ocean_time, DSTART, TIDE_START, TIME_REF
wzhu
#1 Unread post by wzhu »
I am a little confused with the ocean_time, DSTART, TIDE_START and TIME_REF.
I prepared all my input files with the time period from 00:00 01/01/2006 to 00:00 10/31/2008, if I want to start the simulating time from 00:00 09/01/2006, so I have to set the ocean_time in the initial condition file to 20995200 seconds (243 days*24*3600), right? when I did that, the model only works with NDEFHIS set to 0, or I will get the error
NETCDF_PUT_FVAR_1D - error while writing variable: ocean_time
in input file: ./ETM_his.nc
call from: wrt_his.F
But if there is only one single history output file, it will be 200 G in size!!!
I noticed that the DSTART, TIDE_START and TIME_REF in my ocean.in file are all 0.0d0, dose it matter? how should I set each of them?
I tried the following,
DSTART = 243.0d0 ! days after TIME_REF, i.e. 2006 09 01 00 00
TIDE_START = 0.0d0 ! days after tide forcing time axis origin
TIME_REF = 20060101.0d0 ! yyyymmdd.dd
Is this right?
I appreciate any replies.
Happy thanksgiving!
Wenwu
Re: ocean_time, DSTART, TIDE_START, TIME_REF
You should be able to set NDEFHIS to NHIS, no problem. If you have a problem, something is wrong.
You should be able to set the time origin and DSTART as you have below. The tides will depend on how you create your tides file.
wzhu
#3 Unread post by wzhu »
kate wrote:You should be able to set NDEFHIS to NHIS, no problem. If you have a problem, something is wrong.
Thank you very much, kate.
I tried I listed above, it works, :) not only one single history file. It seems that if the ocean_time is changed, the DSTART should be changed accordingly.
I created the tides file from 00:00 01/01/2006, the interval is 1 hour.
