I am wondering if there is an option to save float output in several files? Just like the existing option for history files (NDEFHIS) and others.
This would be very useful for long simulations with many particles.
Regards,
Mari
Option for float output file
Re: Option for float output file
No, this is in my to do list for future releases. I assume that you are deploying millions of floats. The floats NetCDF is never that big to require splitting in my applications. The problem with the splitting the float files is that it makes the plotting of the trajectories trickier.
I looked into splitting the fish output file, which is similar to the floats output file. One thing that's tricky is the restart. Presumably you want to read the float locations from the last record of the last file. I'll attach the fishy output.F for you to look at.
output.F
- Fish version of output.F
- (23.36 KiB) Downloaded 1264 times
Currently I am deploying about 500.000 particles. I will probably increase this number when it is possible to split up the float file, which I will be looking forward to!
Thank you Kate, I will take a closer look at your output.F.
Mari
Mari
Hi, I came across the same problem as Mari met. I follow Kate's suggestion to split float trajectory. And finally it works. Hope it can help rookies like me.
This is what I did.
This is what I did.
In Nonlinear/output.F
ifdef FLOATS
! If appropriate, process floats NetCDF file.
# ifdef MARGINAL_FT
IF (Nfloats(ng).gt.0.and.(nFLT(ng).gt.0)) THEN
! Create output floats NetCDF file or prepare existing file
! to append new data to it. Also, notice that it is possible to
! create several files during a single model run.
IF (LdefFLT(ng)) THEN
IF (ndefFLT(ng).gt.0) THEN
IF (idefFLT(ng).lt.0) THEN
idefFLT(ng)=((ntstart(ng)-1)/ndefFLT(ng))*ndefFLT(ng)
IF ((ndefFLT(ng).eq.nFLT(ng)).and. &
& (idefFLT(ng).le.0)) THEN
idefFLT(ng)=ndefFLT(ng) ! one file per record
ELSE IF (idefFLT(ng).lt.iic(ng)-1) THEN
idefFLT(ng)=idefFLT(ng)+ndefFLT(ng)
IF (ndefFLT(ng).eq.nFLT(ng)) THEN
ifile=(iic(ng)-1)/ndefFLT(ng)
ELSE
ifile=(iic(ng)-1)/ndefFLT(ng)+1
! Restart case
! First, let's check if we need to read from the old file.
IF ((nrrec(ng).ne.0).and.(iic(ng).eq.ntstart(ng))) THEN
NewFile=.FALSE.
Ldefine=.TRUE.
IF ((iic(ng)-1).eq.idefFLT(ng)) THEN
idefFLT(ng)=idefFLT(ng)+nFLT(ng) ! restart offset
ELSE IF ((iic(ng)-1).eq.idefFLT(ng)) THEN
IF (nFLT(ng).ne.ndefFLT(ng).and.iic(ng).eq.ntstart(ng)) THEN
Ldefine=.TRUE.
Newfile=.TRUE.
ELSE
Ldefine=.FALSE.
IF (Ldefine) THEN
NrecFLT(ng)=0
IF (Master) THEN
lstr=LEN_TRIM(FLTbase(ng))
WRITE (FLTname(ng),60) FLTbase(ng)(1:lstr-3),ifile
60 FORMAT (a,'_',i4.4,'.nc')
# ifdef DISTRIBUTE
CALL mp_bcasts (ng, iNLM, FLTname(ng))
IF (ncFLTid(ng).ne.-1) THEN
CALL netcdf_close (ng, iNLM, ncFLTid(ng))
CALL def_floats (ng, Newfile)
LwrtFLT(ng)=.TRUE.
ELSE
IF (iic(ng).eq.ntstart(ng)) THEN
CALL def_floats (ng, ldefout(ng))
LwrtFLT(ng)=.TRUE.
LdefFLT(ng)=.FALSE.
! Write out data into FLT NetCDF file.
IF ((MOD(iic(ng)-1,nFLT(ng)).eq.0).and. &
& ((frrec(ng).eq.0).or.(iic(ng).ne.ntstart(ng)))) THEN
CALL wrt_floats (ng)
# else
IF (Lfloats(ng).and. &
& (Nfloats(ng).gt.0).and.(nFLT(ng).gt.0)) THEN
! Create output floats NetCDF file or prepare existing file to
! append new data to it.
IF (frrec(ng).eq.0) THEN
NewFile=.TRUE.
ELSE
NewFile=.FALSE.
CALL def_floats (ng, NewFile)
LdefFLT(ng)=.FALSE.
! Write out data into floats NetCDF file.
# endif ! marginal
# endif ! floats
In Utility/inp_par.F
ifdef MARGINAL_FT
ELSE IF (TRIM(KeyWord).eq.'NDEFFLT') THEN
Npts=load_i(Nval, Rval, Ngrids, ndefFLT)
ELSE IF (TRIM(KeyWord).eq.'FLTNAME') THEN
DO i=1,LEN(FLTname(Nval))
FLTname(Nval)(i:i)=blank
# ifdef MARGINAL_FT
FLTbase(Nval)(i:i)=blank
FLTname(Nval)=TRIM(ADJUSTL(Cval(Nval)))
# ifdef MARGINAL_FT
FLTbase(Nval)=TRIM(ADJUSTL(FLTname(Nval)))
In mod_iounits.F
# ifdef MARGINAL_FT
character (len=256), dimension(Ngrids) :: FLTbase
In mod_ncparam.F
# ifdef MARGINAL_FT
integer :: idefFLT(Ngrids) ! history file creation flag
# ifdef MARGINAL_FT
idefFLT(ng)=-1
In mod_scalars.F
# ifdef MARGINAL_FT
logical, dimension(Ngrids) :: LwrtFLT ! Write history file
# ifdef MARGINAL_FT
integer, dimension(Ngrids) :: ndefFLT ! History file
# ifdef MARGINAL_FT
LwrtFLT(ng)=.FALSE.
