nudging_sst problem
yjtack1234
nudging_sst problem
#1 Unread post by yjtack1234 »
dear all:
Hello, I have a problem with ROMS. I want to nudge SST satellite data to my model.
So, I define NUDGING_SST and input APARNAM. But, Model blows up as soon as running.
Here is my log file. give me some advice.
Or, is there any way to nudge sst data easier than NUDGING_SST?
175200 ntimes Number of timesteps for 3-D equations.
180.000 dt Timestep size (s) for 3-D equations.
10 ndtfast Number of timesteps for 2-D equations between
480 nRST Number of timesteps between the writing of data
into restart fields.
480 ninfo Number of timesteps between print of information
to standard output.
480 nHIS Number of timesteps between the writing fields
into history file.
480 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
480 nAVG Number of timesteps between the writing of
480 ndefAVG Number of timesteps between creation of new
time-averaged file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
2.0000E+01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
2.0000E+00 blk_ZQ Height (m) of surface air humidity measurement.
2 lmd_Jwt Jerlov water type.
20100101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
1.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
1.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
5.0000E+00 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
5.0000E+00 obcfac Factor between passive and active
T LtracerSrc(01) Processing point sources/Sink on tracer 01: temp
T LtracerSrc(02) Processing point sources/Sink on tracer 02: salt
T Hout(idSrad) Write out shortwave radiation flux.
T Hout(idLrad) Write out longwave radiation flux.
T Hout(idLhea) Write out latent heat flux.
T Hout(idShea) Write out sensible heat flux.
T Hout(idVvis) Write out vertical viscosity coefficient.
T Hout(idTdif) Write out vertical T-diffusion coefficient.
T Hout(idSdif) Write out vertical S-diffusion coefficient.
T Hout(idHsbl) Write out depth of surface boundary layer.
T Hout(idHbbl) Write out depth of bottom boundary layer.
Output Restart File: ../output/test2/ocean_rst.nc
Prefix for History Files: ../output/test2/ocean_his
Prefix for Averages Files: ../output/test2/ocean_avg
Input Grid File: ../../input2_2/08_ep/1993/roms_grid2_ADD_08_2_ep.nc
Input Nonlinear Initial File: ../../input2_2/08_ep/1993/roms_add2_08_2ep_ini.nc
Input Forcing File 01: ../../input2_2/08_ep/1993/frc_ecmwf_1993Pair_365.nc
Input Forcing File 02: ../../input2_2/08_ep/1993/frc_ecmwf_1993Qair_365.nc
Input Forcing File 03: ../../input2_2/08_ep/1993/frc_ecmwf_1993swradd_365.nc
Input Forcing File 04: ../../input2_2/08_ep/1993/frc_ecmwf_1993Tair_365.nc
Input Forcing File 05: ../../input2_2/08_ep/1993/frc_ecmwf_1993Uwind_365.nc
Input Forcing File 06: ../../input2_2/08_ep/1993/frc_ecmwf_1993Vwind_365.nc
Input Forcing File 07: ../../input2_2/08_ep/1993/roms_river_add2_2_1993.nc
Input Climatology File: ../../input2_2/08_ep/1993/roms_clm.nc
Input Boundary File: ../../input2_2/08_ep/1993/roms_add2_2_bry_SODA-Y1993.nc
Assimilation Parameters File: ./assimilation_sst.in
Tile partition information for Grid 01: 0332x0384x0040 tiling: 008x008
tile Istr Iend Jstr Jend Npts
0 1 40 1 48 76800
1 41 82 1 48 80640
2 83 124 1 48 80640
3 125 166 1 48 80640
4 167 208 1 48 80640
5 209 250 1 48 80640
6 251 292 1 48 80640
7 293 332 1 48 76800
8 1 40 49 96 76800
9 41 82 49 96 80640
10 83 124 49 96 80640
11 125 166 49 96 80640
12 167 208 49 96 80640
13 209 250 49 96 80640
14 251 292 49 96 80640
15 293 332 49 96 76800
16 1 40 97 144 76800
17 41 82 97 144 80640
18 83 124 97 144 80640
19 125 166 97 144 80640
20 167 208 97 144 80640
21 209 250 97 144 80640
22 251 292 97 144 80640
23 293 332 97 144 76800
24 1 40 145 192 76800
25 41 82 145 192 80640
26 83 124 145 192 80640
27 125 166 145 192 80640
28 167 208 145 192 80640
29 209 250 145 192 80640
30 251 292 145 192 80640
31 293 332 145 192 76800
32 1 40 193 240 76800
33 41 82 193 240 80640
34 83 124 193 240 80640
35 125 166 193 240 80640
36 167 208 193 240 80640
37 209 250 193 240 80640
38 251 292 193 240 80640
39 293 332 193 240 76800
40 1 40 241 288 76800
41 41 82 241 288 80640
42 83 124 241 288 80640
43 125 166 241 288 80640
44 167 208 241 288 80640
45 209 250 241 288 80640
46 251 292 241 288 80640
47 293 332 241 288 76800
48 1 40 289 336 76800
49 41 82 289 336 80640
50 83 124 289 336 80640
51 125 166 289 336 80640
52 167 208 289 336 80640
53 209 250 289 336 80640
54 251 292 289 336 80640
55 293 332 289 336 76800
56 1 40 337 384 76800
57 41 82 337 384 80640
58 83 124 337 384 80640
59 125 166 337 384 80640
60 167 208 337 384 80640
61 209 250 337 384 80640
62 251 292 337 384 80640
63 293 332 337 384 76800
HaloSizeI(1) = 108
HaloSizeJ(1) = 120
TileSide(1) = 54
TileSize(1) = 2592
EASTASIANSEAS Northwest Pacific ADD
ADD_FSOBC Adding tidal elevation to proccesed OBC data.
ADD_M2OBC Adding tidal currents to proccesed OBC data.
ANA_CLOUD Analytical cloud fraction.
ANA_RAIN Analytical rain fall rate.
AVERAGES_AKS Writing out time-averaged vertical S-diffusion.
AVERAGES_AKT Writing out time-averaged vertical T-diffusion.
AVERAGES_FLUXES Writing out time-averaged surface fluxes.
BULK_FLUXES Surface bulk fluxes parametererization.
DIURNAL_SRFLUX Modulate shortwave radiation by the local diurnal cycle.
EAST_M3CLAMPED Eastern edge, 3D momentum, Clamped condition.
EAST_TCLAMPED Eastern edge, tracers, Clamped condition.
EAST_VOLCONS Eastern edge, enforce mass conservation.
LMD_BKPP KPP bottom boundary layer mixing.
LONGWAVE Compute net longwave radiation internally.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTH_VOLCONS Northern edge, enforce mass conservation.
NORTH_FSCHAPMAN Northern edge, free-surface, Chapman condition.
NORTH_M2FLATHER Northern edge, 2D momentum, Flather condition.
NORTH_M3CLAMPED Northern edge, 3D momentum, Clamped condition.
NORTH_TCLAMPED Northern edge, tracers, Clamped condition.
NUDGING_SST Nudging SST observations.
SALINITY Using salinity.
SOUTH_M3CLAMPED Southern edge, 3D momentum, Clamped condition.
SOUTH_TCLAMPED Southern edge, tracers, Clamped condition.
SOUTH_VOLCONS Southern edge, enforce mass conservation.
TCLIMATOLOGY Processing tracer climatology data.
TCLM_NUDGING Nudging toward tracer climatology.
TS_PSOURCE Tracers point sources and sinks.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_SADVECTION Parabolic splines vertical advection of momentum.
UV_PSOURCE Mass point sources and sinks.
WEST_FSCHAPMAN Western edge, free-surface, Chapman condition.
WEST_M2FLATHER Western edge, 2D momentum, Flather condition.
WEST_M3CLAMPED Western edge, 3D momentum, Clamped condition.
WEST_TCLAMPED Western edge, tracers, Clamped condition.
WEST_VOLCONS Western edge, enforce mass conservation.
Vertical S-coordinate System:
40 0.0000000 0.0000000 0.000 0.000 0.000
39 -0.0250000 -0.0017775 -0.125 -4.564 -9.003
38 -0.0500000 -0.0037835 -0.250 -9.699 -19.149
37 -0.0750000 -0.0060921 -0.375 -15.590 -30.805
36 -0.1000000 -0.0087922 -0.500 -22.458 -44.417
35 -0.1250000 -0.0119914 -0.625 -30.573 -60.522
34 -0.1500000 -0.0158197 -0.750 -40.260 -79.769
33 -0.1750000 -0.0204330 -0.875 -51.907 -102.938
32 -0.2000000 -0.0260168 -1.000 -65.977 -130.954
31 -0.2250000 -0.0327879 -1.125 -83.013 -164.901
30 -0.2500000 -0.0409944 -1.250 -103.634 -206.017
29 -0.2750000 -0.0509117 -1.375 -128.527 -255.679
28 -0.3000000 -0.0628318 -1.500 -158.422 -315.345
27 -0.3250000 -0.0770446 -1.625 -194.044 -386.463
26 -0.3500000 -0.0938098 -1.750 -236.040 -470.330
25 -0.3750000 -0.1133185 -1.875 -284.888 -567.901
24 -0.4000000 -0.1356491 -2.000 -340.784 -679.567
23 -0.4250000 -0.1607245 -2.125 -403.534 -804.944
22 -0.4500000 -0.1882840 -2.250 -472.489 -942.729
21 -0.4750000 -0.2178817 -2.375 -546.535 -1090.694
20 -0.5000000 -0.2489214 -2.500 -624.181 -1245.862
19 -0.5250000 -0.2807264 -2.625 -703.739 -1404.853
18 -0.5500000 -0.3126323 -2.750 -783.549 -1564.348
17 -0.5750000 -0.3440788 -2.875 -862.212 -1721.549
16 -0.6000000 -0.3746809 -3.000 -938.766 -1874.531
15 -0.6250000 -0.4042644 -3.125 -1012.775 -2022.425
14 -0.6500000 -0.4328656 -3.250 -1084.332 -2165.414
13 -0.6750000 -0.4607052 -3.375 -1153.986 -2304.597
12 -0.7000000 -0.4881475 -3.500 -1222.648 -2441.797
11 -0.7250000 -0.5156591 -3.625 -1291.484 -2579.342
10 -0.7500000 -0.5437741 -3.750 -1361.826 -2719.902
9 -0.7750000 -0.5730691 -3.875 -1435.115 -2866.355
8 -0.8000000 -0.6041494 -4.000 -1512.863 -3021.726
7 -0.8250000 -0.6376434 -4.125 -1596.639 -3189.154
6 -0.8500000 -0.6742046 -4.250 -1688.076 -3371.902
5 -0.8750000 -0.7145184 -4.375 -1788.885 -3573.394
4 -0.9000000 -0.7593114 -4.500 -1900.880 -3797.260
3 -0.9250000 -0.8093643 -4.625 -2026.012 -4047.400
2 -0.9500000 -0.8655258 -4.750 -2166.401 -4328.051
1 -0.9750000 -0.9287272 -4.875 -2324.371 -4643.868
0 -1.0000000 -1.0000000 -5.000 -2502.500 -5000.000
Time Splitting Weights: ndtfast = 10 nfast = 15
1 0.0014850648765542 0.1000000000000000 0.0014850648765542 0.1000000000000000
2 0.0059386031399402 0.0998514935123446 0.0074236680164944 0.1998514935123446
3 0.0133457074936657 0.0992576331983505 0.0207693755101601 0.2991091267106951
4 0.0236484051180389 0.0979230624489840 0.0444177806281990 0.3970321891596791
5 0.0366959666818608 0.0955582219371801 0.0811137473100598 0.4925904110968592
6 0.0521753389587948 0.0918886252689940 0.1332890862688545 0.5844790363658532
7 0.0695217010484137 0.0866710913731145 0.2028107873172682 0.6711501277389678
8 0.0878091442019233 0.0797189212682732 0.2906199315191915 0.7508690490072409
9 0.1056214752525633 0.0709380068480809 0.3962414067717548 0.8218070558553218
10 0.1209031436506851 0.0603758593228245 0.5171445504224399 0.8821829151781463
11 0.1307902921035067 0.0482855449577560 0.6479348425259466 0.9304684601359023
12 0.1314219308195445 0.0352065157474054 0.7793567733454911 0.9656749758833076
13 0.1177312353577227 0.0220643226654509 0.8970880087032138 0.9877392985487585
14 0.0832169680811588 0.0102911991296786 0.9803049767843727 0.9980304976784371
15 0.0196950232156274 0.0019695023215627 1.0000000000000000 0.9999999999999999
ndtfast, nfast = 10 15 nfast/ndtfast = 1.50000
1.000000000000 1.083803072626 0.541901536313 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.00000
Minimum X-grid spacing, DXmin = 7.60025906E+00 km
Maximum X-grid spacing, DXmax = 1.17437346E+01 km
Minimum Y-grid spacing, DYmin = 7.61770607E+00 km
Maximum Y-grid spacing, DYmax = 1.17402060E+01 km
Minimum Z-grid spacing, DZmin = 1.25000000E-01 m
Maximum Z-grid spacing, DZmax = 3.56132476E+02 m
Minimum barotropic Courant Number = 1.66925614E-02
Maximum barotropic Courant Number = 6.46860676E-01
Maximum Coriolis Courant Number = 2.06333617E-02
(File: roms_add2_08_2ep_ini.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = -2.43266248E+00 Max = 2.69932123E+01)
- salinity
(Min = 2.90106609E+01 Max = 3.52245790E+01)
GET_NGFLD - tidal period
(Min = 4.30819210E+04 Max = 2.38071599E+06)
(Min = 4.85051667E-05 Max = 1.73504087E+01)
(Min = 8.99863721E-07 Max = 6.28316973E+00)
(Min = 4.97278241E-06 Max = 6.28318402E+00)
(Min = 8.71432860E-07 Max = 6.28317602E+00)
(Min = 1.32779225E-06 Max = 2.21848579E+00)
(Min = -6.09852072E-01 Max = 4.17190933E-01)
(Min = 2.50000000E+01 Max = 1.26000000E+02)
(Min = 1.42000000E+02 Max = 2.39000000E+02)
(Min = 0.00000000E+00 Max = 1.00000000E+00)
(Min = 2.50000004E-02 Max = 2.50000004E-02)
GET_NGFLD - river runoff mass transport, t = 345 00:00:00
(Rec=0012, Index=2, File: roms_river_add2_2_1993.nc)
(Min = -6.85000000E+02 Max = 1.82000000E+04)
GET_NGFLD - river runoff potential temperature, t = 345 00:00:00
(Min = 4.08249998E+00 Max = 1.15649996E+01)
GET_NGFLD - river runoff salinity, t = 345 00:00:00
GET_2DFLD - surface u-wind component, t = 364 12:00:00
(Rec=0365, Index=1, File: frc_ecmwf_1993Uwind_365.nc)
(Tmin= 0.5000 Tmax= 364.5000)
(Min = -1.00494452E+01 Max = 9.66639423E+00)
GET_2DFLD - surface v-wind component, t = 364 12:00:00
(Rec=0365, Index=1, File: frc_ecmwf_1993Vwind_365.nc)
(Min = -1.30453968E+01 Max = 1.74682617E+01)
GET_2DFLD - surface air pressure, t = 364 12:00:00
(Rec=0365, Index=1, File: frc_ecmwf_1993Pair_365.nc)
(Min = 9.91656677E+02 Max = 1.03156396E+03)
GET_2DFLD - solar shortwave radiation flux, t = 364 12:00:00
(Rec=0365, Index=1, File: frc_ecmwf_1993swradd_365.nc)
(Min = 5.76239458E-07 Max = 3.86578192E-05)
GET_2DFLD - surface air temperature, t = 364 12:00:00
(Rec=0365, Index=1, File: frc_ecmwf_1993Tair_365.nc)
(Min = -3.20782394E+01 Max = 2.68132095E+01)
GET_2DFLD - surface air relative humidity, t = 364 12:00:00
(Rec=0365, Index=1, File: frc_ecmwf_1993Qair_365.nc)
(Min = 2.91812077E-01 Max = 9.57439880E-01)
GET_NGFLD - free-surface western boundary condition, t = 345 00:00:00
(Rec=0012, Index=2, File: roms_add2_2_bry_SODA-Y1993.nc)
(Min = -1.30773351E-01 Max = 7.71431506E-01)
(Min = -3.23135282E-01 Max = 1.03932746E+00)
(Min = 3.06237587E-01 Max = 9.48591274E-01)
GET_NGFLD - free-surface northern boundary condition, t = 345 00:00:00
(Min = -2.87908625E-01 Max = 4.87641655E-02)
GET_NGFLD - 2D u-momentum western boundary condition, t = 345 00:00:00
(Min = -1.15328573E-01 Max = 1.49283795E-04)
GET_NGFLD - 2D v-momentum western boundary condition, t = 345 00:00:00
(Min = -6.04844360E-02 Max = 1.49208666E-04)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 345 00:00:00
(Min = -4.94660487E-02 Max = 7.35969206E-02)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 345 00:00:00
(Min = -2.78450633E-02 Max = 5.80423266E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 345 00:00:00
(Min = -3.22142262E-02 Max = 4.66335363E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 345 00:00:00
(Min = -2.16974921E-02 Max = 6.95386598E-02)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 345 00:00:00
(Min = -2.43963767E-03 Max = 1.79442171E-02)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 345 00:00:00
(Min = -2.27926676E-02 Max = 3.94947392E-02)
GET_NGFLD - 3D u-momentum western boundary condition, t = 345 00:00:00
(Min = -3.39760687E-01 Max = 4.08816604E-02)
GET_NGFLD - 3D v-momentum western boundary condition, t = 345 00:00:00
(Min = -1.07088160E-01 Max = 6.54563796E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 345 00:00:00
(Min = -2.74079328E-01 Max = 4.83699049E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 345 00:00:00
(Min = -1.33970777E-01 Max = 3.42267690E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 345 00:00:00
(Min = -3.07057950E-01 Max = 1.15894191E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 345 00:00:00
(Min = -2.03669770E-01 Max = 6.30104647E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 345 00:00:00
(Min = -1.67717470E-02 Max = 5.58414561E-02)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 345 00:00:00
(Min = -1.18416991E-01 Max = 9.26704737E-02)
GET_NGFLD - temperature western boundary condition, t = 345 00:00:00
(Min = 1.80255201E+00 Max = 2.60598279E+01)
GET_NGFLD - salinity western boundary condition, t = 345 00:00:00
(Min = 3.02756577E+01 Max = 3.47565802E+01)
GET_NGFLD - temperature eastern boundary condition, t = 345 00:00:00
(Min = -4.34928980E-01 Max = 2.79747379E+01)
GET_NGFLD - salinity eastern boundary condition, t = 345 00:00:00
(Min = 3.24857270E+01 Max = 3.52342948E+01)
GET_NGFLD - temperature southern boundary condition, t = 345 00:00:00
(Min = 1.04792269E+00 Max = 2.81506726E+01)
GET_NGFLD - salinity southern boundary condition, t = 345 00:00:00
(Min = 3.37780916E+01 Max = 3.51951563E+01)
GET_NGFLD - temperature northern boundary condition, t = 345 00:00:00
(Min = -2.53488623E-01 Max = 7.72190237E+00)
GET_NGFLD - salinity northern boundary condition, t = 345 00:00:00
(Min = 3.12212846E+01 Max = 3.44721993E+01)
GET_3DFLD - potential temperature climatology, t = 345 00:00:00
(Rec=0012, Index=1, File: roms_clm.nc)
(Min = -1.84504335E+00 Max = 2.80750065E+01)
GET_3DFLD - salinity climatology, t = 345 00:00:00
(Min = 2.82957318E+01 Max = 3.52148349E+01)
GET_2DFLD - sea surface temperature observations, t = 364 12:00:00
(Rec=0073, Index=1, File: roms_5days_sate1993.nc)
(Tmin= 4.5000 Tmax= 364.5000)
(Min = -1.07333331E+00 Max = 2.74470496E+01)
GET_2DFLD - sea surface temperature error variance, t = 364 12:00:00
(Min = 5.00000000E-01 Max = 5.00000000E-01)
Maximum grid stiffness ratios: rx0 = 8.485815E-01 (Beckmann and Haidvogel)
rx1 = 3.248332E+01 (Haney)
Initial basin volumes: TotVolume = 2.6588166380E+16 m3
MinVolume = 7.4300392740E+06 m3
MaxVolume = 4.9071852037E+10 m3
Max/Min = 6.6045212182E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00175200)
GET_NGFLD - river runoff mass transport, t = 15 00:00:00
(Rec=0001, Index=1, File: roms_river_add2_2_1993.nc)
(Min = -6.56000000E+02 Max = 1.05000000E+04)
GET_NGFLD - river runoff potential temperature, t = 15 00:00:00
(Min = -1.47559571E+00 Max = 7.49845791E+00)
GET_NGFLD - river runoff salinity, t = 15 00:00:00
GET_2DFLD - surface u-wind component, t = 0 12:00:00
(Rec=0001, Index=2, File: frc_ecmwf_1993Uwind_365.nc)
(Min = -8.87222862E+00 Max = 9.14228916E+00)
GET_2DFLD - surface v-wind component, t = 0 12:00:00
(Rec=0001, Index=2, File: frc_ecmwf_1993Vwind_365.nc)
(Min = -1.48801384E+01 Max = 6.07381105E+00)
GET_2DFLD - surface air pressure, t = 0 12:00:00
(Rec=0001, Index=2, File: frc_ecmwf_1993Pair_365.nc)
(Min = 1.01194104E+03 Max = 1.02739099E+03)
GET_2DFLD - solar shortwave radiation flux, t = 0 12:00:00
(Rec=0001, Index=2, File: frc_ecmwf_1993swradd_365.nc)
(Min = 2.09976735E-06 Max = 3.78373290E-05)
GET_2DFLD - surface air temperature, t = 0 12:00:00
(Rec=0001, Index=2, File: frc_ecmwf_1993Tair_365.nc)
(Min = -2.41697655E+01 Max = 2.54901142E+01)
GET_2DFLD - surface air relative humidity, t = 0 12:00:00
(Rec=0001, Index=2, File: frc_ecmwf_1993Qair_365.nc)
(Min = 4.54055710E-01 Max = 9.27759018E-01)
GET_NGFLD - free-surface western boundary condition, t = 15 00:00:00
(Rec=0001, Index=1, File: roms_add2_2_bry_SODA-Y1993.nc)
(Min = -8.52844417E-02 Max = 6.53009295E-01)
(Min = -3.83937883E-01 Max = 1.03107993E+00)
(Min = 4.05198028E-01 Max = 8.66083701E-01)
GET_NGFLD - free-surface northern boundary condition, t = 15 00:00:00
(Min = -2.76816204E-01 Max = -2.41349568E-02)
GET_NGFLD - 2D u-momentum western boundary condition, t = 15 00:00:00
(Min = -4.70838303E-02 Max = 2.29165856E-03)
GET_NGFLD - 2D v-momentum western boundary condition, t = 15 00:00:00
(Min = -3.33806707E-02 Max = 4.80133258E-04)
(Min = -6.35672237E-02 Max = 8.32791361E-02)
(Min = -3.58092570E-02 Max = 4.67241032E-02)
(Min = -2.68170841E-02 Max = 2.38523732E-02)
(Min = -1.93366955E-02 Max = 2.59837296E-02)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 15 00:00:00
(Min = -3.58531301E-02 Max = 1.68521071E-02)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 15 00:00:00
(Min = -2.57071684E-02 Max = 1.56803027E-02)
GET_NGFLD - 3D u-momentum western boundary condition, t = 15 00:00:00
(Min = -2.25821645E-01 Max = 4.49971464E-02)
GET_NGFLD - 3D v-momentum western boundary condition, t = 15 00:00:00
(Min = -1.13449953E-01 Max = 4.10675805E-02)
(Min = -2.58205333E-01 Max = 5.45059981E-01)
(Min = -1.81034366E-01 Max = 1.29429299E-01)
(Min = -2.91163975E-01 Max = 1.44907935E-01)
(Min = -1.62255872E-01 Max = 5.42261881E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 15 00:00:00
(Min = -6.85694235E-02 Max = 5.25595157E-02)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 15 00:00:00
(Min = -1.25952294E-01 Max = 3.11934491E-02)
GET_NGFLD - temperature western boundary condition, t = 15 00:00:00
(Min = 1.81182228E+00 Max = 2.44203925E+01)
GET_NGFLD - salinity western boundary condition, t = 15 00:00:00
(Min = 3.03083383E+01 Max = 3.46355019E+01)
(Min = -1.11165111E+00 Max = 2.62109885E+01)
(Min = 3.27699372E+01 Max = 3.51476733E+01)
(Min = 1.03954967E+00 Max = 2.64998003E+01)
(Min = 3.30762672E+01 Max = 3.51479991E+01)
GET_NGFLD - temperature northern boundary condition, t = 15 00:00:00
(Min = -8.31919429E-01 Max = 4.76351833E+00)
GET_NGFLD - salinity northern boundary condition, t = 15 00:00:00
(Min = 3.19473957E+01 Max = 3.44690172E+01)
GET_3DFLD - potential temperature climatology, t = 15 00:00:00
(Rec=0001, Index=2, File: roms_clm.nc)
GET_3DFLD - salinity climatology, t = 15 00:00:00
GET_2DFLD - sea surface temperature observations, t = 4 12:00:00
(Rec=0001, Index=2, File: roms_5days_sate1993.nc)
(Min = -1.42442767E+00 Max = 2.68864955E+01)
GET_2DFLD - sea surface temperature error variance, t = 4 12:00:00
0 0 00:00:00 3.109088E-06 2.134717E+04 2.134717E+04 2.662330E+16
DEF_HIS - creating history file: ../output/test2/ocean_his_0001.nc
GET_2DFLD - surface u-wind component, t = 1 12:00:00
(Rec=0002, Index=1, File: frc_ecmwf_1993Uwind_365.nc)
(Min = -9.01124763E+00 Max = 1.14758062E+01)
GET_2DFLD - surface v-wind component, t = 1 12:00:00
(Rec=0002, Index=1, File: frc_ecmwf_1993Vwind_365.nc)
(Min = -7.66629934E+00 Max = 1.14586620E+01)
GET_2DFLD - surface air pressure, t = 1 12:00:00
(Rec=0002, Index=1, File: frc_ecmwf_1993Pair_365.nc)
(Min = 1.00684985E+03 Max = 1.03398645E+03)
GET_2DFLD - solar shortwave radiation flux, t = 1 12:00:00
(Rec=0002, Index=1, File: frc_ecmwf_1993swradd_365.nc)
(Min = 1.33823110E-06 Max = 3.99642596E-05)
GET_2DFLD - surface air temperature, t = 1 12:00:00
(Rec=0002, Index=1, File: frc_ecmwf_1993Tair_365.nc)
(Min = -2.28215714E+01 Max = 2.56358318E+01)
GET_2DFLD - surface air relative humidity, t = 1 12:00:00
(Rec=0002, Index=1, File: frc_ecmwf_1993Qair_365.nc)
(Min = 3.65235634E-01 Max = 9.48288193E-01)
480 1 00:00:00 NaN NaN NaN NaN
Re: nudging_sst problem
Does it run without nudging? Blowing up in the first timestep is kind of suspicious.
NUDGING_SST was taken out completely at some point for being a bad idea.
yjtack1234
#3 Unread post by yjtack1234 »
Thank you for reply.
Model run without nudging_sst. I found another way that is QCORRECTION. But, I dont understand completely dQdSST variable. So, I input dQdSST=-40 without reason. Model is running well for now. Please give me some tips about dQdSST.
Sorry, it was NUDGING_SSH that used to be there. The code I have now has neither NUDGING_SST nor NUDGING_SSH. Which code are you using?
dQdSST is the change in heat flux due to changes in the surface temperature. Surface heat flux is strongly related to surface temperature, so if you have an externally computed heat flux, it could do the wrong thing where your SST doesn't match that used to compute the heat flux.
