dear all
please guide me how i can start model running not from the bigenning but from last time step in restart file.
cheers
redhat
start
Re: start
Dear kate
Dear kate
thanks for your reply. NTIMES was equal to 349440 in crashed model. Base on your answer i have set :
*NTIMES to rest steps (100680) of primary model
*NRREC to -1
*ININAME to point to restart file
to continue model running. but model stopped. after refreshing NTIMES to its primary value (349440), model is running from last step in restart file.
Do you mean that Also i did not catch what LDEFHIS is ?
Best
redhat
Dear kate
*NRREC to -1
Best
redhat
Re: start
You didn't say the first job crashed. Did it save to the third record in the restart file? You probably don't want to restart from that record. Or did it crash simply because it ran out of cpu time?
LDEFHIS is a flag for defining new history, etc. files on restart. You might want to set it to false to keep writing to the old files. If your frequency of writing to files is the same as the frequency of changing to write to a new file then LDEFHIS doesn't matter.
Re: start
Dear Kate
thanks again. model crashed simply (software problem) and saved last second records in the restart file.
Also i think that your mean from LDEFHIS is LDEFOUT because i have just found this flag that have same meaning to create new output files when initializing from a re-start file. is not it?
sincerely yours
redhat
sincerely yours
redhat
