IO
ROMS I/O
ROMS uses NetCDF for all its input and output data management. The NetCDF files can be processed using the standard library developed by UNIDATA, the Parallel-IO (PIO) library developed at NCAR, or the Software for Cashing Output and Reads for Parallel I/O (SCORPIO) library intended for the DOE's Energy Exascale Earth Model System (E3SM). The SCORPIO library was forked from the PIO library several years ago and evolved separately. The generic interface for parallel I/O in ROMS works for both the PIO or SCORPIO libraries and available by activating the PIO_LIB CPP option. However, we recommend using the PIO library because it is more efficient in processing I/O in our benchmark tests. Furthermore, another parallel I/O strategy has been available in ROMS for several years with the NetCDF4/HDF5 libraries by activating the PARALLEL_IO and HDF5 CPP options.
Serial I/O
Parallel I/O with NetCDF-4
PIO and SCORPIO libraries are primarily intended for ROMS distributed-memory (MPI) applications running on a large number of processes in an HPC system with a Parallel File System (like Lustre, GPFS, and so on) for high-performance I/O. The PIO and SCORPIO library uses the MPI-IO interface to facilitate the partitioning of the data across computational or dedicated I/O processes. take a different approach by allowing the user to specify which processes will handle I/O. For example, in an HPC cluster environment with Parallel I/O hardware, the user can instruct PIO or SCORPIO to designate which processes per node to perform I/O. This is a much more reasonable approach for larger applications running on hundreds of processors. To use this Parallel I/O strategy, the PIO or SCORPIO library must be linked to ROMS at compile time by defining the PIO_LIB CPP option. It is only available in distributed-memory applications since it uses MPI-IO.
There are two modes of parallel I/O in PIO AND SCORPIO:
In parallel I/O, writing is usually a more frequent and more complicated operation than reading. Generally, there are four strategies for writing (Mendez et al., 2019; ​Preprint):
  1. Single file, single writer: serial I/O. It is the default strategy in ROMS using the NetCDF3 or NetCDF4 libraries.
  2. Single file, multiple writers: parallel I/O with each tile writing its data to a single file. In ROMS, this capability is achieved by activating PARALLEL_IO and HDF5. It is only possible with the NetCDF4/HDF5 libraries.
  4. Multiple files, multiple writers: Each tile writes its own file, but post-processing is required. Currently, this capability is not available in ROMS but can be easily implemented with the changes introduced in this update.
    INP_LIB = 2
    OUT_LIB = 2
    PIO_METHOD = 2
    ! [1] Box rearrangement
    ! [2] Subset rearrangement
    PIO_REARR = 1
    PIO_REARRCOM = 0
    ! [3] Disable flow control
    PIO_REARRDIR = 0
