ROMS Blows up after third year simulation
novice
#1 Unread post by novice »
Hi Forum,
I am using ROMS model configured for a climatological run in Indian Ocean. Model is initialized with a restart file from the previous run of third year and one month. My model blows up after the start of simulation for the fourth year first month.
Bathymetry (etopo2) is smoothen by 0.2 r value to avoid any chances of bathymetry related issue.
Kindly suggest to solve the problem.
Following is my model configuration and simulation step....
Thursday - March 6, 2014 - 11:42:24 AM
Trial run for Indian Ocean
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script :
SVN Revision : 669M
Local Root : /home/osf123/src0
Header Dir : /home/osf123/src0/test/test_io2
Header file : test_io2.h
Analytical Dir: /home/osf123/src0/test/test_io2
Resolution, Grid 01: 0359x0251x032, Parallel Nodes: 30, Tiling: 006x005
5184000 ntimes Number of timesteps for 3-D equations.
60.000 dt Timestep size (s) for 3-D equations.
-1 nrrec Number of restart records to read from disk.
864 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
43200 nHIS Number of timesteps between the writing fields
into history file.
518400 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
43200 nAVG Number of timesteps between the writing of
518400 ndefAVG Number of timesteps between creation of new
time-averaged file.
for tracer 02: salt
for turbulent energy.
1.0000E-04 rdrg Linear bottom drag coefficient (m/s).
1.0000E-03 rdrg2 Quadratic bottom drag coefficient.
6.0000E+00 theta_s S-coordinate surface control parameter.
1027.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
for tracer 02: salt
for 3D momentum.
-0.278 T0 Background potential temperature (C) constant.
34.649 S0 Background salinity (PSU) constant.
T LtracerCLM(01) Processing climatology on tracer 01: temp
T LtracerCLM(02) Processing climatology on tracer 02: salt
Prefix for History Files: ocean_his
Prefix for Averages Files: ocean_avg
Input Grid File: roms_grd.nc
Input Nonlinear Initial File: ocean_rst.nc
Input Forcing File 01: roms_frc.nc
Input Climatology File: roms_clm.nc
Tile partition information for Grid 01: 0359x0251x0032 tiling: 006x005
tile Istr Iend Jstr Jend Npts
0 1 60 1 49 94080
1 61 120 1 49 94080
2 121 180 1 49 94080
3 181 240 1 49 94080
4 241 300 1 49 94080
5 301 359 1 49 92512
6 1 60 50 100 97920
7 61 120 50 100 97920
8 121 180 50 100 97920
9 181 240 50 100 97920
10 241 300 50 100 97920
11 301 359 50 100 96288
12 1 60 101 151 97920
13 61 120 101 151 97920
14 121 180 101 151 97920
15 181 240 101 151 97920
16 241 300 101 151 97920
17 301 359 101 151 96288
18 1 60 152 202 97920
19 61 120 152 202 97920
20 121 180 152 202 97920
21 181 240 152 202 97920
22 241 300 152 202 97920
23 301 359 152 202 96288
24 1 60 203 251 94080
25 61 120 203 251 94080
26 121 180 203 251 94080
27 181 240 203 251 94080
28 241 300 203 251 94080
29 301 359 203 251 92512
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 60.50 0.50 49.50 RHO-points
1 60.50 120.50 0.50 49.50 RHO-points
2 120.50 180.50 0.50 49.50 RHO-points
3 180.50 240.50 0.50 49.50 RHO-points
4 240.50 300.50 0.50 49.50 RHO-points
5 300.50 359.50 0.50 49.50 RHO-points
6 0.50 60.50 49.50 100.50 RHO-points
7 60.50 120.50 49.50 100.50 RHO-points
8 120.50 180.50 49.50 100.50 RHO-points
9 180.50 240.50 49.50 100.50 RHO-points
10 240.50 300.50 49.50 100.50 RHO-points
11 300.50 359.50 49.50 100.50 RHO-points
12 0.50 60.50 100.50 151.50 RHO-points
13 60.50 120.50 100.50 151.50 RHO-points
14 120.50 180.50 100.50 151.50 RHO-points
15 180.50 240.50 100.50 151.50 RHO-points
16 240.50 300.50 100.50 151.50 RHO-points
17 300.50 359.50 100.50 151.50 RHO-points
18 0.50 60.50 151.50 202.50 RHO-points
19 60.50 120.50 151.50 202.50 RHO-points
20 120.50 180.50 151.50 202.50 RHO-points
21 180.50 240.50 151.50 202.50 RHO-points
22 240.50 300.50 151.50 202.50 RHO-points
23 300.50 359.50 151.50 202.50 RHO-points
24 0.50 60.50 202.50 251.50 RHO-points
25 60.50 120.50 202.50 251.50 RHO-points
26 120.50 180.50 202.50 251.50 RHO-points
27 180.50 240.50 202.50 251.50 RHO-points
28 240.50 300.50 202.50 251.50 RHO-points
29 300.50 359.50 202.50 251.50 RHO-points
0 1.00 60.50 0.50 49.50 U-points
1 60.50 120.50 0.50 49.50 U-points
2 120.50 180.50 0.50 49.50 U-points
3 180.50 240.50 0.50 49.50 U-points
4 240.50 300.50 0.50 49.50 U-points
5 300.50 359.00 0.50 49.50 U-points
6 1.00 60.50 49.50 100.50 U-points
7 60.50 120.50 49.50 100.50 U-points
8 120.50 180.50 49.50 100.50 U-points
9 180.50 240.50 49.50 100.50 U-points
10 240.50 300.50 49.50 100.50 U-points
11 300.50 359.00 49.50 100.50 U-points
12 1.00 60.50 100.50 151.50 U-points
13 60.50 120.50 100.50 151.50 U-points
14 120.50 180.50 100.50 151.50 U-points
15 180.50 240.50 100.50 151.50 U-points
16 240.50 300.50 100.50 151.50 U-points
17 300.50 359.00 100.50 151.50 U-points
18 1.00 60.50 151.50 202.50 U-points
19 60.50 120.50 151.50 202.50 U-points
20 120.50 180.50 151.50 202.50 U-points
21 180.50 240.50 151.50 202.50 U-points
22 240.50 300.50 151.50 202.50 U-points
23 300.50 359.00 151.50 202.50 U-points
24 1.00 60.50 202.50 251.50 U-points
25 60.50 120.50 202.50 251.50 U-points
26 120.50 180.50 202.50 251.50 U-points
27 180.50 240.50 202.50 251.50 U-points
28 240.50 300.50 202.50 251.50 U-points
29 300.50 359.00 202.50 251.50 U-points
0 0.50 60.50 1.00 49.50 V-points
1 60.50 120.50 1.00 49.50 V-points
2 120.50 180.50 1.00 49.50 V-points
3 180.50 240.50 1.00 49.50 V-points
4 240.50 300.50 1.00 49.50 V-points
5 300.50 359.50 1.00 49.50 V-points
6 0.50 60.50 49.50 100.50 V-points
7 60.50 120.50 49.50 100.50 V-points
8 120.50 180.50 49.50 100.50 V-points
9 180.50 240.50 49.50 100.50 V-points
10 240.50 300.50 49.50 100.50 V-points
11 300.50 359.50 49.50 100.50 V-points
12 0.50 60.50 100.50 151.50 V-points
13 60.50 120.50 100.50 151.50 V-points
14 120.50 180.50 100.50 151.50 V-points
15 180.50 240.50 100.50 151.50 V-points
16 240.50 300.50 100.50 151.50 V-points
17 300.50 359.50 100.50 151.50 V-points
18 0.50 60.50 151.50 202.50 V-points
19 60.50 120.50 151.50 202.50 V-points
20 120.50 180.50 151.50 202.50 V-points
21 180.50 240.50 151.50 202.50 V-points
22 240.50 300.50 151.50 202.50 V-points
23 300.50 359.50 151.50 202.50 V-points
24 0.50 60.50 202.50 251.00 V-points
25 60.50 120.50 202.50 251.00 V-points
26 120.50 180.50 202.50 251.00 V-points
27 180.50 240.50 202.50 251.00 V-points
28 240.50 300.50 202.50 251.00 V-points
29 300.50 359.50 202.50 251.00 V-points
HaloSizeI(1) = 144
HaloSizeJ(1) = 126
TileSide(1) = 66
TileSize(1) = 3762
zeta 1 Closed Chapman Imp Chapman Imp Closed
u 1 Closed Radiation Radiation Closed
v 1 Closed Radiation Radiation Closed
temp 1 Closed Radiation Radiation Closed
salt 1 Closed Radiation Radiation Closed
tke 1 Closed Gradient Gradient Closed
TEST_IO2 Trial run for Indian Ocean
DEBUGGING Internal debugging switch activated.
M3CLIMATOLOGY Processing 3D momentum climatology data.
MASKING Land/Sea masking.
MY25_MIXING Mellor/Yamada Level-2.5 mixing closure.
NONLINEAR Nonlinear Model.
NO_LBC_ATT Not checking NetCDF global attribute NLM_LBC during restart.
PRSGRD31 Standard density Jacobian formulation (Song, 1998).
QCORRECTION Surface net heat flux correction.
RHO_SURF Include difference between rho0 and surface density.
SALINITY Using salinity.
TCLIMATOLOGY Processing tracer climatology data.
TS_C4HADVECTION Fourth-order centered horizontal advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
ZCLIMATOLOGY Processing sea surface height climatology data.
Process Information:
Node # 0 (pid= 10116) is active.
Node # 1 (pid= 10117) is active.
Node # 2 (pid= 10118) is active.
Node # 3 (pid= 10119) is active.
Node # 4 (pid= 10120) is active.
Node # 5 (pid= 10121) is active.
Node # 6 (pid= 10122) is active.
Node # 7 (pid= 10123) is active.
Node # 8 (pid= 10124) is active.
Node # 9 (pid= 10125) is active.
Node # 10 (pid= 10126) is active.
Node # 11 (pid= 10127) is active.
Node # 12 (pid= 10128) is active.
Node # 13 (pid= 10129) is active.
Node # 14 (pid= 10130) is active.
Node # 15 (pid= 10131) is active.
Node # 16 (pid= 10132) is active.
Node # 17 (pid= 10133) is active.
Node # 18 (pid= 10134) is active.
Node # 19 (pid= 10135) is active.
Node # 20 (pid= 10136) is active.
Node # 21 (pid= 10137) is active.
Node # 22 (pid= 10138) is active.
Node # 23 (pid= 10139) is active.
Node # 24 (pid= 10140) is active.
Node # 25 (pid= 10141) is active.
Node # 26 (pid= 10142) is active.
Node # 27 (pid= 10143) is active.
Node # 28 (pid= 10144) is active.
Node # 29 (pid= 10145) is active.
32 0.0000000 0.0000000 0.000 0.000 0.000 0.000
31 -0.0312500 -0.0009350 -0.373 -0.313 -2.676 -4.978
30 -0.0625000 -0.0019030 -0.749 -0.625 -5.435 -10.121
29 -0.0937500 -0.0029380 -1.128 -0.938 -8.363 -15.598
28 -0.1250000 -0.0040767 -1.515 -1.250 -11.554 -21.593
27 -0.1562500 -0.0053591 -1.911 -1.563 -15.108 -28.304
26 -0.1875000 -0.0068304 -2.319 -1.875 -19.139 -35.959
25 -0.2187500 -0.0085426 -2.743 -2.188 -23.779 -44.815
24 -0.2500000 -0.0105560 -3.186 -2.500 -29.180 -55.174
23 -0.2812500 -0.0129416 -3.654 -2.813 -35.522 -67.391
22 -0.3125000 -0.0157835 -4.151 -3.125 -43.018 -81.884
21 -0.3437500 -0.0191819 -4.684 -3.438 -51.920 -99.155
20 -0.3750000 -0.0232566 -5.262 -3.750 -62.531 -119.801
19 -0.4062500 -0.0281514 -5.892 -4.063 -75.215 -144.538
18 -0.4375000 -0.0340388 -6.588 -4.375 -90.408 -174.228
17 -0.4687500 -0.0411263 -7.361 -4.688 -108.634 -209.908
16 -0.5000000 -0.0496640 -8.228 -5.000 -130.526 -252.823
15 -0.5312500 -0.0599527 -9.209 -5.313 -156.843 -304.477
14 -0.5625000 -0.0723554 -10.328 -5.625 -188.503 -366.678
13 -0.5937500 -0.0873092 -11.613 -5.938 -226.612 -441.611
12 -0.6250000 -0.1053416 -13.097 -6.250 -272.501 -531.904
11 -0.6562500 -0.1270882 -14.823 -6.563 -327.778 -640.733
10 -0.6875000 -0.1533158 -16.841 -6.875 -394.381 -771.921
9 -0.7187500 -0.1849493 -19.209 -7.188 -474.647 -930.085
8 -0.7500000 -0.2231040 -22.002 -7.500 -571.395 -1120.789
7 -0.7812500 -0.2691252 -25.306 -7.813 -688.026 -1350.747
6 -0.8125000 -0.3246355 -29.226 -8.125 -828.641 -1628.056
5 -0.8437500 -0.3915923 -33.891 -8.438 -998.187 -1962.483
4 -0.8750000 -0.4723564 -39.453 -8.750 -1202.631 -2365.809
3 -0.9062500 -0.5697755 -46.098 -9.063 -1449.170 -2852.242
2 -0.9375000 -0.6872846 -54.048 -9.375 -1746.487 -3438.925
1 -0.9687500 -0.8290268 -63.574 -9.688 -2105.053 -4146.531
0 -1.0000000 -1.0000000 -75.000 -10.000 -2537.500 -5000.000
Time Splitting Weights for Grid 01: ndtfast = 30 nfast = 42
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 2.40495901E+01 km
Maximum X-grid spacing, DXmax = 2.77832099E+01 km
Minimum Y-grid spacing, DYmin = 2.40871264E+01 km
Maximum Y-grid spacing, DYmax = 2.77830873E+01 km
Minimum Z-grid spacing, DZmin = 3.73274602E-01 m
Maximum Z-grid spacing, DZmax = 8.53468765E+02 m
Minimum barotropic Courant Number = 2.76139585E-03
Maximum barotropic Courant Number = 2.60205005E-02
Maximum Coriolis Courant Number = 4.36950352E-03
NLM: GET_STATE - Warning - NetCDF global attribute: NLM_LBC
for lateral boundary conditions not checked
in restart file: ocean_rst.nc
NLM: GET_STATE - Read state initial conditions, t = 1044 00:00:00
(Grid 01, File: ocean_rst.nc, Rec=0002, Index=1)
- free-surface
(Min = -1.71556758E+00 Max = 1.29852434E+00)
(Min = -1.67233753E+00 Max = 1.80405052E+00)
(Min = -1.62756808E+00 Max = 2.88255421E+00)
- u-momentum component
(Min = -3.45645858E+00 Max = 5.06761800E+00)
- v-momentum component
(Min = -4.58061582E+00 Max = 5.81005726E+00)
- potential temperature
(Min = -1.45412661E+02 Max = 5.49312200E+01)
- salinity
(Min = 2.13327691E+01 Max = 4.99393483E+01)
- vertical viscosity coefficient
(Min = 0.00000000E+00 Max = 2.26149188E+02)
- temperature vertical diffusion coefficient
(Min = 0.00000000E+00 Max = 2.97953777E+02)
- salinity vertical diffusion coefficient
GET_2DFLD - surface u-momentum stress, t = 315 00:00:00
(Rec=0000011, Index=1, File: roms_frc.nc)
(Min = -1.67221825E-04 Max = 4.46894929E-05)
GET_2DFLD - surface v-momentum stress, t = 315 00:00:00
(Min = -2.47540242E-04 Max = 1.10292631E-04)
GET_2DFLD - surface net heat flux, t = 315 00:00:00
(Min = -5.78668080E-05 Max = 4.32171632E-05)
GET_2DFLD - sea surface temperature climatology, t = 315 00:00:00
(Min = 1.82882767E+01 Max = 2.97874126E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 315 00:00:00
(Min = -1.67268037E-05 Max = -5.56377139E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 315 00:00:00
(Min = -3.65903823E-07 Max = 1.04064828E-07)
GET_2DFLD - sea surface height climatology, t = 315 00:00:00
(Rec=0000011, Index=1, File: roms_clm.nc)
(Min = -1.80340451E+00 Max = 7.93942796E-01)
GET_3DFLD - potential temperature climatology, t = 315 00:00:00
(Min = 2.51346192E-01 Max = 3.09622487E+01)
GET_3DFLD - salinity climatology, t = 315 00:00:00
(Min = 1.87654107E+01 Max = 4.14058170E+01)
GET_3DFLD - u-momentum component climatology, t = 315 00:00:00
(Min = -4.17097056E+00 Max = 1.67593050E+00)
GET_3DFLD - v-momentum component climatology, t = 315 00:00:00
(Min = -2.42818214E+00 Max = 5.62615950E+00)
Maximum grid stiffness ratios: rx0 = 2.326602E-01 (Beckmann and Haidvogel)
rx1 = 2.526081E+00 (Haney)
Initial basin volumes: TotVolume = 1.4037563547E+17 m3
MinVolume = 2.1707404178E+08 m3
MaxVolume = 6.5879531608E+11 m3
Max/Min = 3.0348875927E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 01503361 - 05184000)
GET_2DFLD - surface u-momentum stress, t = 345 00:00:00
(Rec=0000012, Index=2, File: roms_frc.nc)
(Min = -1.68642882E-04 Max = 4.38884107E-05)
GET_2DFLD - surface v-momentum stress, t = 345 00:00:00
(Min = -2.30629585E-04 Max = 1.16616426E-04)
GET_2DFLD - surface net heat flux, t = 345 00:00:00
(Min = -6.70591379E-05 Max = 4.01735706E-05)
GET_2DFLD - sea surface temperature climatology, t = 345 00:00:00
(Min = 1.78758011E+01 Max = 2.96960344E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 345 00:00:00
(Min = -1.56755779E-05 Max = -4.63628970E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 345 00:00:00
(Min = -2.34185175E-07 Max = 1.15583962E-07)
GET_2DFLD - sea surface height climatology, t = 345 00:00:00
(Rec=0000012, Index=2, File: roms_clm.nc)
(Min = -1.78705581E+00 Max = 7.96083745E-01)
GET_3DFLD - potential temperature climatology, t = 345 00:00:00
(Min = 2.51346192E-01 Max = 3.02954484E+01)
GET_3DFLD - salinity climatology, t = 345 00:00:00
(Min = 2.44451369E+01 Max = 4.13800304E+01)
GET_3DFLD - u-momentum component climatology, t = 345 00:00:00
(Min = -4.40555192E+00 Max = 1.89923644E+00)
GET_3DFLD - v-momentum component climatology, t = 345 00:00:00
(Min = -2.43779523E+00 Max = 5.26730740E+00)
1503360 1044 00:00:00 2.660592E-02 2.017151E+04 2.017154E+04 1.420723E+17
(354,118,01) 1.231160E-03 1.249742E-02 0.000000E+00 5.858310E+00
DEF_HIS - inquiring history file, Grid 01: ocean_his_0003.nc
DEF_AVG - inquiring average file, Grid 01: ocean_avg_0003.nc
1503361 1044 00:01:00 2.660537E-02 2.017151E+04 2.017154E+04 1.420723E+17
(352,161,22) 1.901020E-03 3.217765E-03 7.221660E-02 5.858197E+00
1503362 1044 00:02:00 2.660572E-02 2.017151E+04 2.017154E+04 1.420723E+17
(352,161,22) 1.902566E-03 3.221427E-03 7.252198E-02 5.858440E+00
1503363 1044 00:03:00 2.660607E-02 2.017151E+04 2.017154E+04 1.420723E+17
(352,161,22) 1.904136E-03 3.225071E-03 7.262802E-02 5.858681E+00
(350,153,32) 1.693027E-03 1.207960E-03 4.237695E-01 1.216910E+01
1616397 1122 11:57:00 2.654959E-02 2.017111E+04 2.017114E+04 1.420670E+17
(350,153,32) 1.715048E-03 1.215153E-03 4.059400E-01 1.216248E+01
1616398 1122 11:58:00 2.655689E-02 2.017111E+04 2.017114E+04 1.420670E+17
(351,150,32) 1.054688E-03 1.170428E-03 4.056764E-01 1.215524E+01
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000003
Elapsed CPU time (seconds):
Node # 0 CPU: 28044.521
number of time records written in RESTART file = 00000131
number of time records written in AVERAGE file = 00000001
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_fsobc.h
Node # 1 CPU: 28294.884
Node # 2 CPU: 28290.268
Node # 3 CPU: 28289.876
Node # 4 CPU: 28281.900
Node # 5 CPU: 28285.780
Node # 6 CPU: 28297.000
Node # 7 CPU: 28296.656
Node # 8 CPU: 28291.668
Node # 9 CPU: 28296.496
Node # 10 CPU: 28302.321
Node # 11 CPU: 28296.772
Node # 12 CPU: 28290.592
Node # 13 CPU: 28300.409
Node # 14 CPU: 28297.208
Node # 15 CPU: 28285.376
Node # 16 CPU: 28299.889
Node # 17 CPU: 28295.204
Node # 18 CPU: 28300.669
Node # 19 CPU: 28289.200
Node # 20 CPU: 28293.496
Node # 21 CPU: 28301.669
Node # 22 CPU: 28289.380
Node # 23 CPU: 28295.860
Node # 24 CPU: 28292.836
Node # 25 CPU: 28293.640
Node # 26 CPU: 28281.471
Node # 27 CPU: 28281.523
Node # 28 CPU: 28286.896
Node # 29 CPU: 28290.840
ROMS/Functionals/ana_m2obc.h
ROMS/TOMS: DONE... Thursday - March 6, 2014 - 7:37:37 PM
Kindly help to resolve the problem.
Thanks in advance...
regards,
Sandy
Re: ROMS Blows up after third year simulation
You need to look at record 3 of the restart file to see if you can figure out where and how the thing went bad. It either has an extreme velocity or extreme density. Your Courant numbers look OK, so I'm guessing extreme density. Is the problem at the surface, bottom or middle? Edge or interior? Due to temperature, salinity or both?
novice
#3 Unread post by novice »
Thanks Kate for your quick reply. As you suggested , I checked the third record of my restart file and realized that the temperature has an abnormal range in my eastern boundary, to be more specific off the north east coast of Borneo island and the problem persists for all the levels. In case of salinity also the same location shows some discrepancy. I am a beginner to the ROMS and I would be grateful if you can point out some clues about the source of this problem.
Thanks again for your reply
Sandy
I see you are using a pure radiation boundary condition for the 3-D fields. Perhaps it is not numerically well-behaved. Do you have external boundary conditions to nudge to? I use the RadNud combination on the boundaries.
novice
#5 Unread post by novice »
Thanks Kate. As you suggested I created an external boundary condition file as roms_bry.nc, and changed the option from radiation to radiation with nudging. The model is running now and I will get back to you once it is over.
Thanks again for your support which is really encouraging.
By
Sandy
