumes: TotVolume = 1.4345600000E+09 m3
MinVolume = 1.7962502760E+04 m3
MaxVolume = 8.1804607218E+04 m3
Max/Min = 4.5541875935E+00
OCN2WAV - (06) imported and (05) exported fields, t = 0 00:00:00
- ROMS coupling exchanges wait clock (s):
(Recv= 1.49577300E+00 Send= 1.00000000E-03)
- ROMS Import: wave direction
(Min= 0.00000000E+00 Max= 0.00000000E+00)
- ROMS Import: significant wave height
(Min= 0.00000000E+00 Max= 2.00687870E-02)
- ROMS Import: average wave length
(Min= 0.00000000E+00 Max= 3.12006474E+00)
- ROMS Import: surface wave relative peak period
(Min= 0.00000000E+00 Max= 1.90365362E+00)
- ROMS Import: bottom wave period
- ROMS Import: wave bottom orbital velocity
- ROMS Export: bathymetry
(Min= 4.00000000E+00 Max= 1.55200000E+01)
- ROMS Export: free-surface
- ROMS Export: vertically integrated u-momentum component
- ROMS Export: vertically integrated v-momentum component
- ROMS Export: bottom roughness
(Min= 1.00000000E-04 Max= 1.00000000E-04)
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00034560)
WAV2OCN - (05) imported and (06) exported fields, t = 20000101.000000
- SWAN coupling exchanges wait clock (s):
(Recv= 1.00000000E-03 Send= 0.00000000E+00)
0 0 00:00:00 0.000000E+00 4.346400E+01 4.346400E+01 1.444800E+09
(00,00,0) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
1 0 00:00:05 4.188874E-09 4.346400E+01 4.346400E+01 1.444800E+09
(33,35,8) 1.830471E-10 8.568321E-06 0.000000E+00 3.428109E-04
2 0 00:00:10 1.048059E-09 4.346400E+01 4.346400E+01 1.444800E+09
(32,36,8) 1.815309E-08 7.619639E-07 1.259340E-05 1.085245E-04
3 0 00:00:15 1.652892E-09 4.346399E+01 4.346399E+01 1.444800E+09
(44,34,7) 2.159609E-08 8.100980E-07 1.740382E-05 2.425222E-04
4 0 00:00:20 3.438064E-09 4.346396E+01 4.346396E+01 1.444799E+09
(01,70,8) 4.621740E-22 9.005123E-06 4.995121E-05 4.298072E-04
5 0 00:00:25 7.466462E-09 4.346390E+01 4.346390E+01 1.444799E+09
(01,70,8) 4.780853E-22 1.410838E-05 1.001071E-04 6.719918E-04
6 0 00:00:30 1.504295E-08 4.346381E+01 4.346381E+01 1.444797E+09
(01,70,8) 4.939886E-22 2.068529E-05 1.558654E-04 9.628303E-04
7 0 00:00:35 2.788338E-08 4.346368E+01 4.346368E+01 1.444796E+09
(01,70,8) 5.098832E-22 2.873575E-05 2.107313E-04 1.298652E-03
8 0 00:00:40 4.820968E-08 4.346352E+01 4.346352E+01 1.444793E+09
(01,70,8) 5.257660E-22 3.818063E-05 2.593547E-04 1.677025E-03
9 0 00:00:45 7.872119E-08 4.346332E+01 4.346332E+01 1.444791E+09
(01,70,8) 5.416359E-22 4.886307E-05 2.983127E-04 2.095224E-03
10 0 00:00:50 1.224323E-07 4.346308E+01 4.346308E+01 1.444787E+09
(Min= -2.80699020E-02 Max= 1.52347293E+00)
(Min= 1.50000000E-03 Max= 1.50000000E-03)
WAV2OCN - (05) imported and (06) exported fields, t = 20000101.004600
553 0 00:46:05 1.404862E-02 4.210121E+01 4.211526E+01 1.397104E+09
(43,34,7) 3.080130E-02 2.884473E-02 2.854822E-02 1.770862E+00
554 0 00:46:10 1.410290E-02 4.209954E+01 4.211364E+01 1.397024E+09
(43,34,6) 3.265176E-02 2.854275E-02 2.171048E-02 1.796062E+00
555 0 00:46:15 1.415746E-02 4.209788E+01 4.211204E+01 1.396944E+09
(43,34,7) 3.232283E-02 2.891264E-02 1.016905E-02 1.770801E+00
556 0 00:46:20 1.421223E-02 4.209623E+01 4.211044E+01 1.396865E+09
(43,34,6) 3.271962E-02 2.863249E-02 1.311072E-02 1.775483E+00
557 0 00:46:25 1.426692E-02 4.209459E+01 4.210886E+01 1.396785E+09
(43,34,7) 3.266177E-02 2.899868E-02 1.230340E-02 1.782253E+00
558 0 00:46:30 1.432153E-02 4.209297E+01 4.210729E+01 1.396705E+09
(43,34,7) 3.283983E-02 2.903181E-02 1.213627E-02 1.790798E+00
559 0 00:46:35 1.437606E-02 4.209135E+01 4.210573E+01 1.396626E+09
(43,34,7) 3.301345E-02 2.906513E-02 1.209292E-02 1.798722E+00
560 0 00:46:40 1.443048E-02 4.208975E+01 4.210418E+01 1.396546E+09
(43,34,7) 3.317994E-02 2.909934E-02 1.217016E-02 1.806090E+00
561 0 00:46:45 1.448482E-02 4.208816E+01 4.210264E+01 1.396466E+09
(43,34,7) 3.333991E-02 2.913453E-02 1.231081E-02 1.813048E+00
562 0 00:46:50 1.453905E-02 4.208657E+01 4.210111E+01 1.396387E+09
(43,34,7) 3.349292E-02 2.917069E-02 1.245728E-02 1.819617E+00
563 0 00:46:55 1.459319E-02 4.208500E+01 4.209959E+01 1.396307E+09
(43,34,7) 3.363899E-02 2.920784E-02 1.256182E-02 1.825842E+00
564 0 00:47:00 1.464721E-02 4.208343E+01 4.209808E+01 1.396228E+09
(43,34,7) 3.377848E-02 2.924591E-02 1.258581E-02 1.831766E+00
565 0 00:47:05 1.470115E-02 4.208188E+01 4.209658E+01 1.396148E+09
(43,34,7) 3.391098E-02 2.928481E-02 1.250750E-02 1.837378E+00
566 0 00:47:10 1.475498E-02 4.208033E+01 4.209508E+01 1.396068E+09
(43,34,7) 3.403756E-02 2.932445E-02 1.232179E-02 1.842757E+00
567 0 00:47:15 1.480873E-02 4.207878E+01 4.209359E+01 1.395988E+09
(43,34,7) 3.415774E-02 2.936473E-02 1.203968E-02 1.847866E+00
568 0 00:47:20 1.486238E-02 4.207725E+01 4.209211E+01 1.395908E+09
(43,34,7) 3.427292E-02 2.940560E-02 1.168742E-02 1.852803E+00
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= EXIT CODE: 9
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Killed (signal 9)
This typically refers to a problem with your application.
Please see the FAQ page for debugging suggestions
log.txt
(148.92 KiB) Downloaded 408 times
togye176
Re: BAD TERMINATION (inlet_test)
#2 Unread post by togye176 »
According to some replies for this problem, it seems to be due to the lack of physical memory.
I am trying to run this model both UNIX operated by university and my personal workstation.
And, this error appeared only at my workstation which has 16 cores and 32 GB RAM.
Is this capacity not sufficient to run the model?
#3 Unread post by kate »
That seems like a lot of memory. Do you have per process limits to how much of it you can use?
togye176
#4 Unread post by togye176 »
kate wrote:That seems like a lot of memory. Do you have per process limits to how much of it you can use?
Thank you Kate,
But, I cannot understand what are you saying. How can I check it (sorry I am beginner for both ROM and Linux).
FYI, I attached 'ulimit' results
core file size (blocks, -c) 0
data seg size (kbytes, -d) unlimited
scheduling priority (-e) 0
file size (blocks, -f) unlimited
pending signals (-i) 255823
max locked memory (kbytes, -l) 64
max memory size (kbytes, -m) unlimited
open files (-n) 1024
pipe size (512 bytes, -p) 8
POSIX message queues (bytes, -q) 819200
real-time priority (-r) 0
stack size (kbytes, -s) unlimited
cpu time (seconds, -t) unlimited
max user processes (-u) 255823
virtual memory (kbytes, -v) unlimited
file locks (-x) unlimited
