how to call the function get_3dfld
xiaozhu557
#1 Unread post by xiaozhu557 »
Hello all,
I want to add a 3D mixing coefficient and input it to the model as a forcing parameter. I have defined it in mod_forces.F as follow,
# ifdef ECOSIM
      allocate ( FORCES(ng) % SpecIr(LBi:UBi,LBj:UBj,NBands) )
      allocate ( FORCES(ng) % avcos(LBi:UBi,LBj:UBj,NBands) )
# ifdef WAVE_MIXING
      allocate ( FORCES(ng) % bv(LBi:UBi,LBj:UBj,0:N(ng)) )
      allocate ( FORCES(ng) % bvG(LBi:UBi,LBj:UBj,0:N(ng),2) )
#if defined TANGENT || defined TL_IOMS
!  Tangent linear model state
      allocate ( FORCES(ng) % tl_sustr(LBi:UBi,LBj:UBj) )
      allocate ( FORCES(ng) % tl_svstr(LBi:UBi,LBj:UBj) )
This means that the variable's size is bv(xi_rho,eta_rho,s_w)
Then I read in the data from forcing file in subroutine get_data.F as follow,
#  if !defined ANA_M3CLIMA && defined M3CLIMATOLOGY
      CALL get_3dfld (ng, iNLM, idUclm, CLM(ng)%ncid,                   &
     &                1, CLM(ng), update(1),                            &
     &                LBi, UBi, LBj, UBj, 1, N(ng), 2, 1,               &
#   ifdef MASKING
     &                GRID(ng) % umask(LBi,LBj),                        &
#   endif
     &                CLIMA(ng) % uclmG(LBi,LBj,1,1))
      CALL get_3dfld (ng, iNLM, idVclm, CLM(ng)%ncid,                   &
#   ifdef MASKING
     &                GRID(ng) % vmask(LBi,LBj),                        &
#   endif
     &                CLIMA(ng) % vclmG(LBi,LBj,1,1))
#  endif
#if defined SOLVE3D && defined WAVE_MIXING
      CALL get_3dfld (ng, iNLM, idWbv, ncFRCid(idWbv,ng),               &
     &                nFfiles(ng), FRC(1,ng), update(1),                &
     &                LBi, UBi, LBj, UBj, 0, N(ng), 2, 1,               &
#   ifdef MASKING
     &                GRID(ng) % rmask(LBi,LBj),                        &
#   endif
     &                FORCES(ng) % bvG(LBi,LBj,1,1))
I have got an error message as segmentation fault while calling the subroutine get_3dfld with more than one processors to run ROMS. But it can work fine with only one processor to run ROMS.
So it is wired for me.
But if I defined it as
# ifdef WAVE_MIXING
      allocate ( FORCES(ng) % bv(LBi:UBi,LBj:UBj,N(ng)) )
      allocate ( FORCES(ng) % bvG(LBi:UBi,LBj:UBj,N(ng),2) )
This means that the variable's size is bv(xi_rho,eta_rho,s_rho)
And read it with
#   ifdef MASKING
#   endif
It can work fine. So I am confused about the subroutine get_3dfld. Does not it been used to read the variable with size s_w, and just works with s_rho? Or do I have made a mistake to use this subroutine?
I would like appreciate your any hint very much. Thanks.
Re: how to call the function get_3dfld
#2 Unread post by arango »
The routine get_3dfld can read any 3D field. You just need to specify the correct range for the vertical dimension: 0, N(ng)
#   ifdef MASKING
#   endif
Also, you need to be sure that you added the proper metadata in varinfo.dat for the new variable and code the appropriate logic for idWbv in mod_ncparam.F.
xiaozhu557
#3 Unread post by xiaozhu557 »
Thanks for your replying, arango.
Yes, I have added it, I am sure. Or I can not compile it successful.
Now my question is why the modifications can not work when I run the model with multiprocessor and define the variable bvG as
allocate ( FORCES(ng) % bvG(LBi:UBi,LBj:UBj,0:N(ng)) )
Is it correct if I set the bvG's size as (ocean_time,s_w,eta_rho,xi_rho) in the forcing file? If not correct, how should I define it in mod_forces.F
How should I modify them in order to make them work with bvG(ocean_time,s_w,eta_rho,xi_rho) and run with multi-processor?
In this case, how Should I call the subroutine get_3dfld?
Where is my mistake? Thanks.
#4 Unread post by arango »
Nope, it has to be a 4D-array to store the two time snapshots that are used to linearly interpolate input data at each time-step:
# ifdef WAVE_MIXING
Then, you need to pass array bvG with zero-pointer for the third dimension. This is basic Fortran coding. If you read the top of get_3dfld.F and follow the logic, you will be understand what I am talking about :!: All these routines are well documented. Perhaps, you should read mode about Fortran before start coding...
#   ifdef MASKING
#   endif
     &                FORCES(ng) % bvG(LBi,LBj,0,1))
xiaozhu557
#5 Unread post by xiaozhu557 »
But why it can work when I run the model with only one processor? This is exactly confused me. Thanks.
