A benchmark case for tide
feroda
#1 Unread post by feroda »
In SVN repository, various cases are collected in the folder of '/test'.
I wanted to setup a 2-dimension run solely forced by tide. By looking through the 'test' folder, I did not find any case for reference.
I am wondering if it is physically sounding to have ROMS solely forced by tide. If it is:
1. Do zeta, ubar, vbar represent tidal amplitude and currents, respectively?
2. without any other forcing except tide, ROMS could keep running as far into the future as one
wants. Is this sort of tide prediction?
Anyone has done a 2-D case forced solely by tide, and would like to share the header file and input parameter file (.h and .in)?
Thanks.
jivica
Re: A benchmark case for tide
#2 Unread post by jivica »
I believe it is too simple to have it ;)
You can setup it easily without any grid or forcing, just using ana_*
For example use ana_grid.h to make rectangular basin, in that case you can increase resolution within ocean.in file where you specify number of cells, no need for recompile (specify some analytic function for bathymetry) then use for boundary again ana_fsobc.h to force elevation (and/or momentum) and that's it. Actually it is nice example of Taylor case when having Kelvin wave propagate and reflect in the channel giving amphidromic point and so on..
Just checked and all is setup for you;
have a look at the $ROMS/Functionals/ana_fsobc.h
you'll see:
!  Free-surface open boundary conditions.
#if defined INLET_TEST
# ifdef NORTH_FSOBC
      IF (NORTHERN_EDGE) THEN
        cff=-1.0_r8*sin(2.0_r8*pi*time(ng)/(12.0_r8*3600.0_r8))
        DO i=IstrR,IendR
          BOUNDARY(ng)%zeta_north(i)=cff
#elif defined KELVIN
      fac=1.0_r8                                ! zeta0
      omega=2.0_r8*pi/(12.42_r8*3600.0_r8)      ! M2 Tide period
# ifdef WEST_FSOBC
      IF (WESTERN_EDGE) THEN
        DO j=JstrR,JendR
          val=fac*EXP(-GRID(ng)%f(Istr-1,j)*GRID(ng)%yp(Istr-1,j)/      &
     &                SQRT(g*GRID(ng)%h(Istr-1,j)))
          BOUNDARY(ng)%zeta_west(j)=val*COS(omega*time(ng))
# ifdef EAST_FSOBC
Ivica
