I am trying to model the transport of sediment discharged from a small river (flux ~10m^3/s) into ocean, which possibly has some radioactivity. Attached picture shows the bathymetry around the river mouth.
By preliminary calculations we have identified the dominant mechanisms of transport:
1: wave-induced suspension
2: wind-induced current
Other factors, such as off-shore current, tidal current, and river plume current are negligible.
Since the amount of sediment is very small and does not change the bathymetry, we don't need strong-coupling between ROMS and SWAN, as in the inlet_test case. Instead, we'd like to read the UBOT data of SWAN (stationary calculation) result and simulate the transport of sediment in ROMS.
My question is: is it possible to read bottom orbital velocity data at the startup and incorporate it to the sediment transport simulation?
Thanks in advance.
Using SWAN result as an initial input data
- a.png (92.71 KiB) Viewed 4114 times
Re: Using SWAN result as an initial input data
You can use swan outputs to drive roms, without direct coupling. Here is an m file that reads swan mat files and creates a roms netcdf forcing file. let me know if you have any questions.
-john
-john
swanmat2roms.m
- (11.28 KiB) Downloaded 437 times
Thank you very much.
Unfortunately none of my colleagues has MATLAB license, so I'll search some compatible tools.
I think you can rewrite a similar script for python, where you import .mat using scipy.io. It will be a fair bit of work but you can use that script for many runs.
Cheers
nikhil
Cheers
nikhil
