Compilation errors in check_multifile
m.hadfield
With the multifile-checking code introduced a couple of days ago I'm getting compilation errors in check_multifile when the model is built in a configuration that requires the reading of forcing files:
check_multifile.f90:68.33:
            ncname=BRY(ng)%files(Fcount)
                                 1
Warning: Legacy Extension: REAL array index at (1)
check_multifile.f90:93.18:
          updated=.FALSE.
                  1
Error: Can't convert LOGICAL(4) to REAL(4) at (1)
check_multifile.f90:112.35:
            ncname=FRC(i,ng)%files(Fcount)
                                   1
The first problem is that there is no implicit none statement in this file, so undeclared variables are given implicit types, leading to the errors above.
If I add an "implicit none" statement I find there are 3 undeclared variables: Fcount, lstr (both of integer type) and updated (logical). If I add local declarations for these then the model builds and runs OK, though I don't know if the multifile-checking is actually working as it should. I note that the variable "updated" is set to .FALSE. in a couple of places but is never used.
hankseidel
Re: Compilation errors in check_multifile
#2 Unread post by hankseidel »
We ran into the same problem yesterday evening. Just getting ready to post and we saw your post. We will try your workaround.
Hank
#3 Unread post by arango »
Yes, this was fixed. Actually, there were a parallel bug in distributed memory that took me couple of hours to find. See following :arrow: ticket for more information. Please update.
m.hadfield
A minor remaining issue: looking at this...
https://www.myroms.org/svn/src/trunk/RO ... ultifile.F
...the variable lstr is still undeclared, and this is not picked up by the compiler because there is still no "implicit none".
