user
user
- user
- Generic User parameters, NUSER values are expected.
- routine = mod_scalars.F
- keyword = USER
- input = roms.in
From roms.in we have the following:
! [ isFsur = 1 ] free-surface
! [ isTvar = ? ] Last tracer
