IO
Serial I/O
Parallel I/O with NetCDF-4
PIO_METHOD = 2
! [3] Disable flow control
PIO_REARRDIR = 0
Ouput Multi-Files
Sometimes, it is advantageous to time-split ROMS output (averages, diagnostic, history, and quicksave) into multiple NetCDF files to avoid creating huge files on disk for storage in applications with large grids. Smaller files are easy to handle and can be concatenated in OpenDAP catalogs.
For example, an application for a particular area with a substantial grid size needs to be run for one year. The ROMS timestep is DT = 300 seconds. Then, one could split the history and quicksave data into daily NetCDF files with single or multiple time records every 3, 6, or 24 hours. In this case, ROMS will generate a sequence of files with suffixes _0001.nc to _0365.nc filenames. Therefore, we need the following parameters in roms.in:
- Timestepping parameters.
