variable change from kout to kstp(ng) when compling
xiaozhu557
#1 Unread post by xiaozhu557 »
Hello Everyone,
I found some variables name changed while compling from *.F to *.f90. Such as
in the file wrt_his.F Line 509
        status=nf_fwrite3d(ng, iNLM, HIS(ng)%ncid, HIS(ng)%Vid(idUvel), &
     &                     HIS(ng)%Rindex, gtype,                       &
     &                     LBi, UBi, LBj, UBj, 1, N(ng), scale,         &
# ifdef MASKING
     &                     GRID(ng) % umask_io,                         &
     &                     OCEAN(ng) % u(:,:,:,NOUT))
but in the file wrt_his.f90, it is as follow
     &                     OCEAN(ng) % u(:,:,:,nrhs(ng)))
NOUT changed to nrhs(ng)
OR in the file wrt_his.F
status=nf_fwrite2d(ng, iNLM, HIS(ng)%ncid, HIS(ng)%Vid(idUbar), &
     &                     LBi, UBi, LBj, UBj, scale,                   &
#ifdef MASKING
     &                     OCEAN(ng) % ubar(:,:,KOUT))
     &                     OCEAN(ng) % ubar(:,:,kstp(ng)))
KOUT changed to kstp(ng)
Anyone know what is the reason for that? Thanks.
Re: variable change from kout to kstp(ng) when compling
This is happening in the C preprocessor stage and is entirely intentional. If you look in globaldefs.h, you see:
** Set output index for multi-time levels variables.
#ifdef SOLVE3D
# if defined TANGENT || defined TL_IOMS
#  define TKOUT kstp(ng)
#  define KOUT kstp(ng)
#  define NOUT nrhs(ng)
# else
#else
# define KOUT knew(ng)
So we want one thing with the tangent linear, something else otherwise.
