I am configuring a model. It seems that the dimensions of my input files are not consistent.
After an examination of all 6 input files, I could not figure it out which file has the wrong dimension.
I am posting the error and information about six input files. Hope someone could help me out!
Thanks in advance!
Fan
My Lm = 304, Mm = 240
Lp = 306, Mp = 242
Error
INITIAL: Configurating and initializing forward nonlinear model ...
OPENCDF - inconsistent size of dimension: xi_psi 305 141
ROMS/TOMS - IO error ................ exit_flag: 4
Elapsed CPU time (seconds):
Node # 1 CPU: 0.165
Node # 2 CPU: 0.167 Node # 0 CPU: 0.164
Node # 3 CPU: 0.170
Total: 0.667
Total: 0.000 0.0000
Message Passage: data broadcast .................. 0.001 ( 0.1477 %)
Total: 0.001 0.1477
All pecentages are with respect to total time = 0.667
ERROR: OPENCDF - Can not open NetCDF file.
REASON: No error
Grid file
dimensions:
xi_psi = 305 ;
xi_rho = 306 ;
xi_u = 305 ;
xi_v = 306 ;
eta_psi = 241 ;
eta_rho = 242 ;
eta_u = 242 ;
eta_v = 241 ;
two = 2 ;
bath = UNLIMITED ; // (0 currently)
initial file
-init {
dimensions:
xi_rho = 306 ;
xi_u = 305 ;
xi_v = 306 ;
eta_rho = 242 ;
eta_u = 242 ;
eta_v = 241 ;
s_rho = 24 ;
s_w = 25 ;
tracer = 2 ;
time = UNLIMITED ; // (1 currently)
boundary file
bry {
dimensions:
xi_rho = 306 ;
xi_u = 305 ;
xi_v = 306 ;
eta_rho = 242 ;
eta_u = 242 ;
eta_v = 241 ;
s_rho = 24 ;
s_w = 25 ;
bry_time = 12 ;
climatology file
clim {
dimensions:
xi_rho = 306 ;
xi_u = 305 ;
xi_v = 306 ;
eta_rho = 242 ;
eta_u = 242 ;
eta_v = 241 ;
s_rho = 24 ;
s_w = 25 ;
tracer = 2 ;
tclm_time = 12 ;
sclm_time = 12 ;
ssh_time = 12 ;
uclm_time = 12 ;
vclm_time = 12 ;
ocean_time = 12 ;
wind forcing
forc-winds {
dimensions:
xi_rho = 306 ;
xi_u = 305 ;
xi_v = 306 ;
eta_rho = 242 ;
eta_u = 242 ;
eta_v = 241 ;
sms_time = 2925 ;
heat fluxes
forc-others {
dimensions:
xi_rho = 306 ;
xi_u = 305 ;
xi_v = 306 ;
eta_rho = 242 ;
eta_u = 242 ;
eta_v = 241 ;
shf_time = 24 ;
swf_time = 24 ;
sst_time = 24 ;
sss_time = 24 ;
srf_time = 24 ;
Help: Inconsistent dimensions in input files
Re: Help: Inconsistent dimensions in input files
None of the files you show have a dimension of xi_psi=141. Are you sure that's not coming from the ocean.in file or some other file?
Kate, thanks very much for your reply.
Actually, the problem is in the cppdefs.h file; it is reading another application.
kate wrote:None of the files you show have a dimension of xi_psi=141. Are you sure that's not coming from the ocean.in file or some other file?
