Problem restarting ROMS in COAWST (WRF-ROMS coupling)
nicholls
#1 Unread post by nicholls »
Hello everyone,
I am a COAWST model user running a WRF-ROMS coupling configuration. I am currently testing whether I can start, stop, and restart the COAWST model. Specifically I am running two six hours segments. The first starts at model initialization, and the second from a restart time six hours later (via an ocean_rst.nc file). The first segment runs perfectly, but in the latter, ROMS successfully reads the restart file and I changed NRREC in roms.namelist.in from 0 to -1, but ROMS fails because it tries to find a file ocean_avg_0000.nc. I hope this is a newbie question, but I am confused as to why ROMS would look for this file to restart itself. From the ROMS users' guide, my understanding was that all I needed to do was to change ININAME to ocean_rst.nc, change NRREC to -1, and increase NTIMES to the end time of the next period (i.e., 4120, I am running a time step of 10 seconds), so I am at a loss to find an explanation as to why ROMS would look for an ocean_avg file. Even when I renamed my ocean_avg_0001 file to ocean_avg_0000, the ROMS read the ocean_avg file but then failed there after because ROMS then said it was also missing a ocean_dia_0000.nc file. Considering that in my roms.namelist.in file I set NDEFAVG = 2160 (or six hours), it does not make sense to me why ROMS would look for ocean_avg_0000, when I do correctly generate a file ocean_avg_0001.nc. For reference I am using COAWST rev 727 and ROMS version 455 and I have attached my error and ROMS configuration files to this message.
Thanks for your time and consideration of this post.
--Stephen Nicholls
ROMS error output (subsection containing first error)
Maximum grid stiffness ratios: rx0 = 8.938246E-01 (Beckmann and Haidvogel)
rx1 = 1.373953E+01 (Haney)
Initial basin volumes: TotVolume = 2.3137323492E+17 m3
MinVolume = 1.5508442673E+07 m3
MaxVolume = 1.6246901264E+11 m3
Max/Min = 1.0476165535E+04
ROMS recv data from WRF
ROMS sent data to WRF
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00017286)
GRID STEP Day HH:MM:SS KINETIC_ENRG POTEN_ENRG TOTAL_ENRG NET_VOLUME
1 0 1 00:00:00 5.227080E-03 2.075019E+04 2.075020E+04 2.314783E+17
DEF_AVG - inquiring average file: ocean_avg_0000.nc
ocean_avg_0000.nc
call from: def_avg.F
ROMS/TOMS - Output error ............ exit_flag: 3
Elapsed CPU time (seconds):
Node # 0 CPU: 24.722
Node # 1 CPU: 28.402
wrf.error.txt
Error output from WRF model
(72.71 KiB) Downloaded 295 times
roms.namelist.in
namelist configuration file for ROMS
(61.07 KiB) Downloaded 312 times
roms.error.txt
Error output from ROMS model
(169.81 KiB) Downloaded 302 times
noreaster.h
ROMS parameterization configuration file
(4.07 KiB) Downloaded 306 times
Re: Problem restarting ROMS in COAWST (WRF-ROMS coupling)
i see your post on the coawst site, so i will answer it there. think this might just be a ROMS issue with restarting.
-john
nicholls
#3 Unread post by nicholls »
Following your suggestion from John Warner, I recompiled COAWST with the changes seen below to my .h file. With these
changes, ROMS no long demands the ocean_avg_0000.nc or ocean_dia_0000.nc. Without these demands, I managed to get COAWST to restart successfully. That said, this problem has been resolved. Thanks John for the help!
--Stephen
old:
#define DIAGNOSTICS_UV
#define DIAGNOSTICS_TS
new:
#undef AVERAGES
#undef DIAGNOSTICS_UV
#undef DIAGNOSTICS_TS
balaji
#4 Unread post by balaji »
Hi everyone....
I'm new to this forum..
I have written mail to JC Warner regarding the address to download the Model COAWST..
I have no idea that whether my mail have reached him...
Please help me on this issue..
How to get access to download COAWST model ...
Thanks in advance
