Since I am working on the NEMURO model, I will follow the script name for this model. But other biological models are also applied.
In the standard input file (ocean.in), you can define different boundary conditions for the nonlinear model and the adjoint model for physical variables.
Then the boundary condition for tangent linear and representer model is assigned in the "read_phypar.F" (line 2671-2691).
#if defined TANGENT || defined TL_IOMS
! Set lateral boundary condition switches for the tangent linear
! models (TLM and RPM) to the same values as the adjoint model.
DO ivar=1,nLBCvar
DO i=1,4
tl_LBC(i,ivar,ng)%acquire =ad_LBC(i,ivar,ng)%acquire
tl_LBC(i,ivar,ng)%Chapman =ad_LBC(i,ivar,ng)%Chapman
tl_LBC(i,ivar,ng)%clamped =ad_LBC(i,ivar,ng)%clamped
tl_LBC(i,ivar,ng)%closed =ad_LBC(i,ivar,ng)%closed
tl_LBC(i,ivar,ng)%Flather =ad_LBC(i,ivar,ng)%Flather
tl_LBC(i,ivar,ng)%gradient =ad_LBC(i,ivar,ng)%gradient
tl_LBC(i,ivar,ng)%nested =ad_LBC(i,ivar,ng)%nested
tl_LBC(i,ivar,ng)%nudging =ad_LBC(i,ivar,ng)%nudging
tl_LBC(i,ivar,ng)%periodic =ad_LBC(i,ivar,ng)%periodic
tl_LBC(i,ivar,ng)%radiation=ad_LBC(i,ivar,ng)%radiation
tl_LBC(i,ivar,ng)%reduced =ad_LBC(i,ivar,ng)%reduced
The issue is that there is no statement for assigning "tl_LBC" in the function "read_BioPar", or the script "nemuro_inp.h".
So "tl_LBC" may not the same as "ad_LBC" that you give in the "nemuro.in".
My quick fix was just to add the same assigning statement in the "nemuro_inp.h".
I believe there should be better fix for this bug.
I hope I explained this clearly.
