Nested Grids
Nested Grids Menu | |
1. Introduction | |
Nested Grids Classes
The ROMS nested grid design includes three Super-Classes and several Sub-Classes:
- Mosaic Grids Sub-Class
- Single Refinement Sub-Class
- Composite Grids
Mosaic Sub-Class:
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2 -
Composite Overlap Sub-Class:
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2 -
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2 -
Ngrids = 6
NestLayers = 1
GridsInLayer = 6
Ncontact = 10
- Refinement Grids
Single Refinement Sub-Class:
Ngrids = 2
NestLayers = 2
GridsInLayer = 1 1
Ncontact = 2 -
Ngrids = 4
NestLayers = 3
GridsInLayer = 1 2 1
Ncontact = 6
Ngrids = 3
NestLayers = 2
GridsInLayer = 2 1
Ncontact = 4 -
Ngrids = 3
NestLayers = 2
GridsInLayer = 1 2
Ncontact = 4
- Hweight(3,:) = p * q
- Hweight(1,:) = 1.0
- Hweight(2,:) = 0.0
- Hweight(3,:) = 0.0
- Hweight(4,:) = 0.0
and
TYPE T_NGC
END TYPE T_NGC
- Mosaic Sub-Class
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Receiver Grid = red -
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Receiver Grid = blue
- Composite Overlap Sub-Class
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Ngrids = 6
NestLayers = 1
GridsInLayer = 6
Ncontact = 10
Donor Grid = blue
Ngrids = 6
NestLayers = 1
GridsInLayer = 6
Ncontact = 10
Donor Grid = red
Ngrids = 2
NestLayers = 2
GridsInLayer = 1 1
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 2
GridsInLayer = 1 1
Ncontact = 2
Donor Grid = red
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = blue
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = red
Receiver Grid = blue -
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = red
Receiver Grid = green -
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = green
Receiver Grid = red
Ngrids = 3
NestLayers = 2
GridsInLayer = 2 1
Ncontact = 4
Donor Grid = blue
Ngrids = 3
NestLayers = 2
GridsInLayer = 2 1
Ncontact = 4
Donor Grid = red
Ngrids = 3
NestLayers = 2
GridsInLayer = 1 2
Ncontact = 4
Donor Grid = blue
Ngrids = 3
NestLayers = 2
GridsInLayer = 1 2
Ncontact = 4
Donor Grid = red
Ngrids = 3
NestLayers = 2
GridsInLayer = 1 2
Ncontact = 4
Donor Grid = red
Ngrids = 3
NestLayers = 2
GridsInLayer = 1 2
Ncontact = 4
Donor Grid = green
Receiver Grid = red
Nesting Test Cases
- RHO-MASK
RHO-MASK Whole Grid -
RHO-MASK Composite Grids
- Contact Points, Composite
Donor Grid = blue
Donor Grid = red
Donor Grid = blue
Donor Grid = red
- RHO-MASK
RHO-MASK Refinement Grid
- Contact Points, Refinement
Donor Grid = red (coarse)
Receiver Grid = blue (fine) -
Donor Grid = blue (fine)
Receiver Grid = red (coarse)
Contact Points Metadata
dimensions:
Ngrids = 2 ;
Ncontact = 2 ;
Nweights = 4 ;
datum = 350 ;
variables:
int spherical ;
int Lm(Ngrids) ;
int Mm(Ngrids) ;
int coincident(Ngrids) ;
int composite(Ngrids) ;
int mosaic(Ngrids) ;
mosaic:flag_values = 0, 1 ;
int refinement(Ngrids) ;
int refine_factor(Ngrids) ;
int interpolate(Ncontact) ;
int donor_grid(Ncontact) ;
int receiver_grid(Ncontact) ;
int NstrR(Ncontact) ;
int NendR(Ncontact) ;
int NstrU(Ncontact) ;
int NendU(Ncontact) ;
int NstrV(Ncontact) ;
int NendV(Ncontact) ;
int contact_region(datum) ;
int on_boundary(datum) ;
on_boundary:flag_meanings = "other western southern eastern northern" ;
int Idg(datum) ;
int Jdg(datum) ;
int Irg(datum) ;
Irg:coordinates = "Xrg Yrg" ;
int Jrg(datum) ;
Jrg:coordinates = "Xrg Yrg" ;
double Xrg(datum) ;
Xrg:units = "meter" ;
double Yrg(datum) ;
Yrg:units = "meter" ;
double h(datum) ;
h:units = "meter" ;
h:coordinates = "Xrg Yrg" ;
h:_FillValue = 1.e+37 ;
double f(datum) ;
f:units = "second-1" ;
f:coordinates = "Xrg Yrg" ;
f:_FillValue = 1.e+37 ;
double pm(datum) ;
pm:units = "meter-1" ;
pm:coordinates = "Xrg Yrg" ;
pm:_FillValue = 1.e+37 ;
double pn(datum) ;
pn:units = "meter-1" ;
pn:coordinates = "Xrg Yrg" ;
pn:_FillValue = 1.e+37 ;
double dndx(datum) ;
dndx:units = "meter" ;
dndx:_FillValue = 1.e+37 ;
double dmde(datum) ;
dmde:units = "meter" ;
dmde:_FillValue = 1.e+37 ;
double angle(datum) ;
angle:units = "radians" ;
angle:_FillValue = 1.e+37 ;
double mask(datum) ;
mask:flag_values = 0., 1. ;
global attributes:
:grid_files = " \n",
