REASON: Attempting netcdf-4 operation on netcdf-3 file
andre_belem
#1 Unread post by andre_belem »
I just moved to a new Ubuntu 12.04 machine and installed netcdf from source, with special attention to netcdf-4.2.1.1 for the CC compiler (using --disable-netcdf-4 option) and netcdf-fortran-4.2 for netcdf.mod.
Everything installed, I compiled ROMS with no problems and tested the UPWELLING example.
Everything was fine, until I installed with sudo apt-get install the ferret-vis package and then - BUMP!
NETCDF_CREATE - unable to create output NetCDF file:
ocean_his.nc
call from: def_his.F
I found a mismatch between what I installed previously (/usr/local/netcdf) with "some" netcdf scratch from ferret-vis.
So, I have no idea why the program is now giving me this error because NETCDF_DIR is correctly set in my Compilers/Linux-gfortran.mk
Any idea what I'm doing wrong and why it worked for the first time ?
Cheers
Dr.Andre L. Belem
Project Manager - Physical Oceanography and Offshore Operations
UFF/ANP/Petrobras
Department of Geochemistry - Fluminense Federal University
Niteroi - RJ - Brazil
Skype: andre.lbelem Email: andre_belem@geoq.uff.br
andre_belem
Re: REASON: Attempting netcdf-4 operation on netcdf-3 file
#2 Unread post by andre_belem »
bump ? :shock:
Dr.Andre L. Belem
UFF/ANP/Petrobras
#3 Unread post by kate »
Well, going to the source, in mod_netcdf.F the file creation mode starts as:
#if defined HDF5
!     integer :: CMODE = nf90_hdf5         ! NetCDF-4/HDF5 format file
      integer :: CMODE = nf90_netcdf4      ! NetCDF-4/HDF5 format file
#else
      integer :: CMODE = nf90_64bit_offset ! NetCDF 64-bit offset format
!                                            (large file support)
I assume you don't have HDF5 defined, so it should be attempting the 64bit_offset mode. Can you write a test code to create such a file with your library?
andre_belem
#4 Unread post by andre_belem »
Hi Kate,
yes...I don't have HDF5 because I installed netcdf with --disable-netcdf-4 option.
I can't create any file (same error) but it doesn't explain "why" it worked for the first run and now doesn't work any more.
I tried again to install everything from a fresh install and now doesn't work neither the first run.
I guess it has something to do with netcdf versions (I have both netcdf-3 and -4 because ferret, GMT, etc etc). May be I have to refresh all netcdf links. But...it still doesn't explain why worked for just one run.
Dr.Andre L. Belem
UFF/ANP/Petrobras
