Hi,everyone
I'm confused about the difference between climatology and the open boundary in ROMS.In my opinion, when run a model you only need the initial condition, force and boundary condition, so what role does the climatolgy play? If I get the open boundary and climatology files from the same data, is it still necessary to define both of them?
Any answer is appreciated,
Thank you.
The difference between climatology and open boundary?
Re: The difference between climatology and open boundary?
You are right - you might not need climatology. I would certainly try your run without it first. However, the option is there should you decide to try it later. We have one domain where adding a band of climatology nudging around the edge helped the boundary conditions.
