I am trying to use d_climatology.m script to create a climatology file for ROMS. However, when I switch on the flag S.def_v3d to 1. I get an error
>> d_climatology
NC2 Error
Error using c_climatology (line 848)
C_CLIMATOLOGY: ENDDEF - unable to leave definition mode.
Error in d_climatology (line 121)
[~]=c_climatology(S);
This error is not seen once I remove the did.Nr dimension from both u and v components
Var.dimid = [did.v3d_time did.Nr did.yu did.xu];
to
Var.dimid = [did.v3d_time did.yu did.xu];
ie removing one dimension, which of course is wrong.
Can some one help me in removing the error.
I am using R2011b version of matlab
I corrected a small typo in c_climatology.m on line 174 (changed Dname.v2d_time to Dname.v3d_time).
Ratnam
Error using c_climatology.m...
Re: Error using c_climatology.m...
I found that the problem was with allocating large arrays. So I wrote the "S.def_v3d" variables into a separate file by running the script d_climatology.m and this time setting S.def_temp and S.def_salt to zero
Ratnam
Ratnam
