IO
ROMS I/O
  4. Multiple files, multiple writers: Parallel I/O in which each distributed-memory or shared-memory tile decomposition writes its data into the partition file. Still, post-processing is required to pack the data into a single file. Currently, this capability is not available in ROMS but can be easily implemented within its current I/O infrastructure. However, this strategy is cumbersome and undesired in variational data assimilation (4D-Var) algorithms that require reading forwards and backward in time the state trajectories. As a consequence, reading becomes the bottleneck.
Serial I/O
Parallel I/O with NetCDF-4
PIO and SCORPIO libraries are primarily intended for ROMS distributed-memory (MPI) applications running on a large number of processes in an HPC system with a Parallel File System (like Lustre, GPFS, and so on) for high-performance I/O. The PIO and SCORPIO library uses the MPI-IO interface to facilitate the partitioning of the data across computational or dedicated I/O processes. take a different approach by allowing the user to specify which processes will handle I/O. For example, in an HPC cluster environment with Parallel I/O hardware, the user can instruct PIO or SCORPIO to designate which processes per node to perform I/O. This is a much more reasonable approach for larger applications running on hundreds of processors. To use this Parallel I/O strategy, the PIO or SCORPIO library must be linked to ROMS at compile time by defining the PIO_LIB CPP option. It is only available in distributed-memory applications since it uses MPI-IO.
    INP_LIB = 2
    OUT_LIB = 2
    PIO_METHOD = 2
    ! [1] Box rearrangement
    ! [2] Subset rearrangement
    PIO_REARR = 1
    PIO_REARRCOM = 0
    ! [3] Disable flow control
    PIO_REARRDIR = 0
