Extracting depth associated with each level
tnmiles
#1 Unread post by tnmiles »
I'm extracting data on s-levels but want to know what depths the points in each of these levels are associated with as a 2-d grid. Would I have to calculate this using the stretching parameter, or is there an easy way to output this? I'm currently using roms_sview to get each levels u and v data, and then rotating them using roms_uvrhotate. So I have a 2-d map on a single level. I'd like to find out the depths associated with this 2-d level.
Re: Extracting depth associated with each level
#2 Unread post by arango »
You are using John Wilkin Matlab scripts. I always use matlab/utility/depths.m from the ROMS Matlab repostory :arrow: https://www.myroms.org/svn/src/matlab. Or I use the ROMS grid structure computed from matlab/grid/get_roms_grid.m. See :arrow: WikiROMS for details.
tnmiles
#3 Unread post by tnmiles »
Got it, thanks!
