IO
Serial I/O
Parallel I/O with NetCDF-4
PIO_METHOD = 2
! [3] Disable flow control
PIO_REARRDIR = 0
Output Multi-Files
- Timestepping parameters.
LcycleRST == T ! Switch to recycle restart time records (file with only 2 cycling time records)
- Timestamp assigned for model initialization, reference time origin for tidal forcing, and model reference time for output NetCDF units attribute.DSTART = 365.0d0 ! days (ROMS is initialized on 2007-01-01 00:00:00Z)
TIDE_START = 0.0d0 ! days
TIME_REF = 20060101.0d0 ! yyyymmdd.dd
MOD(NTIMES, NDEFQCK) = 0
MOD(NTIMES, NDEFAVG) = 0
MOD(NTIMES, NDEFDIA) = 0
MOD(NTIMES, NRST) = 0
MOD(NDEFHIS, NHIS) = 0
MOD(NDEFQCK, NQCK) = 0
MOD(NDEFAVG, NAVG) = 0
MOD(NDEFDIA, NDIA) = 0
