shortwave solar radiation in ROMS surface forcing
I have a question about the shortwave radiation in the surface forcing. For long wave radiation, you can either input downwelling long wave radiation or net long wave radiation. But for shortwave radiation, it is not so clear. When I looked into the bulk_flux.F, it seemed to me that net shortwave radiation is assumed because I didn't see any adjustment to the input for the reflection of shortwave radiation at the surface. And the reflection could be up to 25% of the incoming solar radiation. As a matter of fact, the reflection of the longwave radiation is not taken into account either, I think. However, the reflection of longwave radiation is only about 3% (the emmiss coefficient is equal to 0.97 but isn't applied to the downwelling long wave radiation). Could anyone please clarify this for me?
Thanks a lot,
Jiangtao
Thanks a lot,
Jiangtao
ROMS expects you to provide the NET shortwave radiation.
Looking in bulk_flux.F...
The term
emmiss*StefBo*TseaK(i)*TseaK(i)*TseaK(i)*TseaK(i)
is only the emitted, so the downwelling longwave is supposed to be already provided to the net of reflection, i.e., the full term
IRdown * (1-reflectivity)
# elif defined LONGWAVE_OUT
! Treat input longwave data as downwelling radiation only and add
! outgoing IR from model sea surface temperature.
LRad(i,j)=lrflx(i,j)*Hscale- &
& emmiss*StefBo*TseaK(i)*TseaK(i)*TseaK(i)*TseaK(i)
another question about surface forcing
Thanks for the reply.
I have another question about other properties in the surface forcing: should I use wind, air temperature, relative humidity and air pressure at 10-meter-height or at surface? In mod_scalars.F, it's said that the height of atmospheric boundary layer is set to 10m and the wind, temperature and humidity measurements are at 10m. What about pressure?
-Jiangtao
-Jiangtao
The BULK_FLUX option for surface heat and momentum flux boundary conditions uses the COARE algorithms described in:
Fairall, C., E. Bradley, D. Rogers, J. Edson, and G. Young, 1996: Bulk parameterization of air-sea fluxes for TOGA COARE. Journal of Geophysical Research, 101, 3747-3764.
Fairall, C. W., E. F. Bradley, J. E. Hare, A. A. Grachev, and J. Edson, 2003: Bulk Parameterization of Air–Sea Fluxes: Updates and Verification for the COARE Algorithm. Journal of Climate, 16, 571-591.
Following meteorological conventions, the input data are wind velocity at 10 m height, air temperature at 2 m height, relative humidity at 2 m height, and air pressure at sea surface.
For example, if you were using the NCEP NAM forecast data available from the NOMADS Opendap server at
http://nomad3.ncep.noaa.gov/ncep_data/index.html
you would want the following variables described at, e.g. http://nomad3.ncep.noaa.gov:9090/dods/n ... r_00z.info
ugrd10m ** 10 m u wind [m/s]
vgrd10m ** 10 m v wind [m/s]
pressfc ** surface pressure [pa]
tmp2m ** 2 m temp. [k]
rh2m ** 2 m relative humidity [%]
the heights of measurements are, by default (from mod_scalars.F)
so I suppose you should set blk_ZW, blk_ZT and blk_ZQ according to the height of your input data.
Any confirmation on that?
Jacopo
#ifdef BULK_FLUXES
! Constants used in surface fluxes bulk parameterization.
! blk_Cpa Specific heat capacity for dry air (J/kg/K).
! blk_Cpw Specific heat capacity for seawater (J/kg/K).
! blk_Rgas Gas constant for dry air (J/kg/K).
! blk_Zabl Height (m) of atmospheric boundary layer.
! blk_ZQ Height (m) of surface air humidity meassurement.
! blk_ZT Height (m) of surface air temperature meassurement.
! blk_ZW Height (m) of surface winds meassurement.
! blk_beta Beta parameter evaluated from Fairall low windspeed
! turbulence data.
! blk_dter Temperature change.
! blk_tcw Thermal conductivity of water (W/m/K).
! blk_visw Kinematic viscosity water (m2/s).
real(r8) :: blk_Cpa = 1004.67_r8 ! (J/kg/K), Businger 1982
real(r8) :: blk_Cpw = 4000.0_r8 ! (J/kg/K)
real(r8) :: blk_Rgas = 287.1_r8 ! (J/kg/K)
real(r8) :: blk_Zabl = 600.0_r8 ! (m)
real(r8) :: blk_ZQ = 10.0_r8 ! (m)
real(r8) :: blk_ZT = 10.0_r8 ! (m)
real(r8) :: blk_ZW = 10.0_r8 ! (m)
real(r8) :: blk_beta = 1.2_r8 ! non-dimensional
real(r8) :: blk_dter = 0.3_r8 ! (K)
real(r8) :: blk_tcw = 0.6_r8 ! (W/m/K)
real(r8) :: blk_visw = 0.000001_r8 ! (m2/s)
Jacopo
Default BULK_FLUXES "measurement" heights in mod_s
When BULK_FLUXES is defined, the default "measurement" height for temperature, humidity and wind are all set to 10 m, as Jacopo mentioned.
Yet it seems likely that most people using BULK_FLUXES are using met model output, which typically outputs temperature and humidity at 2 m, and wind at 10 m, as John Wilkin has mentioned.
Perhaps the default heights for temperature and humidity (currently both 10 m) in mod_scalars.F should be changed to 2 m.
-Rich
#ifdef BULK_FLUXES
! turbulence data.
real(r8) :: blk_ZQ = 2.0_r8 ! (m)
real(r8) :: blk_ZT = 2.0_r8 ! (m)
Re: shortwave solar radiation in ROMS surface forcing
However,for the Jerlov water typeROMS expects you to provide the NET shortwave radiation.
https://www.myroms.org/wiki/index.php/Jwtype
Qsw is the downward shortwave radiation at the sea surface.
So, i have a little confused about the srflux.
Qsw is the same as srflux and is the downward shortwave radiation at the sea surface that enters the ocean.
The remark that it is net shortwave is to emphasize that on the atmosphere side the reflected upward shortwave (due to ocean surface albedo) needs to be subtracted from the downward shortwave to get the flux that crosses the air-sea interface.
