run problem
mrmohammadpour
run problem
#1 Unread post by mrmohammadpour »
Dear Users
when i ran ROMS model it stopped. i don't know what is problem. here is my log file :
Sunday - January 26, 2014 - 5:29:22 AM
Wind-Driven Upwelling/Downwelling over a Periodic Channel
Operating system : Linux
CPU/hardware : x86_64
Compiler system : pgi
Compiler command : /home/mohammadpour/libs_pgi/mpich2-1.4/mpich2_pgi_recompile/bin/mpif90
Compiler flags : -O3 -Mfree
Input Script :
SVN Revision :
Local Root : /home/mohammadpour/wrf-roms_coupling/ROMS/trunk
Header Dir : /home/mohammadpour/wrf-roms_coupling/ROMS/trunk/ROMS/Include
Header file : spinup.h
Analytical Dir: /home/mohammadpour/wrf-roms_coupling/ROMS/trunk/ROMS/Functionals
Resolution, Grid 01: 0197x0147x030, Parallel Nodes: 4, Tiling: 002x002
518400 ntimes Number of timesteps for 3-D equations.
600.000 dt Timestep size (s) for 3-D equations.
288 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
4320 nHIS Number of timesteps between the writing fields
into history file.
51840 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
4320 nAVG Number of timesteps between the writing of
51840 ndefAVG Number of timesteps between creation of new
time-averaged file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
1 lmd_Jwt Jerlov water type.
6.5000E+00 theta_s S-coordinate surface control parameter.
75.000 Tcline S-coordinate surface/bottom layer width (m) used
2.000 dstart Time-stamp assigned to model initialization (days).
19970602.00 time_ref Reference time for units attribute (yyyymmdd.dd)
3.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
3.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.0000E+01 Znudg Nudging/relaxation time scale (days)
3.0000E+01 M2nudg Nudging/relaxation time scale (days)
3.0000E+01 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.0000E+01 obcfac Factor between passive and active
T Hout(idSrad) Write out shortwave radiation flux.
T Hout(idTdif) Write out vertical diffusion: AKt(itemp).
T Hout(idSdif) Write out vertical diffusion: AKt(isalt).
T Hout(idHsbl) Write out depth of surface boundary layer.
T Aout(idUsms) Write out averaged surface U-momentum stress.
T Aout(idVsms) Write out averaged surface V-momentum stress.
T Aout(idUbms) Write out averaged bottom U-momentum stress.
T Aout(idVbms) Write out averaged bottom V-momentum stress.
T Aout(idTsur) Write out averaged surface net heat flux.
T Aout(idTsur) Write out averaged surface net salt flux.
T Aout(idSrad) Write out averaged shortwave radiation flux.
Output Restart File: spinup_rst.nc
Prefix for History Files: spinup_his
Prefix for Averages Files: spinup_avg
Input Grid File: spinup_grid.nc
Input Nonlinear Initial File: spinup_init.nc
Input Forcing File 01: spinup_forc.nc
Tile partition information for Grid 01: 0197x0147x0030 tiling: 002x002
tile Istr Iend Jstr Jend Npts
0 1 99 1 74 219780
1 100 197 1 74 217560
2 1 99 75 147 216810
3 100 197 75 147 214620
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 99.50 0.50 74.50 RHO-points
1 99.50 197.50 0.50 74.50 RHO-points
2 0.50 99.50 74.50 147.50 RHO-points
3 99.50 197.50 74.50 147.50 RHO-points
0 1.00 99.50 0.50 74.50 U-points
1 99.50 197.00 0.50 74.50 U-points
2 1.00 99.50 74.50 147.50 U-points
3 99.50 197.00 74.50 147.50 U-points
0 0.50 99.50 1.00 74.50 V-points
1 99.50 197.50 1.00 74.50 V-points
2 0.50 99.50 74.50 147.00 V-points
3 99.50 197.50 74.50 147.00 V-points
HaloSizeI(1) = 336
HaloSizeJ(1) = 255
TileSide(1) = 106
TileSize(1) = 8374
zeta 1 Periodic Closed Periodic Closed
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
temp 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
UPWELLING Wind-Driven Upwelling/Downwelling over a Periodic Channel
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
OUT_DOUBLE Double precision output fields in NetCDF files.
QCORRECTION Surface net heat flux correction.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 0 (pid= 10167) is active.
Node # 1 (pid= 10168) is active.
Node # 2 (pid= 10169) is active.
Node # 3 (pid= 10170) is active.
30 0.0000000 0.0000000 0.000 0.000 0.000 0.000
29 -0.0333333 -0.0000711 -1.253 -1.253 -2.581 -2.779
28 -0.0666667 -0.0002876 -2.511 -2.511 -5.490 -6.211
27 -0.1000000 -0.0006599 -3.775 -3.775 -8.748 -10.342
26 -0.1333333 -0.0012053 -5.045 -5.045 -12.395 -15.251
25 -0.1666667 -0.0019498 -6.323 -6.323 -16.490 -21.054
24 -0.2000000 -0.0029282 -7.610 -7.610 -21.110 -27.907
23 -0.2333333 -0.0041868 -8.907 -8.907 -26.360 -36.019
22 -0.2666667 -0.0057848 -10.217 -10.217 -32.373 -45.655
21 -0.3000000 -0.0077977 -11.542 -11.542 -39.318 -57.154
20 -0.3333333 -0.0103201 -12.887 -12.887 -47.408 -70.941
19 -0.3666667 -0.0134710 -14.255 -14.255 -56.910 -87.551
18 -0.4000000 -0.0173990 -15.652 -15.652 -68.158 -107.650
17 -0.4333333 -0.0222890 -17.086 -17.086 -81.568 -132.069
16 -0.4666667 -0.0283717 -18.564 -18.564 -97.659 -161.845
15 -0.5000000 -0.0359336 -20.098 -20.098 -117.073 -198.263
14 -0.5333333 -0.0453311 -21.700 -21.700 -140.612 -242.925
13 -0.5666667 -0.0570072 -23.388 -23.388 -169.271 -297.819
12 -0.6000000 -0.0715120 -25.182 -25.182 -204.287 -365.416
11 -0.6333333 -0.0895292 -27.107 -27.107 -247.196 -448.787
10 -0.6666667 -0.1119079 -29.197 -29.197 -299.905 -551.744
9 -0.7000000 -0.1397028 -31.489 -31.489 -364.785 -679.024
8 -0.7333333 -0.1742238 -34.033 -34.033 -444.780 -836.509
7 -0.7666667 -0.2170979 -36.891 -36.891 -543.545 -1031.506
6 -0.8000000 -0.2703455 -40.138 -40.138 -665.621 -1273.088
5 -0.8333333 -0.3364762 -43.868 -43.868 -816.647 -1572.525
4 -0.8666667 -0.4186066 -48.198 -48.198 -1003.625 -1943.813
3 -0.9000000 -0.5206075 -53.273 -53.273 -1235.256 -2404.334
2 -0.9333333 -0.6472858 -59.273 -59.273 -1522.339 -2975.676
1 -0.9666667 -0.8046118 -66.423 -66.423 -1878.292 -3684.649
0 -1.0000000 -1.0000000 -75.000 -75.000 -2319.776 -4564.551
Time Splitting Weights for Grid 01: ndtfast = 30 nfast = 42
7-0.0011849025289723 0.0336508794757796-0.0107112868023601 0.2343461315221331
8-0.0005032751608632 0.0336903762267453-0.0112145619632232 0.2680365077488784
9 0.0003887272597151 0.0337071520654408-0.0108258347035082 0.3017436598143192
12 0.0043042707117221 0.0335513677379153-0.0022367614257357 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864347 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001212 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565096 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906203 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716642 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402367 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399431 0.6603333185976138
21 0.0256737146312911 0.0297153720153352 0.1342125541712341 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524358 0.7189082721405745
23 0.0316613792205220 0.0279045862015855 0.1945237931729577 0.7468128583421599
24 0.0346736416507075 0.0268492068942347 0.2291974348236652 0.7736620652363947
25 0.0376471948657328 0.0256934188392112 0.2668446296893980 0.7993554840756059
26 0.0405373376992233 0.0244385123436867 0.3073819673886213 0.8237939964192926
27 0.0432936737565710 0.0230872677537126 0.3506756411451923 0.8468812641730052
28 0.0458596469320356 0.0216441452951603 0.3965352880772279 0.8685254094681655
29 0.0481720587108285 0.0201154903974257 0.4447073467880564 0.8886408998655912
30 0.0501605672561820 0.0185097551070648 0.4948679140442384 0.9071506549726560
31 0.0517471682814031 0.0168377361985254 0.5466150823256414 0.9239883911711814
32 0.0528456577069106 0.0151128305891453 0.5994607400325520 0.9391012217603266
33 0.0533610761022577 0.0133513086655816 0.6528218161348097 0.9524525304259083
34 0.0531891349131380 0.0115726061288397 0.7060109510479476 0.9640251365547480
35 0.0522156244733761 0.0097996349650684 0.7582265755213237 0.9738247715198164
36 0.0503158038019030 0.0080591141492892 0.8085423793232267 0.9818838856691056
37 0.0473537721847154 0.0063819206892258 0.8558961515079421 0.9882658063583314
38 0.0431818225418188 0.0048034616164019 0.8990779740497609 0.9930692679747333
39 0.0376397765791564 0.0033640675316746 0.9367177506289173 0.9964333355064079
40 0.0305543017255206 0.0021094083123694 0.9672720523544379 0.9985427438187773
41 0.0217382098544504 0.0010909315881854 0.9890102622088883 0.9996336754069627
42 0.0109897377911118 0.0003663245930371 1.0000000000000000 0.9999999999999998
Minimum X-grid spacing, DXmin = 1.10793490E+01 km
Maximum X-grid spacing, DXmax = 1.23645734E+01 km
Minimum Y-grid spacing, DYmin = 1.22967498E+01 km
Maximum Y-grid spacing, DYmax = 1.25362749E+01 km
Minimum Z-grid spacing, DZmin = 1.25266506E+00 m
Maximum Z-grid spacing, DZmax = 8.79901752E+02 m
Minimum barotropic Courant Number = 6.23884565E-02
Maximum barotropic Courant Number = 4.86076854E-01
Maximum Coriolis Courant Number = 3.97538733E-02
NLM: GET_STATE - Read state initial conditions, t = 15 00:00:00
(Grid 01, File: spinup_init.nc, Rec=0001, Index=1)
- free-surface
(Min = -2.77832448E-01 Max = 3.31414968E-01)
(Min = -1.25634745E-01 Max = 1.77229121E-01)
(Min = -1.38672471E-01 Max = 2.10709214E-01)
- u-momentum component
(Min = -1.53557062E-01 Max = 2.16179758E-01)
- v-momentum component
(Min = -1.60301849E-01 Max = 2.89086640E-01)
- potential temperature
(Min = 1.14265692E+00 Max = 2.86823902E+01)
- salinity
(Min = 3.25348816E+01 Max = 4.16874809E+01)
(Rec=0000001, Index=1, File: spinup_forc.nc)
(Min = -4.86813767E-05 Max = 2.52287123E-05)
(Min = -5.47968043E-05 Max = -4.21221514E-06)
(Min = 3.48837818E-05 Max = 5.50180279E-05)
GET_2DFLD - surface net heat flux, t = 15 00:00:00
(Min = -3.29714540E-05 Max = 8.93999451E-06)
GET_2DFLD - sea surface temperature climatology, t = 15 00:00:00
(Min = 2.22198391E+01 Max = 2.80529479E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 15 00:00:00
(Min = -1.04309738E-05 Max = -5.87327915E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 15 00:00:00
(Min = -5.07285736E-08 Max = 9.23233398E-08)
(Min = 3.27277985E+01 Max = 3.95276862E+01)
Maximum grid stiffness ratios: rx0 = 9.504773E-01 (Beckmann and Haidvogel)
rx1 = 9.070657E+00 (Haney)
Initial basin volumes: TotVolume = 7.2646258697E+15 m3
MinVolume = 1.7509492046E+08 m3
MaxVolume = 1.3340832495E+11 m3
Max/Min = 7.6192001800E+02
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00001873 - 00518400)
GET_2DFLD - surface u-momentum stress, t = 45 00:00:00
(Rec=0000002, Index=2, File: spinup_forc.nc)
(Min = -4.26484547E-05 Max = 3.48980978E-05)
GET_2DFLD - surface v-momentum stress, t = 45 00:00:00
(Min = -4.47138871E-05 Max = -9.47061337E-07)
GET_2DFLD - solar shortwave radiation flux, t = 45 00:00:00
(Min = 4.54021059E-05 Max = 6.31895738E-05)
GET_2DFLD - surface net heat flux, t = 45 00:00:00
(Min = -1.61443246E-05 Max = 1.87568280E-05)
GET_2DFLD - sea surface temperature climatology, t = 45 00:00:00
(Min = 2.13062878E+01 Max = 2.83568234E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 45 00:00:00
(Min = -9.42328302E-06 Max = -6.00754887E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 45 00:00:00
(Min = -9.75183062E-09 Max = 7.84124291E-08)
GET_2DFLD - sea surface salinity climatology, t = 45 00:00:00
(Min = 3.34322014E+01 Max = 3.92781461E+01)
1872 15 00:00:00 1.644192E-05 1.698797E+04 1.698797E+04 7.386947E+15
(180,019,30) 1.696469E-03 1.394756E-02 0.000000E+00 2.896648E-01
1873 15 00:10:00 1.742019E-02 1.698723E+04 1.698725E+04 7.386378E+15
(001,001,01) 3.235082E-01 1.400772E-02 8.883639E-05 8.421076E+00
1874 15 00:20:00 5.492227E-02 1.698616E+04 1.698621E+04 7.385627E+15
(197,001,30) 5.501832E-01 0.000000E+00 2.322991E+02 1.663641E+01
1875 15 00:30:00 1.167855E-01 1.698452E+04 1.698464E+04 7.384796E+15
(197,001,30) 2.439337E+00 0.000000E+00 3.830584E+02 7.122162E+01
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000001
Elapsed CPU time (seconds):
Node # 0 CPU: 2.122
Node # 1 CPU: 2.122
Node # 2 CPU: 2.122
Node # 3 CPU: 2.122
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/TOMS: DONE... Sunday - January 26, 2014 - 5:29:24 AM
does anyone know what is the problem?
Re: run problem
I would load the restart file into ncview and look at the point 197,1,30 to see what's going on there.
mrmohammadpour
Re: run problem
#3 Unread post by mrmohammadpour »
Dear Kate, thank you for replying
i upload my restart file, please see it
http://www.uplooder.net/cgi-bin/dl.cgi? ... 37aa9dde91
Re: run problem
#4 Unread post by arango »
We are very busy people to start downloading everybody files for us to plot them and then tell you what it is wrong. It is for you to investigate and learn what maybe happening. The fact that model is blowing-up right away is possibly due to wrong configuration files and/or CFL violation. The learning curve of ROMS is very high. Even users with a lot of experience spend a lot of time examining their simulations. This is what scientists do everyday.
If we want to have good simulations with any ocean model, we need to spend the time learning how to achieve such simulations. I know that it is frustrating at times but it has to be done. Otherwise, we are in the wrong profession...
mrmohammadpour
Re: run problem
#5 Unread post by mrmohammadpour »
Dear Arango
thank you for your advice
I did not mean to disturb you. i was hoping someone on this forum can advise me.
I'm so sorry for the trouble that I've caused
