IO
ROMS I/O
Serial I/O
Parallel I/O with NetCDF-4
    INP_LIB = 2
    OUT_LIB = 2
    PIO_METHOD = 2
    ! [1] Box rearrangement
    ! [2] Subset rearrangement
    PIO_REARR = 1
    PIO_REARRCOM = 0
    ! [3] Disable flow control
    PIO_REARRDIR = 0
Output Multi-Files
  • Timestepping parameters.
    LcycleRST == T  ! Switch to recycle restart time records (file with only 2 cycling time records)
    DSTART = 365.0d0  ! days (ROMS is initialized on 2007-01-01 00:00:00Z)
    TIDE_START = 0.0d0  ! days
    TIME_REF = 20060101.0d0  ! yyyymmdd.dd (Very important: ROMS time is seconds since 2006-01-01 00:00:00Z)
MOD(NTIMES, NDEFHIS) = 0
MOD(NTIMES, NDEFQCK) = 0
MOD(NTIMES, NDEFAVG) = 0
MOD(NTIMES, NDEFDIA) = 0
MOD(NTIMES, NRST) = 0
MOD(NDEFHIS, NHIS) = 0
MOD(NDEFQCK, NQCK) = 0
MOD(NDEFAVG, NAVG) = 0
MOD(NDEFDIA, NDIA) = 0
MOD(NRST, NHIS) = 0
MOD(NRST, NQCK) = 0
MOD(NRST, NAVG) = 0
MOD(NRST, NDIA) = 0
