Blowing up at the beginning
ljd
#1 Unread post by ljd »
I meet with blowing up at the beginning of the model, can someone help me to find the problem?
Thanks a lot.
1296000 ntimes Number of timesteps for 3-D equations.
1200.000 dt Timestep size (s) for 3-D equations.
120 ndtfast Number of timesteps for 2-D equations between
1 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
into history file.
72 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
72 nAVG Number of timesteps between the writing of
72 ndefAVG Number of timesteps between creation of new
time-averaged file.
2.0000E+01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
2.0000E+01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
5.0000E+01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
1 lmd_Jwt Jerlov water type.
3.0000E+00 theta_s S-coordinate surface control parameter.
3.0000E-01 theta_b S-coordinate bottom control parameter.
50.000 Tcline S-coordinate surface/bottom layer width (m) used
-1.00 time_ref Reference time for units attribute (yyyymmdd.dd)
9.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
9.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
9.0000E+01 Znudg Nudging/relaxation time scale (days)
9.0000E+01 M2nudg Nudging/relaxation time scale (days)
9.0000E+01 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.0000E+01 obcfac Factor between passive and active
T VolCons(2) NLM southern edge boundary volume conservation.
T VolCons(3) NLM eastern edge boundary volume conservation.
T LtracerCLM(01) Turning ON processing of climatology tracer 01: temp
T LtracerCLM(02) Turning ON processing of climatology tracer 02: salt
T Hout(idu3dE) Write out 3D U-wastward component at RHO-points.
T Hout(idv3dN) Write out 3D V-northward component at RHO-points.
T Hout(idHsbl) Write out depth of surface boundary layer.
T Aout(idu3dE) Write out averaged 3D U-eastward at RHO-points.
T Aout(idv3dN) Write out averaged 3D V-northward at RHO-points.
T Aout(idHsbl) Write out averaged depth of surface boundary layer.
Output Restart File: /public/userspace/ljd/IO_d10/IO_rst_d10.nc
Prefix for History Files: /public/userspace/ljd/IO_d10/IO_his_d10
Prefix for Averages Files: /public/userspace/ljd/IO_d10/IO_avg_d10
Input Grid File: IO_grd_d10.nc
Input Nonlinear Initial File: IO_ini_d10.nc
Input Forcing File 01: IO_frc_d10_01.nc
IO_frc_d10_02.nc
IO_frc_d10_03.nc
IO_frc_d10_04.nc
IO_frc_d10_05.nc
IO_frc_d10_06.nc
IO_frc_d10_07.nc
IO_frc_d10_08.nc
IO_frc_d10_09.nc
IO_frc_d10_10.nc
IO_frc_d10_11.nc
IO_frc_d10_12.nc
Input Climatology File: IO_clm_d10_TSUVZ.nc
Input Boundary File: IO_bry_d10.nc
Tile partition information for Grid 01: 0799x0629x0040 tiling: 016x012
tile Istr Iend Jstr Jend Npts
0 1 50 1 50 100000
1 51 100 1 50 100000
2 101 150 1 50 100000
3 151 200 1 50 100000
4 201 250 1 50 100000
5 251 300 1 50 100000
6 301 350 1 50 100000
HaloSizeI(1) = 124
HaloSizeJ(1) = 130
TileSide(1) = 59
TileSize(1) = 3304
zeta 1 Closed Chapman Imp Chapman Imp Closed
ubar 1 Closed Flather Flather Closed
vbar 1 Closed Flather Flather Closed
u 1 Closed Rad + Nud Rad + Nud Closed
v 1 Closed Rad + Nud Rad + Nud Closed
temp 1 Closed Rad + Nud Rad + Nud Closed
salt 1 Closed Rad + Nud Rad + Nud Closed
IO_D10 Control run for the Indian Ocean, 1/10*1/10 deg
LMD_CONVEC LMD convective mixing due to shear instability.
LMD_MIXING Large/McWilliams/Doney interior mixing.
LMD_RIMIX LMD diffusivity due to shear instability.
LMD_SKPP KPP surface boundary layer mixing.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
40 0.0000000 0.0000000 0.000 0.000 0.000 0.000
39 -0.0250000 -0.0076503 -1.250 -1.250 -26.133 -51.016
38 -0.0500000 -0.0156736 -2.500 -2.500 -53.479 -104.459
37 -0.0750000 -0.0241410 -3.750 -3.750 -82.270 -160.790
36 -0.1000000 -0.0331262 -5.000 -5.000 -112.745 -220.490
35 -0.1250000 -0.0427053 -6.250 -6.250 -145.151 -284.053
34 -0.1500000 -0.0529559 -7.500 -7.500 -179.742 -351.984
33 -0.1750000 -0.0639559 -8.750 -8.750 -216.770 -424.791
32 -0.2000000 -0.0757823 -10.000 -10.000 -256.486 -502.972
31 -0.2250000 -0.0885086 -11.250 -11.250 -299.129 -587.009
30 -0.2500000 -0.1022034 -12.500 -12.500 -344.922 -677.345
29 -0.2750000 -0.1169269 -13.750 -13.750 -394.061 -774.373
28 -0.3000000 -0.1327288 -15.000 -15.000 -446.708 -878.416
27 -0.3250000 -0.1496453 -16.250 -16.250 -502.980 -989.710
26 -0.3500000 -0.1676968 -17.500 -17.500 -562.943 -1108.387
25 -0.3750000 -0.1868861 -18.750 -18.750 -626.608 -1234.466
24 -0.4000000 -0.2071978 -20.000 -20.000 -693.923 -1367.845
23 -0.4250000 -0.2285984 -21.250 -21.250 -764.779 -1508.309
22 -0.4500000 -0.2510387 -22.500 -22.500 -839.018 -1655.535
21 -0.4750000 -0.2744569 -23.750 -23.750 -916.437 -1809.124
20 -0.5000000 -0.2987836 -25.000 -25.000 -996.811 -1968.621
19 -0.5250000 -0.3239476 -26.250 -26.250 -1079.908 -2133.566
18 -0.5500000 -0.3498824 -27.500 -27.500 -1165.512 -2303.525
17 -0.5750000 -0.3765328 -28.750 -28.750 -1253.444 -2478.138
16 -0.6000000 -0.4038607 -30.000 -30.000 -1343.580 -2657.159
15 -0.6250000 -0.4318501 -31.250 -31.250 -1435.867 -2840.484
14 -0.6500000 -0.4605110 -32.500 -32.500 -1530.338 -3028.176
13 -0.6750000 -0.4898810 -33.750 -33.750 -1627.116 -3220.482
12 -0.7000000 -0.5200268 -35.000 -35.000 -1726.417 -3417.833
11 -0.7250000 -0.5510432 -36.250 -36.250 -1828.549 -3620.848
10 -0.7500000 -0.5830519 -37.500 -37.500 -1933.909 -3830.319
9 -0.7750000 -0.6162000 -38.750 -38.750 -2042.975 -4047.201
8 -0.8000000 -0.6506573 -40.000 -40.000 -2156.300 -4272.599
7 -0.8250000 -0.6866143 -41.250 -41.250 -2274.502 -4507.754
6 -0.8500000 -0.7242808 -42.500 -42.500 -2398.264 -4754.029
5 -0.8750000 -0.7638835 -43.750 -43.750 -2528.324 -5012.899
4 -0.9000000 -0.8056655 -45.000 -45.000 -2665.473 -5285.946
3 -0.9250000 -0.8498858 -46.250 -46.250 -2810.552 -5574.854
2 -0.9500000 -0.8968188 -47.500 -47.500 -2964.454 -5881.408
1 -0.9750000 -0.9467546 -48.750 -48.750 -3128.123 -6207.496
0 -1.0000000 -1.0000000 -50.000 -50.000 -3302.557 -6555.114
Time Splitting Weights for Grid 01: ndtfast = 120 nfast = 162
ndtfast, nfast = 120 162 nfast/ndtfast = 1.35000
1.000000000000 1.016453155986 0.508226577993 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.26033
Minimum X-grid spacing, DXmin = 9.61983482E+00 km
Maximum X-grid spacing, DXmax = 1.11132834E+01 km
Minimum Y-grid spacing, DYmin = 9.62858029E+00 km
Maximum Y-grid spacing, DYmax = 1.11132783E+01 km
Minimum Z-grid spacing, DZmin = 1.25000000E+00 m
Maximum Z-grid spacing, DZmax = 3.47617667E+02 m
Minimum barotropic Courant Number = 2.81833239E-02
Maximum barotropic Courant Number = 3.42277905E-01
Maximum Coriolis Courant Number = 8.73901467E-02
(Grid 01, File: IO_ini_d10.nc, Rec=0001, Index=1)
- free-surface
(Min = -1.65856037E-01 Max = 1.09070785E+00)
- u-momentum component
(Min = -7.12925634E-01 Max = 7.55215659E-01)
- v-momentum component
(Min = -7.72852753E-01 Max = 7.65704231E-01)
- potential temperature
(Min = 5.25969674E-02 Max = 2.98913774E+01)
- salinity
(Min = 2.12743881E+00 Max = 4.07141128E+01)
GET_2DFLD - surface u-momentum stress, t = 30 00:00:00
(Rec=0000030, Index=1, File: IO_frc_d10_01.nc)
(Tmin= 1.0000 Tmax= 30.0000)
(Min = -3.34676881E-04 Max = 4.07706802E-04)
GET_2DFLD - surface v-momentum stress, t = 30 00:00:00
(Min = -2.24989736E-04 Max = 2.88494194E-04)
GET_2DFLD - solar shortwave radiation flux, t = 30 00:00:00
(Min = 2.57790513E-05 Max = 7.66878176E-05)
GET_2DFLD - surface net heat flux, t = 30 00:00:00
(Min = -5.53345135E-05 Max = 3.85001502E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 30 00:00:00
(Min = -1.88254621E-07 Max = 9.84993660E-08)
GET_NGFLD - free-surface eastern boundary condition, t = 356 00:00:00
(Rec=0000072, Index=2, File: IO_bry_d10.nc)
(Tmin= 1.0000 Tmax= 356.0000)
(Min = 9.16177432E-02 Max = 8.75259395E-01)
GET_NGFLD - free-surface southern boundary condition, t = 356 00:00:00
(Min = 7.29231921E-02 Max = 7.42595725E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 356 00:00:00
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 356 00:00:00
(Min = -2.83704406E-01 Max = 7.63229013E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 356 00:00:00
GET_NGFLD - 2D v-momentum southern boundary condition, t = 356 00:00:00
(Min = -2.64802093E-01 Max = 6.51729572E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 356 00:00:00
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 356 00:00:00
(Min = -7.15777892E-01 Max = 1.10803898E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 356 00:00:00
GET_NGFLD - 3D v-momentum southern boundary condition, t = 356 00:00:00
(Min = -3.84782651E-01 Max = 9.38375501E-02)
GET_NGFLD - temperature eastern boundary condition, t = 356 00:00:00
(Min = 6.58606760E-01 Max = 2.96212242E+01)
GET_NGFLD - salinity eastern boundary condition, t = 356 00:00:00
(Min = 2.48901541E+01 Max = 3.57507704E+01)
GET_NGFLD - temperature southern boundary condition, t = 356 00:00:00
(Min = 4.04895103E-01 Max = 2.52432386E+01)
GET_NGFLD - salinity southern boundary condition, t = 356 00:00:00
(Min = 3.43807778E+01 Max = 3.58496595E+01)
GET_3DFLD - potential temperature climatology, t = 271 00:00:00
(Rec=0000004, Index=1, File: IO_clm_d10_TSUVZ.nc)
(Tmin= 1.0000 Tmax= 271.0000)
(Min = 5.98539002E-02 Max = 3.09193401E+01)
GET_3DFLD - salinity climatology, t = 271 00:00:00
(Min = 2.12883019E+00 Max = 4.07080536E+01)
Maximum grid stiffness ratios: rx0 = 2.087711E-01 (Beckmann and Haidvogel)
rx1 = 9.239405E+00 (Haney)
Initial basin volumes: TotVolume = 1.3422006839E+17 m3
MinVolume = 1.1592918981E+08 m3
MaxVolume = 4.1624495376E+10 m3
Max/Min = 3.5905103317E+02
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 01296000)
GET_2DFLD - surface u-momentum stress, t = 1 00:00:00
(Rec=0000001, Index=2, File: IO_frc_d10_01.nc)
(Min = -3.95970791E-04 Max = 3.27253677E-04)
GET_2DFLD - surface v-momentum stress, t = 1 00:00:00
(Min = -3.27691439E-04 Max = 2.14956658E-04)
GET_2DFLD - solar shortwave radiation flux, t = 1 00:00:00
(Min = 2.25483297E-05 Max = 7.95320454E-05)
GET_2DFLD - surface net heat flux, t = 1 00:00:00
(Min = -5.94075649E-05 Max = 4.05880867E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 1 00:00:00
(Min = -1.70621406E-07 Max = 9.32263919E-08)
GET_NGFLD - free-surface eastern boundary condition, t = 1 00:00:00
(Rec=0000001, Index=1, File: IO_bry_d10.nc)
(Min = 1.09218201E-01 Max = 8.56462430E-01)
GET_NGFLD - free-surface southern boundary condition, t = 1 00:00:00
(Min = 8.11142240E-02 Max = 7.40974584E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 1 00:00:00
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 1 00:00:00
(Min = -2.72014740E-01 Max = 8.39977933E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 1 00:00:00
GET_NGFLD - 2D v-momentum southern boundary condition, t = 1 00:00:00
(Min = -2.63939739E-01 Max = 5.91890203E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 1 00:00:00
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 1 00:00:00
(Min = -6.70640665E-01 Max = 1.22306183E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 1 00:00:00
GET_NGFLD - 3D v-momentum southern boundary condition, t = 1 00:00:00
(Min = -3.81899509E-01 Max = 8.58668860E-02)
GET_NGFLD - temperature eastern boundary condition, t = 1 00:00:00
(Min = 6.58755465E-01 Max = 2.94668588E+01)
GET_NGFLD - salinity eastern boundary condition, t = 1 00:00:00
(Min = 2.48780853E+01 Max = 3.57520208E+01)
GET_NGFLD - temperature southern boundary condition, t = 1 00:00:00
(Min = 4.08595854E-01 Max = 2.55525390E+01)
GET_NGFLD - salinity southern boundary condition, t = 1 00:00:00
(Min = 3.43756636E+01 Max = 3.58334744E+01)
GET_3DFLD - potential temperature climatology, t = 1 00:00:00
(Rec=0000001, Index=2, File: IO_clm_d10_TSUVZ.nc)
(Min = 5.79100773E-02 Max = 2.97284260E+01)
GET_3DFLD - salinity climatology, t = 1 00:00:00
(Min = 2.12750411E+00 Max = 4.07142143E+01)
0 0 00:00:00 7.816705E-04 2.102642E+04 2.102642E+04 1.351798E+17
(114,286,36) 7.585973E-02 7.725372E-02 0.000000E+00 1.001434E+00
DEF_HIS - creating history file, Grid 01: /public/userspace/ljd/IO_d10/IO_his_d10_0001.nc
1 0 00:20:00 7.853795E-04 2.102642E+04 2.102642E+04 1.351798E+17
(427,355,22) 9.046983E-03 1.832398E-02 3.615468E-01 1.001033E+00
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000001
2 0 00:40:00 7.884234E-04 2.102643E+04 2.102643E+04 1.351798E+17
(093,251,40) 5.191574E-03 3.447813E-03 1.963723E+00 1.002399E+00
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000002
3 0 01:00:00 7.909288E-04 2.102643E+04 2.102643E+04 1.351798E+17
(017,011,40) 2.232034E-02 7.210791E-03 1.492642E+00 1.002914E+00
4 0 01:20:00 7.933181E-04 2.102643E+04 2.102643E+04 1.351798E+17
(017,011,40) 1.075373E-02 1.031695E-03 1.974933E+00 1.005651E+00
5 0 01:40:00 7.955499E-04 2.102643E+04 2.102643E+04 1.351798E+17
(093,238,40) 4.780234E-03 2.868451E-04 1.005678E+00 1.005552E+00
6 0 02:00:00 7.977047E-04 2.102643E+04 2.102643E+04 1.351798E+17
(090,250,40) 1.649237E-02 1.200453E-02 1.148647E+00 1.003872E+00
7 0 02:20:00 7.999087E-04 2.102643E+04 2.102643E+04 1.351798E+17
(090,250,40) 4.511523E-03 1.395434E-02 1.543594E+00 1.001765E+00
8 0 02:40:00 8.023086E-04 2.102644E+04 2.102644E+04 1.351798E+17
(090,250,40) 1.885090E-02 9.810953E-04 1.732885E+00 1.006152E+00
9 0 03:00:00 8.047665E-04 2.102644E+04 2.102644E+04 1.351798E+17
(109,294,40) 1.139387E-02 2.705044E-03 9.080376E-01 1.003519E+00
10 0 03:20:00 8.074709E-04 2.102644E+04 2.102644E+04 1.351798E+17
(088,512,06) 6.383354E-02 5.553126E-02 9.530703E-01 1.004710E+00
11 0 03:40:00 8.110126E-04 2.102644E+04 2.102644E+04 1.351798E+17
(088,512,07) 6.624754E-02 5.991228E-02 1.224564E+00 1.019313E+00
12 0 04:00:00 8.154429E-04 2.102644E+04 2.102644E+04 1.351798E+17
(088,512,07) 7.194483E-02 5.467485E-02 1.655688E+00 1.168393E+00
13 0 04:20:00 8.207404E-04 2.102644E+04 2.102644E+04 1.351798E+17
(090,512,11) 5.065749E-03 1.447481E-02 2.383933E+00 1.304853E+00
14 0 04:40:00 8.288798E-04 2.102645E+04 2.102645E+04 1.351798E+17
(090,512,12) 1.696763E-02 4.843554E-02 3.511587E+00 1.659252E+00
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000003
number of time records written in RESTART file = 00000014
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/TOMS: DONE... Thursday - April 3, 2014 - 12:23:49 PM
real 452.72
user 5805.97
sys 1272.95
+ exit 0
Re: Blowing up at the beginning
Have you tried a smaller timestep? Does it run longer?
Have you looked at the restart file to see how and where it's blowing up?
