IO
Serial I/O
Parallel I/O with NetCDF-4
PIO and SCORPIO libraries are primarily intended for ROMS distributed-memory (MPI) applications running on a large number of processes in an HPC system with a Parallel File System (like Lustre, GPFS, and so on) for high-performance I/O. The PIO and SCORPIO library uses the MPI-IO interface to facilitate the partitioning of the data across computational or dedicated I/O processes. take a different approach by allowing the user to specify which processes will handle I/O. For example, in an HPC cluster environment with Parallel I/O hardware, the user can instruct PIO or SCORPIO to designate which processes per node to perform I/O. This is a much more reasonable approach for larger applications running on hundreds of processors. To use this Parallel I/O strategy, the PIO or SCORPIO library must be linked to ROMS at compile time by defining the PIO_LIB CPP option. It is only available in distributed-memory applications since it uses MPI-IO.
PIO_METHOD = 2
! [3] Disable flow control
PIO_REARRDIR = 0
