inlet_test case problem
liangliang
#1 Unread post by liangliang »
I have succeed compiling inlet_test case ,but when I run it . It seems wrong. There were no error messages. When i run it , it shows " Node # 0 (pid= 0) is active.
Node # 1 (pid= 0) is active.
Node # 2 (pid= 0) is active.
Node # 3 (pid= 0) is active."
I wait for about 10 minutess ,it still show that . Nothing changed .
Could someone give me some advice ? Thank you !
$ mpirun -n 8 ./oceanM coupling_inlet_test.in
Coupled Input File name = coupling_inlet_test.in
Model Coupling Parallel Threads:
Ocean Model MPI nodes: 000 - 003
Waves Model MPI nodes: 004 - 007
Ocean Export: bath:SSH:Ubar:Vbar:ZO
Waves Export: Wdir:Wamp:Wlen:Wptop:Wpbot:Wubot
Sunday - February 17, 2013 - 3:09:51 PM
Inlet Test Case
Operating system : CYGWIN
CPU/hardware : i686
Compiler system : gfortran
Compiler command : /usr/local/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -I/home/Administrator/softwares/MCT/include -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form
Input Script : ocean_inlet_test.in
SVN Revision : 643M
Local Root : /home/Administrator/ROMS-swan/trunk
Header Dir : /home/Administrator/ROMS-swan/Projects/Inlet_test_config
Header file : inlet_test.h
Analytical Dir: /home/Administrator/ROMS-swan/Projects/Inlet_test_config
Resolution, Grid 01: 0075x0070x008, Parallel Nodes: 4, Tiling: 002x002
34560 ntimes Number of timesteps for 3-D equations.
5.000 dt Timestep size (s) for 3-D equations.
720 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
720 nHIS Number of timesteps between the writing fields
into history file.
1.0000E-03 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
5.0000E-06 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
for turbulent energy.
1.5000E-02 Zob Bottom roughness (m).
5.0000E-01 Zos Surface roughness (m).
1.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E+00 theta_b S-coordinate bottom control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
T Hout(idBath) Write out time-dependent bathymetry.
T Hout(idUbrs) Write out bottom U-current stress.
T Hout(idVbrs) Write out bottom V-current stress.
T Hout(idUbws) Write out wind-induced, bottom U-wave stress.
T Hout(idVbws) Write out wind-induced, bottom V-wave stress.
T Hout(idUbcs) Write out max wind + current, bottom U-wave stress.
T Hout(idVbcs) Write out max wind + current, bottom V-wave stress.
T Hout(idW2xx) Write out 2D radiation stress, Sxx.
T Hout(idW2xy) Write out 2D radiation stress, Sxy.
T Hout(idW2yy) Write out 2D radiation stress, Syy.
T Hout(idWamp) Write out wave height.
T Hout(idWlen) Write out wavelength.
T Hout(idWdir) Write out wave direction.
T Hout(idBott) Write out bottom property 01: grain_diameter
T Hout(idBott) Write out bottom property 02: grain_density
T Hout(idBott) Write out bottom property 03: settling_vel
T Hout(idBott) Write out bottom property 04: erosion_stress
T Hout(idBott) Write out bottom property 05: ripple_length
T Hout(idBott) Write out bottom property 06: ripple_height
T Hout(idBott) Write out bottom property 07: bed_wave_amp
T Hout(idBott) Write out bottom property 08: Zo_def
T Hout(idBott) Write out bottom property 09: Zo_app
Physical parameters File: ocean_inlet_test.in
Input Grid File: /home/Administrator/ROMS-swan/Projects/Inlet_test_config/Data/inlet_test_grid.nc
Tile partition information for Grid 01: 0075x0070x0008 tiling: 002x002
tile Istr Iend Jstr Jend Npts
0 1 38 1 35 10640
1 39 75 1 35 10360
2 1 38 36 70 10640
3 39 75 36 70 10360
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 38.50 0.50 35.50 RHO-points
1 38.50 75.50 0.50 35.50 RHO-points
2 0.50 38.50 35.50 70.50 RHO-points
3 38.50 75.50 35.50 70.50 RHO-points
0 1.00 38.50 0.50 35.50 U-points
1 38.50 75.00 0.50 35.50 U-points
2 1.00 38.50 35.50 70.50 U-points
3 38.50 75.00 35.50 70.50 U-points
0 0.50 38.50 1.00 35.50 V-points
1 38.50 75.50 1.00 35.50 V-points
2 0.50 38.50 35.50 70.00 V-points
3 38.50 75.50 35.50 70.00 V-points
HaloSizeI(1) = 150
HaloSizeJ(1) = 144
TileSide(1) = 44
TileSize(1) = 1848
Sediment Parameters, Grid: 01
Size Sd50 Csed Srho Wsed Erate poros
Class (mm) (kg/m3) (kg/m3) (mm/s) (kg/m2/s) (nondim)
1 1.0000E-01 0.0000E+00 2.6500E+03 1.0000E+01 5.0000E-03 0.0000E+00
tau_ce tau_cd nl_tnu2 nl_tnu4 Akt_bak Tnudg
(N/m2) (N/m2) (m2/s) (m4/s) (m2/s) (day)
1 1.0000E-01 1.0000E-02 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+01
New bed layer formed when deposition exceeds 0.10000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.00000E+00 (m).
Rate coefficient for bed load transport = 0.15000E+00
T Hout(idTvar) Write out sediment01: mud_01
T Hout(idfrac) Write out bed fraction, sediment 01: mudfrac_01
T Hout(idfrac) Write out mass, sediment 01: mudmass_01
T Hout(idSbed) Write out BED property 01: bed_thickness
T Hout(idSbed) Write out BED property 02: bed_age
T Hout(idSbed) Write out BED property 03: bed_porosity
zeta 1 Gradient Closed Gradient Gradient
ubar 1 Gradient Closed Gradient Reduced
vbar 1 Gradient Closed Gradient Reduced
u 1 Gradient Closed Gradient Gradient
v 1 Gradient Closed Gradient Gradient
temp 1 Gradient Closed Gradient Gradient
salt 1 Gradient Closed Gradient Gradient
mud_01 1 Gradient Closed Gradient Gradient
tke 1 Gradient Closed Gradient Gradient
INLET_TEST Inlet Test Case
ANA_BPFLUX Analytical bottom passive tracers fluxes.
ANA_SEDIMENT Analytical sediment initial conditions.
ANA_SPFLUX Analytical surface passive tracer fluxes.
FSOBC_REDUCED Using free-surface data in reduced physics conditions
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
NEARSHORE_MELLOR08 Nearshore Radiation Stress Terms (Mellor 2008).
NONLINEAR Nonlinear Model.
SEDIMENT Cohesive and noncohesive sediments.
SED_MORPH Allow bottom model elevation to evolve.
SUSPLOAD Activate suspended sediment transport.
SSW_BBL Styles and Glenn Bottom Boundary Layer - modified.
SSW_CALC_ZNOT Internal computation of bottom roughness.
SWAN_COUPLING Two-way SWAN/ROMS coupling.
UV_ADV Advection of momentum.
WAVES_OCEAN Two-way wave-ocean models coupling.
Process Information:
SWAN is preparing computation ...
liangliang
Re: inlet_test case problem
#2 Unread post by liangliang »
I find it show
at the beginning .
But it show
in the end .
Is that mean Ocean Model is active ,but there are some wrong in swan .So Waves Model MPI nodes are not active ?
But I don't know how to make it right . Could someone give me some help ?
moritz.wandres
#3 Unread post by moritz.wandres »
I seem to have encountered a similar problem. Did you find a solution yet?
#4 Unread post by jcwarner »
there is another ticket with similar issues:
viewtopic.php?f=31&t=2890&p=11075&hilit=inlet#p11075
You should not have to wait for 10 minutes for the coupled system to start. it should be instantaneous. Were there any Err* files from SWAN? if so, then the mostl likely problem is that swan cannot find one of its input files (bahty.bot or grid coord).
liangliang
#5 Unread post by liangliang »
moritz.wandres wrote:Hi,
Jwarner is right .I didn't set 'inlet_test_bathy.bot' and 'inlet_test_grid_coord.grd ' in swan_inlet_test.in.
You can try it ,it will be OK .
