Hi all, I'm doing a run with run_inter.csh but I get the following problem:
CHECKDIMS ERROR: inconsistent size of dimension 'xi_u': 155 (must be 40).
how to fix this? Thanks in advance for the help
Gustavo
dimension 'xi_u' problems
Re: dimension 'xi_u' problems
What do you think your grid dimensions are? Is your Lm closer to 40 or to 155? You need to figure out where ROMS is getting that other number from. Is it from your ocean.in file or from say the grid file?
ROMS is reading the dimension from roms_grd.nc file. I've already run the model in this way but do I don't know why this error occurs.
