I'm attempting to set up and run a realistic application of my own using the most recent version of ROMS. I have all of the necessary netcdf files for grid and forcing (tide, winds & river discharge). The build goes smoothly but upon running I receive the following error:
Wednesday - October 2, 2013 - 11:31:11 AM
At line 1067 of file read_phypar.f90
Fortran runtime error: Attempting to allocate already allocated array 'frc'
CASE ('NFFILES')
Npts=load_i(Nval, Rval, Ngrids, nFfiles)
DO ng=1,Ngrids
IF (nFfiles(ng).le.0) THEN
IF (Master) WRITE (out,260) 'NFFILES', nFfiles(ng), &
& 'Must be equal or greater than one.'
exit_flag=4
RETURN
mFfiles=MAXVAL(nFfiles)
allocate ( FRC(mFfiles,Ngrids) )
allocate ( FRCids(mFfiles,Ngrids) )
allocate ( Ncount(mFfiles,Ngrids) )
FRCids(1:mFfiles,1:Ngrids)=-1
Ncount(1:mFfiles,1:Ngrids)=0
CASE ('FRCNAME')
label='FRC - forcing fields'
Npts=load_s2d(Nval, Cval, line, label, ifile, igrid, &
& Ncount, mFfiles, FRC)
I have 3 forcing files and NFFILES set equal to 3 in my ocean*.in.
I cannot, for the life of me, figure out why this array is being re-allocated. Searching through the scripts in the same scratch directory shows no other place were the array 'FRC' is allocated. A search of the forum reveals no other identical problems.
I'll soon go about trying different compilers, because nothing about the set up of my application seems to be amiss.
Any ideas on where to look next?
Any advice is appreciated, as always.
