time range mismatch
andres
time range mismatch
#1 Unread post by andres »
I want to do a hindcast run using Roms_Agrif v1.2 and SODA data which is saved into monthly files
When I try to run the coe I get the following error.
SET_CYCLE ERROR: non-cycling regime, but model time exeeds
time of the last available data record for variable: bry_time
TDAYS = 0.3652E+05 TLAST = 0.3660E+05
could you explain me where is the mistmatch?
Regards.
Andres
What is the time of your initial conditions and what are the times listed in the boundary file?
andres
data from roms_ini.nc and roms_bry.nc
#3 Unread post by andres »
kate wrote:What is the time of your initial conditions and what are the times listed in the boundary file?
From roms_ini.nc
tstart = 36524
tend = 36524
scrum_time = 3155673600
From the roms_bry.nc
bry_time = 36849.0208333334, 36859.0208333334, 36869.0208333334,
36879.0208333334, 36889.0208333334, 36899.0208333334
and the error output is
TDAYS = 0.3652E+05 TLAST = 0.3690E+05
GET_BRY -- Read all boundary data for time = 0.3685E+05
-1
Is this the information you need?
Andres
The error makes sense then. The model will try to read boundary info for a time that is equal to or before your model time as well as a time that is equal to or after your model time, then linearly interpolate between the two. All of your boundary times are in the future.
yxli
Re: time range mismatch
#5 Unread post by yxli »
Hello, I have the same problem, how did you solve it?
