inquire -swrad
wangzc
Location: National Marine Environmental Forecasting Center
inquire -swrad
#1 Unread post by wangzc »
hi,
I want to know which cpp option active the variable 'swrad'. I try to it, but failed. Anyone can tell me? Many thanks!
ECS East of China Sea
DEBUGGING Internal debugging switch activated.
INLINE_2DIO Processing 3D IO level by level to reduce memory needs.
LMD_SHAPIRO Shapiro filtering boundary layer depth.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
RAMP_TIDES Ramping tidal forcing for one day.
STATIONS Writing out station data.
STATIONS_CGRID Extracting station data at native C-grid locations.
TS_C4HADVECTION Fourth-order centered horizontal advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_C4ADVECTION Fourth-order centered differences advection of momentum.
INQUIRE - unable to find requested variable: swrad
Re: inquire -swrad
The answer is LMD_SKPP. This is from globaldefs.h:
#if defined LMD_SKPP     || defined SOLAR_SOURCE   || \
    defined BULK_FLUXES  || defined BIOLOGY
# define SHORTWAVE
wangzc
Re: inquire -swrad
#3 Unread post by wangzc »
Thank U, Kate!
I see it in globaldefs.h. All needed cpp options can be found here. As a beginner, everyone can face 'inquire' problems. Share to all the experience.
Error prompt: INQUIRE - unable to find requested variable: ***
$cd trunk/
$grep -n *** -r ./
!find the variable *** in the folder and subfolder
Then check out the related file to see '#define' what. After that, locate the line via '/ what' to make sure the related cpp options.
--zongchen
