After restart in the subroutine ice_advect ice concentrations are equal to 0#define PERFECT_RESTART
#define WET_DRY
#define ICE_MODEL
#ifdef SOLVE3D
# ifdef ICE_MODEL
# define ICE_THERMO
# define ICE_MK
# undef ICE_ALB_EC92
# define ICE_SMOOTH
# define ICE_MOMENTUM
# define ICE_MOM_BULK
# define ICE_EVP
# define ICE_ADVECT
# define ICE_SMOLAR
# define ICE_UPWIND
# define ICE_BULK_FLUXES
# define ICE_SHOREFAST
! step number 1 in mpdata:
DO j=Jmin,Jmax
DO i=Imin,Imax
ar(i,j)=1.0_r8/omn(i,j)
aif(i,j)=(scr(i,j,liold)-dtice(ng)*(aflxu(i+1,j)-aflxu(i,j) &
& +aflxv(i,j+1)-aflxv(i,j))*ar(i,j))
aif(i,j) = aif(i,j)*rmask(i,j)
aif(i,j) = aif(i,j)*rmask_wet(i,j)
DO j=Jstr,Jend
DO i=Istr,Iend
scr(i,j,linew) = aif(i,j)
In order to avoid this situation I've made changes
in file checkvars.F
#ifdef PERFECT_RESTART
! Determine perfect restart fields to read from input NetCDF file.
IF (((model.eq.0).or.(model.eq.iNLM)).and.(nrrec(ng).ne.0)) THEN
# ifdef SOLVE3D
get_var(idRu3d)=.TRUE.
get_var(idRv3d)=.TRUE.
get_var(idRwet)=.TRUE. !!!!!!!!!!! included
get_var(idUwet)=.TRUE. !!!!!!!!!!! included
get_var(idVwet)=.TRUE. !!!!!!!!!!! included
get_var(idRzet)=.TRUE.
get_var(idRu2d)=.TRUE.
get_var(idRv2d)=.TRUE.
# if defined GLS_MIXING || defined MY25_MIXING
get_var(idMtke)=.TRUE.
get_var(idMtls)=.TRUE.
get_var(idVmLS)=.TRUE.
get_var(idVmKK)=.TRUE.
# ifdef GLS_MIXING
get_var(idVmKP)=.TRUE.
! Read in nonlinear free-surface (m).
IF (get_var(idFsur)) THEN
foundit=find_string(var_name, n_var, TRIM(Vname(1,idFsur)), &
& varid)
IF (Perfect2D) THEN
gtype=var_flag(varid)*r3dvar
ELSE
gtype=var_flag(varid)*r2dvar
IF (Perfect2D) THEN
status=nf_fread3d(ng, IDmod, ncname, ncINPid, &
& Vname(1,idFsur), varid, &
& InpRec, gtype, Vsize, &
& LBi, UBi, LBj, UBj, 1, 3, &
& Fscl, Fmin, Fmax, &
# ifdef MASKING
& GRID(ng) % rmask, &
& OCEAN(ng) % zeta)
ELSE
status=nf_fread2d(ng, IDmod, ncname, ncINPid, &
& LBi, UBi, LBj, UBj, &
# ifdef MASKING
& OCEAN(ng) % zeta(:,:,Tindex))
IF (status.ne.nf90_noerr) THEN
IF (Master) THEN
WRITE (stdout,30) string, TRIM(Vname(1,idFsur)), InpRec, &
& TRIM(ncname)
exit_flag=2
ioerror=status
RETURN
ELSE
IF (Master) THEN
WRITE (stdout,70) TRIM(Vname(2,idFsur)), Fmin, Fmax
# if defined MASKING && \
defined PERFECT_RESTART
!!!!!!!!!!!!!!!!!!!!!!!!!!!!! start of inclusion
! Read in wet/dry mask in RHO-points.
IF (get_var(idRwet)) THEN
foundit=find_string(var_name, n_var, TRIM(Vname(1,idRwet)), &
& varid)
& Vname(1,idRwet), varid, &
& GRID(ng) % rmask_wet)
IF (Master) THEN
WRITE (stdout,30) string, TRIM(Vname(1,idRwet)), InpRec, &
& TRIM(ncname)
exit_flag=2
ioerror=status
RETURN
ELSE
IF (Master) THEN
WRITE (stdout,70) TRIM(Vname(2,idRwet)), Fmin, Fmax
! Read in wet/dry mask in U-points.
IF (get_var(idUwet)) THEN
foundit=find_string(var_name, n_var, TRIM(Vname(1,idUwet)), &
& varid)
gtype=var_flag(varid)*u2dvar
& Vname(1,idUwet), varid, &
& GRID(ng) % umask, &
& GRID(ng) % umask_wet)
IF (Master) THEN
WRITE (stdout,30) string, TRIM(Vname(1,idUwet)), InpRec, &
& TRIM(ncname)
exit_flag=2
ioerror=status
RETURN
ELSE
IF (Master) THEN
WRITE (stdout,70) TRIM(Vname(2,idUwet)), Fmin, Fmax
! Read in wet/dry mask in V-points.
IF (get_var(idVwet)) THEN
foundit=find_string(var_name, n_var, TRIM(Vname(1,idVwet)), &
& varid)
gtype=var_flag(varid)*v2dvar
& Vname(1,idVwet), varid, &
& GRID(ng) % vmask, &
& GRID(ng) % vmask_wet)
IF (Master) THEN
WRITE (stdout,30) string, TRIM(Vname(1,idVwet)), InpRec, &
& TRIM(ncname)
exit_flag=2
ioerror=status
RETURN
ELSE
IF (Master) THEN
WRITE (stdout,70) TRIM(Vname(2,idVwet)), Fmin, Fmax
!!!!!!!!!!!!!!!!!!!!!!!!!! end of inclusion
! Read in nonlinear RHS of free-surface.
In the history file some values are multiplied on rmask_io, umask_io, vmask_io. But theses masks are calculated in subroutine wetdry_tile (from step2d) after first output of history values (from subroutine output). To avoid this situation I've changed file set_masks.F
CALL set_masks_tile (ng, tile, model, &
& IminS, ImaxS, JminS, JmaxS, &
# ifdef UV_PSOURCE
& Msrc(ng), Nsrc(ng), &
& SOURCES(ng) % Isrc, &
& SOURCES(ng) % Jsrc, &
& SOURCES(ng) % Dsrc, &
& GRID(ng) % pmask, &
# if defined PERFECT_RESTART !!!! included
& GRID(ng) % rmask_wet, & !!!! included
& GRID(ng) % umask_wet, & !!!! included
& GRID(ng) % vmask_wet, & !!!! included
# endif !!!! included
# ifdef OUTFLOW_MASK
& GRID(ng) % mask_outflow, &
SUBROUTINE set_masks_tile (ng, tile, model, &
# ifdef UV_PSOURCE
& Msrc, Nsrc, &
& Isrc, Jsrc, Dsrc, &
& pmask, rmask, &
& umask, vmask, &
& rmask_wet, & !!!! included
& umask_wet, vmask_wet, & !!!! included
& mask_outflow, &
real(r8), intent(in) :: pmask(LBi:,LBj:)
real(r8), intent(in) :: rmask(LBi:,LBj:)
real(r8), intent(in) :: umask(LBi:,LBj:)
real(r8), intent(in) :: vmask(LBi:,LBj:)
real(r8), intent(in) :: rmask_wet(LBi:,LBj:) !!!! included
real(r8), intent(in) :: umask_wet(LBi:,LBj:) !!!! included
real(r8), intent(in) :: vmask_wet(LBi:,LBj:) !!!! included
rmask_io(LBi:UBi,LBj:UBj) = 0
umask_io(LBi:UBi,LBj:UBj) = 0
vmask_io(LBi:UBi,LBj:UBj) = 0
DO j=Jstr,JendR
DO i=Istr,IendR
pmask_io(i,j)=pmask(i,j)
DO j=JstrR,JendR
DO i=IstrR,IendR
rmask_io(i,j)=rmask(i,j) * rmask_wet(i,j)
DO j=JstrR,JendR
DO i=Istr,IendR
umask_io(i,j)=umask(i,j) * umask_wet(i,j)
DO j=Jstr,JendR
DO i=IstrR,IendR
vmask_io(i,j)=vmask(i,j) * vmask_wet(i,j)
# else
DO j=Jstr,JendR
DO i=Istr,IendR
DO j=JstrR,JendR
DO i=IstrR,IendR
DO j=JstrR,JendR
DO i=Istr,IendR
DO j=Jstr,JendR
DO i=IstrR,IendR
Values Pair in input forcing file have units Pascal. In the model its values are multiplied by 0.01 ( for millibar units). But in history and average output files should be to return to Pascal units
I've made some corrections in files wrt_his.F and wrt_avg.F
# if defined BULK_FLUXES || defined ECOSIM || defined ATM_PRESS
! Write out surface air pressure.
IF (Hout(idPair,ng)) THEN
scale=100.0_r8 !!!!!! changed
gtype=gfactor*r2dvar
IF (Aout(idPair,ng)) THEN
#ifdef CASPIAN_XXX
hh = h(i,j)+Zt_avg1(i,j)
IF (hh.LT.1.0_r8) THEN
fac_shflx = hh
! fac_shflx = 0.0_r8
ELSE
fac_shflx = 1.0_r8
#else
fac_shflx = 1.0_r8
#ifdef ICE_SHOREFAST !!!! included
fac_sf = 1.0_r8 !!!! included
#endif !!!! included
#ifdef ICESHELF
IF (zice(i,j).eq.0.0_r8) THEN
IF(ai(i,j,linew).LE.min_a(ng)) THEN
stflx(i,j,itemp) = qao_n(i,j)*fac_shflx
ELSE
And
I have not change, but in file set_avg.F compilator make warning about fac in line 2563. It is not determined. May be should be rfac(i,j) instead of fac?
IF (Aout(idTauiw,ng)) THEN
DO j=JstrR,JendR
DO i=IstrR,IendR
AVERAGE(ng)%avgutau_iw(i,j)= &
& fac*AVERAGE(ng)%avgutau_iw(i,j) !!!!!!!!!!!!!!!!!!!!!!!!
IF (EWperiodic(ng).or.NSperiodic(ng)) THEN
CALL exchange_r2d_tile (ng, tile, &
& AVERAGE(ng)%avgutau_iw)
# ifdef DISTRIBUTE
CALL mp_exchange2d (ng, tile, iNLM, 1, &
& NghostPoints, &
& EWperiodic(ng), NSperiodic(ng), &
If my corections are not true excuse me, If true, will be usefull to know it
Now I run model with its
