Problem with compact Fennel Rad+Nud boundaries
m.hadfield
These days, boundary conditions for biological tracers (Fennel model) are set in a file like ROMS/External/bio_Fennel.in, which has the following comment
! NOTICE: It is possible to specify the lateral boundary conditions for
! ======  all biological tracers in a compact form with a single entry.
! If so, all the biological tracers are assumed to have the same boundary
! condition as in the single entry.
although the entries below in the same file use the non-compact form:
   LBC(isTvar) ==   Per     Clo     Per     Clo \    ! idbio( 1), NO3
                    Per     Clo     Per     Clo \    ! idbio( 2), NH4
                    Per     Clo     Per     Clo \    ! idbio( 3), chlorophyll
                    Per     Clo     Per     Clo \    ! idbio( 4), phytoplankton
I recently set up a simulation with the simple, 7-component Fennel model and--being an adventurous but trusting soul--specified Rad+Nud boundary conditions all round with the compact form, thus:
   LBC(isTvar) ==   RadNud  RadNud  RadNud  RadNud \    ! idbio(*)
ROMS did assign Rad+Nud conditions to all the biological tracers, as intended, as this output from the log file indicates...
 NO3                      1   Rad + Nud    Rad + Nud    Rad + Nud    Rad + Nud
 NH4                      1   Rad + Nud    Rad + Nud    Rad + Nud    Rad + Nud
 chlorophyll              1   Rad + Nud    Rad + Nud    Rad + Nud    Rad + Nud
 phytoplankton            1   Rad + Nud    Rad + Nud    Rad + Nud    Rad + Nud
 zooplankton              1   Rad + Nud    Rad + Nud    Rad + Nud    Rad + Nud
 LdetritusN               1   Rad + Nud    Rad + Nud    Rad + Nud    Rad + Nud
 SdetritusN               1   Rad + Nud    Rad + Nud    Rad + Nud    Rad + Nud
...but the only tracer for which GET_NGFLD was called to read in boundary values was the first one, NO3. For all the others, GET_NGFLD is not called, and the simulation appears to proceed with zero values at the boundary.
I did a bit of light debugging and found that in ROMS/Nonlinear/get_data.F, at lines 813-836, there is a series of tests like this
        DO i=1,NT(ng)
          IF (LBC(iwest,isTvar(i),ng)%acquire) THEN
            CALL get_ngfld (ng, iNLM, idTbry(iwest,i), BRY(ng)%ncid,    &
     &                      1, BRY(ng), update(1),                      &
     &                      JLB, JUB, N(ng), 2, 0, Mm(ng)+1, N(ng),     &
     &                      BOUNDARY(ng) % tG_west(:,:,:,i))
I printed out hte values of the acquire tag: it is TRUE for tracers 1, 2 and 3 (temp, salt and NO3) but FALSE for all the rest. Consequently they are not read. I had a look at the code that sets the acquire tag and decided it looks a bit gnarly for me right now.
I have worked around the problem by using a non-compact specification of the boundaries.
m.hadfield
Re: Problem with compact Fennel Rad+Nud boundaries
m.hadfield wrote: I recently set up a simulation with the simple, 7-component Fennel model and--being an adventurous but trusting soul--specified Rad+Nud boundary conditions all round with the compact form, thus:
Hmmm. I wonder if the trailing backslash on that line might be the source of the problem?!
5 minutes later: Nope. Trailing backslash removed, compact form still broken.
